Old 04-28-2001, 10:06 PM   #1
cj917
Member#: 627
MY96 outback wagon
Question is this normal?
when i'm in low gears (2nd gear is somehow most apparent) and under 2000rpm, whenever i lift off or press the throttle suddenly, the car sorta bobs back and forth... it has been going on for quite a while, but lately it really started to bother me
anyone has a clue what might be the cause(s)? i think i'll go ahead and reset the ECU and see if that helps, but i wanna know what's causing this
any help is appreciated... thanx~
cj917 is offline   Reply With Quote
Old 04-28-2001, 10:35 PM   #2
Really_Soaked
Member#: 4992
2000 Impreza 2.5 RS
Blue Ridge Pearl
Post
I could almost lift the front end of my RX-7 doing this in 1st gear...
Slamming down on the throttle in a low gear is usually pretty jolty.
-Simon
Really_Soaked is offline   Reply With Quote
Old 04-28-2001, 11:03 PM   #3
cj917
Member#: 627
MY96 outback wagon
Post
i know that for a manual-tranny car in low gear and low rpm it can get quite jolty, but i didn't expect it to be this bad
eitherway even if there's nothing wrong with my car, there's gotta be some way to make it better......
Old 04-28-2001, 11:07 PM   #4
IowaRS
Member#: 5385
2012 WRX Base
Ice Silver
Post
Welcome to the world of AWD!!!
The "jolts and jerks" you get are drivetrain lash. With the AWD system there is a lot of stuff meshing together to make the car go.
When you let off of the gas all of that loosens up at the same time and you get kind of a "bump" or "jolt" when it all tightens back up in the other direction.
EDIT: ByTheWay the ECU has nothing to do with it.
Totally normal, it threw me for a loop when I first got my RS too
[This message has been edited by IowaRS (edited April 28, 2001).]
IowaRS is offline   Reply With Quote
Old 04-29-2001, 12:50 PM   #5
Xio
Member#: 3805
2011 STi Sedan SWP
2011 Outback ABP
Post
IowaRS is completely correct.
Not to worry though, you simply need to learn to modulate the gas more smoothly. It took me alot of practice to get used to it, as I drove a Ford Taurus auto before I got my RS, but it will happen.
Rush hour stop 'n go is a good, if rather frustrating, place to learn smooth driving at low rpms/speeds .
Xio is offline   Reply With Quote
Old 04-29-2001, 02:02 PM   #6
MagicMT
Member#: 4042
2001 Magic Mobile
Old School Style
Post
yep, normal. just gas and clutch very slowly and very smoothly. it's really jolty especially in the morning...
[This message has been edited by MagicMT (edited April 29, 2001).]
MagicMT is offline   Reply With Quote
My clutch is dead at 42K is this normal? Ripper Normally Aspirated Powertrain 9 06-07-2012 08:46 PM
is this normal for the normal headlight sequence for an 07 outback? jawwadh Electrical & Lighting 6 08-09-2008 12:34 AM
Is this normal to do this? SubaruImpreza_power Newbies & FAQs 13 06-23-2004 09:37 AM
Is $2,500 for taxes, plates and doc fee sound crazy or is this normal? twiztid General Community 10 11-07-2002 10:36 PM
Reserve is hard to engage 3 out of 5 times... Is this normal? MrP0nch0 Technical Forum Archive 23 08-29-2000 06:28 PM
