Old 04-28-2001, 06:59 PM   #1
scottsubarus
Member#: 5336
1992 SVX
Angry intake problem/question please help
JCsports intake has been on my wife's 97 Legacy GT(auto) for a couple weeks and she loves the sound! last night my son drove the car to work and said that on HARD accleration from a dead stop he thought the moter had died. He said that he has done that b4 and it took off fine. I checked all clamps/fittings ect all seemed tight still has anyone else had this happen? what should I check next?? Thanks!
scottsubarus is offline   Reply With Quote
Old 04-28-2001, 07:51 PM   #2
SkToBe
Ghost Mod
Member#: 1278
2001 RS
Post
Was she hitting the rev limiter?
SkToBe is offline   Reply With Quote
Old 04-28-2001, 08:25 PM   #3
scottsubarus
Member#: 5336
1992 SVX
Post
No it didn't take off acted like nothing was there for a few seconds, when you backed off the gas it took off fine
Old 04-28-2001, 08:36 PM   #4
SkToBe
Ghost Mod
Member#: 1278
2001 RS
Post
Sorry, no experience with auto's... (never owned one, but I'm sure someone here has some thoughts on what the problem might be)
Old 04-28-2001, 09:37 PM   #5
Really_Soaked
Member#: 4992
2000 Impreza 2.5 RS
Blue Ridge Pearl
Post
This happened to a friend of mine with his legacy wagon.
It just acted like really bad throttle response. Check the airflow sensor (MAF or MAP). You can also try just re-setting the ECU (unplug the negative terminal of the battery for 30 mins).
Best of luck.
-Simon
Really_Soaked is offline   Reply With Quote
Old 04-28-2001, 11:38 PM   #6
bratmantlz
Member#: 3231
88 626 Turbo
white
Smile
its an auto? it bogs down on hard WOT starts? am i right or am i correct? usually the jcsports intakes do loose some low end. i have a S-AFC to correct it.
Brian
bratmantlz is offline   Reply With Quote
Old 04-29-2001, 10:41 AM   #7
scottsubarus
Member#: 5336
1992 SVX
Post
Yes it's an automatic. when it acts up it's like someone shut off the engine for 2/3 seconds. I would have never noticed it but I don't romp on the gas from a dead stop with her car, but with a 16yr old son it's a diffrent story! I'll try resetting the ECU and see what happens
Old 04-29-2001, 10:45 AM   #8
AccidenT
Member#: 2024
2005 Legacy 2.5i
Atlantic Blue Pearl
Post
I have a weapon*R intake (similar to JC-Sports). The other day I was starting from a stop on a hill and I thought my car was going to die. It was bogging and bucking so I pushed in the clutch, let off the gas, gave it gas and then shifted into first. After that it was fine. I don't know if it was fuel starvation or what. I've had the problem one other time starting from a stop on a very slight hill...
AccidenT is offline   Reply With Quote
Old 04-29-2001, 03:09 PM   #9
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
Post
umm...the only two things I've messed with for bogging and such were the fuel filter, plugs, and o2 sensor. It's got 27k on it already and I've had it a year and a half. The sensor was a warranty issue, and the plugs and fuel filter were just maintenance/tuning. Runs fine so far, mods and all. If it's a bad MAF, I'd be very surprised. Check the simple stuff first.
Gary
HamFist is offline   Reply With Quote
Old 04-29-2001, 03:18 PM   #10
KeithRS
Member#: 3436
1987 Rockhopper
Yellow
Exclamation
Sounds like a classic clogged fuel filter- when was the lsat time it was replaced?
When they get old and clogged, you start to get a little bit of hesitation on hard acceleration or sustained high speed driving. Then the engine starts to cut out when you are accelerating from a stop. Try replacing it before you do anything else if you haven't already.
KeithRS is offline   Reply With Quote
INTAKE QUESTION please help nayank24 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 09-19-2007 01:08 PM
Intake question... please help! blt Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 02-01-2006 08:57 PM
Intake Silencer Removal Question, Please HELP!! Inprogress Newbies & FAQs 28 08-06-2004 10:00 PM
('93-'01) please help!! 98 GC8 bumper conversion question, please help!! nateconnella Impreza Forum 10 05-13-2003 05:50 PM
('93-'01) please help!! 98 GC8 bumper conversion question, please help!! nateconnella Impreza Forum 1 05-05-2003 10:11 PM
