Old 01-12-2003, 02:06 PM   #1
chrislehr
Member#: 24165
2003 WRX Sedan
World Rally Blue
Default My grounding mods and also gutterguard'd my scoop *pics*
and I have a gutterguard screen on my hood scoop and did the DIY grounding mod for the WRX
Cant really see the screen in the last pic, too sunny...
My homemade cables:
The battery connections
The drivers strut and intake manifold connections
The passenger strut and intake manifold
The hand I hurt doing the passenger intake manifold bolt
The hood scoop finished:
The hood scoop pchopped so you can see it:
chrislehr is offline   Reply With Quote
Old 01-12-2003, 03:05 PM   #2
vapore0n
Member#: 21356
2010 BMW 335i
2017 STI Limited LBP
I have the self made ground mods. A lot cheaper than brand named, and does the same thing. <<cough carwash cough>>
I installed mine yesterday, so I have yet to test the car.
vapore0n is offline   Reply With Quote
Old 01-12-2003, 08:41 PM   #3
chrislehr
Member#: 24165
2003 WRX Sedan
World Rally Blue
Its too cold to wash the car... I dont trust or like car washes.. so to sit out for an hour and do it right = cant feel my hands
Old 01-13-2003, 07:48 PM   #4
vapore0n
Member#: 21356
2010 BMW 335i
I do the same thing, wash it under 20F isnt that easy, especially when the watter freezes and the watter coming from the hose doesnt defrost it, unly adds more to it. But this last weekend got the job done, and waxed too too bad snow is coming tonight
Old 01-13-2003, 08:36 PM   #5
SjpWrx
Member#: 22554
2007 Corolla no PW!
WHITE miss my WRX :(
Default ..
is there any benefit from this mod. looks simple enough to do.
SjpWrx is offline   Reply With Quote
Old 01-13-2003, 10:25 PM   #6
tuca33
Member#: 24303
2002 Impreza WRX
Did it hurt a lot in the hand??
Seems preety dolorous.
Tuca
tuca33 is offline   Reply With Quote
Old 01-13-2003, 11:44 PM   #7
koloumb
Member#: 28268
2002 WRX Sedan
Only 3 cables? You need about 100 to properly ground your engine!!
Looks good. I've got some funky green/yellow wire that should look very rude in my engine bay. Any one who works on it will wonder what the heck I'm doing...
_0wen_
koloumb is offline   Reply With Quote
Old 01-18-2003, 07:34 AM   #8
e-llipsis
Member#: 22107
2005 Subaru STi CGM
Indy Region - STU 9
Post DIY Ground Mod
For those of you who may not have found this yet - here is a fairly good diy on the grounding mod. The article doesn't have any pics but if you combine the instructions there with the pics chrislehr has posted here you will have about 95% of what you need right at your fingertips.
http://www.wrxfanatics.com/DIY/Grounding/Ground.htm
Marshall
p.s. I have access to the materials to do this in Black, Blue, Red and Yellow wire along with some very nice gold plated ring terminals. Since I am already making several kits for my group, if anyone wants a kit from me I'd consider making some extras for ~$40 - $45 shipped. Anyone who is interested can PM me.
e-llipsis is offline   Reply With Quote
Old 01-28-2003, 08:55 PM   #9
STi-Nismo Dood
Member#: 4149
MY93 Impreza 6MT
GC8.6 Aspen White
I installed my ground wire between the bushing plate of the screw that holds the windshield washer container, it has a charge going through it, so is that considered a sucessful ground mod? It doesnt neccessarily have to be the six noted on web site points necessarily does it? As long as the wire actually grounds to the chassis, thats fine right?
STi-Nismo Dood is offline   Reply With Quote
Old 01-29-2003, 01:32 PM   #10
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
I bolted my ground wires directly to the wires that were bolted onto the chassis. I don't think it would really hurt if the wire was just on the chassis, but the main idea of the ground mod is to give the least resistance possible for grounding the engine and other sensors. Since electrical current takes the path of least resistance, placing the wire somewhere along the chassis still means the current will still be travelling through some of the chassis instead of mostly going through the grounding cable.
For those interested, I would be able to make grounding wires in black, red, blue (I'll check for other available colors) with gold plated ring terminals soldered to the wire instead of just securing it by crimping the terminals. Just crimping the terminals still leads to the wire sliding off eventually.. for about $40 shipped PM or email me.
-Victor
cRayZee is offline   Reply With Quote
Old 01-29-2003, 01:54 PM   #11
empreza[RS]
Member#: 13263
2001 Impreza RS 2.5
Pearl White
I am interested. Just PM you. $40.00 shipped is pretty cheap. Can you make mine in black, since ground should be black ? Do these come with directions?
empeza[RS]
empreza[RS] is offline   Reply With Quote
Old 01-29-2003, 01:58 PM   #12
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
dood, you're in san diego, come pick it up, I'll help you install
Old 01-29-2003, 02:31 PM   #13
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
I am still waiting to do this mod when I have the time (albeit on a GC8) There has been a lot of talk on this mod for a while in the NA forum. Interesting to see it works on the WRX also
Eric
Eric SS is offline   Reply With Quote
Old 01-31-2003, 08:54 PM   #14
STi-Nismo Dood
Member#: 4149
MY93 Impreza 6MT
GC8.6 Aspen White
is that why I get shocked sometimes when touching my car body after driving it? But I can see that a car needs a LOT of these grounding wires, not just 1 or 2 to see visible results, but my brain might be faulty for thinking that
Old 01-31-2003, 09:06 PM   #15
supermarkus
Member#: 6971
2008 WRX STi
SSM
No, your clothing builds up static electricity as you are sliding out of the car seat and you discharge it as soon as you touch the door. This has nothing to do with the grounding mod, which I've found to do nothing for my car. It has more to do with weather conditions. I never get shocked on rainy days.
I wasn't ever actually experiencing hesitation or stumbling but I did it as a preventative measure. I've noticed no improvement or degradation in the way my car runs, it was just possibly wasted money and time.
supermarkus is offline   Reply With Quote
Grounding mod FAQ the right way thread pics too! Davenow Electrical & Lighting 727 08-03-2015 10:10 AM
Grounding Mod and Possible Heat Problem Meat Electrical & Lighting 3 08-11-2003 03:54 PM
Un-grounding mod and hesitation Snowman South East Region Forum 41 02-26-2003 09:43 PM
Did My Grounding Mod Today.... karazyman Member's Car Gallery 9 07-14-2002 09:45 PM
My Grounding Mod z28dan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 06-15-2002 12:02 AM
