Old 01-12-2003, 06:04 PM   #1
dvancleve
Member#: 5211
2007 Outback XT Ltd.
Diamond Gray Metallic
Question Reset check engine light w/out going to dealer?
My check engine light came on a couple days ago for no apparent reason. I checked the oil and coolant and everything seems fine. The car is running normally as far as I can tell, and I suspect there isn't really anything wrong. I know that things like not getting the gascap on tight can trigger the warning light... I would like to reset it myself and see if it stays off. Would disconnecting the battery overnight do it? If now, can it be done without visiting the dealer?
Thanks, Doug
dvancleve is offline   Reply With Quote
Old 01-12-2003, 07:23 PM   #2
AGscooby
Member#: 4242
1999 BD SUS GRN/GLD
gimme Legacy TPH wagon!
Lightbulb
IIRC, resetting the ECU as you suggest will clear the CEL. I believe the battery need only be disconnected for a little over an hour. There's a nice little write-up on ScoobyMods.com.
AG
May the B4 be with you!
AGscooby is offline   Reply With Quote
Old 01-12-2003, 07:24 PM   #3
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Removing the battery may or maynot work. If one of the gazillion sensors are bad it will just come back on again. You can take it to an autozone and have the code pulled and see what's wrong though.
Peaty is offline   Reply With Quote
Old 01-13-2003, 03:09 PM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
But you dont NEED to reset the light!!!
If the problem is fixed the light will go out. If the problem still exists the light stays on. Its very simple.
Old 01-13-2003, 03:29 PM   #5
richeich
Member#: 1353
2001 Impreza 2.5RS
I always thought that once it threw a code, the CEL would stay on until it was reset. Mine threw a CEL a few weeks ago. It was only on for about a day before I had some other work to do on the car. I disconnected the battery and reset the ECU while I was working on it. Everything has been fine since, no CEL. I figure if it comes back, then maybe I'll have the code pulled. Otherwise, I'm not worried about it.
Rich
richeich is offline   Reply With Quote
Old 01-13-2003, 03:57 PM   #6
sovereignmk1
Member#: 11858
1998 Silver Legacy
Your local schucks/kragen or similar should be able to pull and clear the code for free
//Mark
sovereignmk1 is offline   Reply With Quote
Old 01-13-2003, 05:32 PM   #7
ciper
Member#: 15543
90BJ Legacy LS ABS
Im going to post something in service forum. I think you guys are wrong.
edit: Lets see what everyone else thinks. http://forums.nasioc.com/forums/show...hreadid=300696
Old 01-13-2003, 08:44 PM   #8
AGscooby
Member#: 4242
1999 BD SUS GRN/GLD
Wink
Okie doke, I stand corrected. The circumstances under which the CEL occurs depends on the type of problem. If Doug's car is functioning, he can try to clear it by disconnecting the battery. If the CEL continues to occur or reappears again, then there is a 'hard fault' cauing the code. If the CEL does not appear again, the cause was possibly intermittent.
AG
Old 01-14-2003, 08:45 PM   #9
dvancleve
Member#: 5211
Exclamation Disconnecting the battery cleared the CEL...
To recap,
I had the CEL come on but couldn't detect anything wrong (oil and coolant levels fine, car running normally). I know something as trivial as leaving the gas cap a bit loose can trigger the CEL (and I figure if something is really wrong it will come right back on), so I disconnected the battery overnight to see if it would go away. It did, and hasn't come back so far.
I realize that this should have/did clear out the ECU memory, but I can't feel a difference seat of the pants and my mileage is not that great anyway. I guess if the light comes back on soon I will take it in to the dealer or see if there is an independent Subie shop in the Chandler/Mesa/Tempe area...
Doug
Old 01-15-2003, 10:25 AM   #10
AGscooby
Member#: 4242
1999 BD SUS GRN/GLD
Lightbulb Re: Disconnecting the battery cleared the CEL...
Doug
I've read that it'll take a 100 miles or more before your ECU has relearned your driving habits. Since you weren't getting great gas mileage previously, you might want to go easy on the gas to put the ECU on the "economic learning track".
AG
Old 01-15-2003, 04:33 PM   #11
rallysquirrel
Member#: 7006
2007 SpecB
watch out for that CEL. If its misfire in a cylinder, you wouldn't feel it, but after a while the headgaskets will go.
rallysquirrel is offline   Reply With Quote
Old 05-21-2013, 05:36 PM   #12
Kevan711
Member#: 330881
2013 Sport Limited
If you disconnect the battery do you lose your bluetooth settings, radio stations, etc?
Kevan711 is offline   Reply With Quote
Old 05-21-2013, 07:57 PM   #13
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Only one way to find out...
Old 05-22-2013, 12:29 PM   #14
subie98
Member#: 225299
lol true
subie98 is offline   Reply With Quote
Old 05-22-2013, 11:58 PM   #15
Frogsthatmoo
Member#: 153374
2001 Outback Wagon
typically, yes
Frogsthatmoo is offline   Reply With Quote
Old 05-23-2013, 04:43 AM   #16
Kevan711
Member#: 330881
2013 Sport Limited
And that would be to ask someone for an intelligent response?
Scan tool needed to reset check engine light - Mission Viejo Area subaruracerx Southern California Impreza Club Forum -- SCIC 10 09-21-2009 07:08 PM
Reset Check Engine Light snowstorm Newbies & FAQs 2 01-11-2007 08:25 PM
How do you reset a check engine light? badsswrx Legacy Forum 5 10-16-2006 04:13 AM
does the check engine light come on when u need to go in for maintenance? garie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 03-11-2004 08:14 AM
check engine light won't go away spgavin Normally Aspirated Powertrain 4 06-07-2001 09:46 AM
