Old 11-03-2003, 11:29 PM   #26
300blueballs
Member#: 39941
2004 Impreza WRX STi
Originally posted by Davenow
My VF24 was creeping from 15 to 18.8PSI.
I ported the wastegate , same deal, more towards the flapper pivit, also severly rounded the passage into the wastegate.
No more boost creep! Although I did have to raise the boost numbers in my utec (which were VERY low anyway) to get the same boost.
Why did you have to raise the boost numbers after porting the wastegate? Doesn't the ECU monitor boost? For example if you had it set for 15lbs shouldn't it hit 15 lbs no matter how much the wastegate was ported (unless you ground it out more than the flapper diameter)?
I guess I am asking if the flap gradually and actively changes its position depending on the boost level (which should on the current wastegate actuator map - depending purely on the boost level and adjusting it to make it match the boost level specified in the programming throughout the RPM range) aka, does the ECU adjust the wastegate according to the new dimensions of the hole by the amt. of boost it sees.
Or is it alot simpler and it's more like if experiencing X amount of boost, open the wastegate by X amount....
(just want to make sure I will not be boosting lower than stock levels if I port mine)
300blueballs is offline   Reply With Quote
Old 02-19-2004, 11:35 PM   #27
Kenneth2000
Member#: 6375
2004 STi
Java Black Pearl
Damn ... I wish I had seen this before I installed my turbo ...
Oh well ....
I guess I'll have to wait now ....
Kenneth2000 is offline   Reply With Quote
Old 02-21-2004, 10:12 PM   #28
300blueballs
Member#: 39941
I've had mine ported by the STi mechanic at my dealership who does aftermarket installs on the side. Boost creep is gone. I'm getting 15psi solid which is what I had stock so I am extremely happy.
He is doing this for a guy from out of state so I'll try to take some pictures then.
Old 04-14-2004, 03:14 PM   #29
Pirana
Member#: 55197
blueballs any updates
Pirana is offline   Reply With Quote
Old 04-14-2004, 03:42 PM   #30
300blueballs
Member#: 39941
Check this out Pirana:
http://www.imprezawrxsti.com/postnuk...ewtopic&t=8186
My boost levels are 100% fine after the port.
Anything else you need to know, I'll be happy to help.
Old 04-15-2004, 06:32 PM   #31
Syck_Driven_STi
Member#: 46274
2004 German
Blue Pearl
nice.
Syck_Driven_STi is offline   Reply With Quote
Old 04-29-2004, 04:07 PM   #32
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
The reason Davenow had to raise his boost levels if pretty simple. First and foremost he was/is using Utec to control boost. With the Utec you don't give it a boost level (i.e. 18psi) you give it a number that changes wastegate duty cycles and a couple other things. Also since the air can move through the wastegate so much easier now it now takes that path as the path of least resistance. By raising your boost values you raise your wastegate duty cycle which keeps the wastegate flapper closed more. If your stock ECU controls boost (stock or reflashed) it should be able to adjust to the increased flow through the wastegate. However there is a limit to how much it can adjust so quite possibly on very hot days you might not beable to hit full boost. I would remove just enough material to make it so that the boost doesn't creep and that is all. Unless of course you have a way to control boost (EBC, Utec, ECUtek).
I hope that wasn't too confusing. Damn did I say wastegate alot.
mbiker97 is offline   Reply With Quote
Old 04-29-2004, 06:52 PM   #33
Pirana
Member#: 55197
Update:
Did my porting myself last week and happy to report that I'am back to full throttle and no boost creep. Steady at 15psi, which was the same I had before the intake and exhaust.
Old 05-02-2004, 09:19 AM   #34
uptownWRX
Member#: 34289
2004 STi
K, so i am putting on a Helix DP and a HKS carbon Ti cat back exhaust on my STi later today. From what I am reading and correct me if I am wrong, in "theory" I will get boost creep correct?
uptownWRX is offline   Reply With Quote
Old 05-02-2004, 11:18 AM   #35
shields102
Member#: 9598
02 wrx
white
^Yes you will.
A buddy of mine and I just ported the wastegate on his sti to relive bc with a helix/blitz combo. We were able to remove the exhaust housing from the center section without removing the entire turbo from the car. Basicly we left the water lines on and were carefull not to doink the turbine blades when we seperated the ex-housing. Its really not that hard. The creep was gone after the port. Boost was good.
shields102 is offline   Reply With Quote
Old 05-03-2004, 03:28 AM   #36
Sauceboy01
Member#: 13107
i cant beleive this thread is stil around.. whoa!
Sauceboy01 is offline   Reply With Quote
Old 07-15-2004, 03:16 PM   #37
makofoto
Member#: 25243
2006 Legacy Outback
Great info ... after putting on my ScoobySport DP ... I'm getting creep ... this should take care of it.
makofoto is offline   Reply With Quote
Old 08-31-2004, 05:02 PM   #38
glilly
Magic 8 ball says Ban
Member#: 7245
13 BRZ
08 Avalanche
what about an external wastegate? anyone done this yet?
Greg
glilly is offline   Reply With Quote
Old 08-31-2004, 05:06 PM   #39
makofoto
Member#: 25243
2006 Legacy Outback
I found the my Shiv dyno tuned EcuTek engine has a little bleed hole tube in the wastegate line ... when I taped over it ... I ended up with stock like boost. By carefully taping over half of the (-0.5 mm) hole ... I stopped getting boost creep ... while maintaining my proper 17 psi boost in high boost mode ... until I was able to get my ECU re-flashed from Vishnu/Shiv with the proper map that took my downpipe into consideration.
Old 02-07-2006, 04:34 PM   #40
06subiwrx
Member#: 106989
06 subaru wrx
white
Subaru Banner Help
HI
I am new in nasoic althought I have read a lot of information posteed.
I have a 06 wrx I installed a hks down pipe and up pipe and greaddy full 3'' cat back, perrin air intake. I was having turbo creep and a friend of mine that has a machine shop and I did the porting in the waste gate I removed 0.177" of material in the waste gate when I reinstalled my turbo I installed a perrin boost controller and the intercoller house kit, everything was find until today that I decided to remove the boost crotroller because (I wasn't happy with it) I was not boosting more that 13 psi (before the porting and boost controller instalation I was boosting 18 psi) so I run it to try and I got boost creep ( fuel cut and engine light and cruise control light went off on the dash) The car with out the boost controller run much better I was boosting close to 17 psi when I hit fuel cut.
The question is has somebody had the same problem before or I need to do some more porting to the waste gate.
Thanks to the pictures and Information provided by austin I did it but I don't know what to do next....
06subiwrx is offline   Reply With Quote
Old 02-07-2006, 04:47 PM   #41
Austin
Member#: 7089
2016 STi
Originally Posted by 06subiwrx
when I reinstalled my turbo I installed a perrin boost controller and the intercoller house kit, everything was find until today that I decided to remove the boost crotroller because I was not boosting more that 13 psi (before the porting and boost controller instalation I was boosting 18 psi) so I run it to try and I got boost creep
If you're not overboosting with a boost controller hooked up, you don't need more porting.
If you're not overboosting with a boost controller hooked up and then you do overboost when you remove the boost controller, your vacuum lines are wrong and/or restricted. You're somehow venting air from the boost control lines, which lowers the pressure exerted on the wastegate actuator, which keeps the wastegate shut longer (or, shut to a greater pressure), which causes your turbo to spin faster & create more boost pressure.
If you run a straight (meaning no other connections) vacuum line from the turbo outlet (highest pressure source) to the wastegate actuator, your boost pressure should max out at wastegate spring pressure. If your boost creeps up above wastegate spring pressure, you have boost creep. If your boost creeps up to a level higher than you want, you need more porting.
With your perrin controller removed, what are you running for boost control?
Austin is offline   Reply With Quote
Old 02-07-2006, 07:12 PM   #42
06subiwrx
Member#: 106989
06 subaru wrx
white
Subaru Banner boost creep
I just reconected the stock "boost controller" (the stock conection turbo to wastegate) the stock lines and I am geting the boost creep. What I don't understand is why after instaling the perrin boost controller my boost levels went down, and know that I reconected the stock lines and my boost increased by a 25 to 30 % per gear (it feels like a diferent car) just know I reconected the perrin boost controler and again no boost creep but boost levels low.
Is there a problem with the boost controller or I did not conected it right but I gonna try I direct line from the turbo to the wastegate. If I do so it is better that the MBC or should I reinstal it the MBC. What do I do with the stock holes I mean when I install the boost controller what happend with the stock lines.
Thanks
Old 02-07-2006, 10:04 PM   #43
06subiwrx
Member#: 106989
06 subaru wrx
white
At the Track boost
I connect the turbo to the wastegate without any boost controler and the car is running better that the MBC so I would like to know if I am going to have any problem
thanks
Old 08-30-2006, 12:24 PM   #44
gregsatt
Member#: 38536
'02 WRX Wagon
FreeRentMoney.com White
Thread revival...
Are there any other benefits to this porting? Does it spool more quickly? I've read somewhere to port some part of the VF39 to get it to spool more quickly, but I can't find the thread.
Also, what type of grinder bit is needed to grind away the metal?
Thanks,
Greg
gregsatt is offline   Reply With Quote
Old 11-02-2006, 04:50 PM   #45
Greg555
Member#: 814
Want engine mgmnt?
I sell ViPec's ECU's
I aslo have a question.
Is boost creep a problem if you are running higher boost levels? (reflashed ECU?)
Greg555 is offline   Reply With Quote
Old 12-31-2007, 04:04 AM   #46
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
very very informative
maxpowr is offline   Reply With Quote
Old 02-23-2008, 10:38 AM   #47
stormhalter
Member#: 145884
06 STi
Blueballs, that link is dead.
I am putting on a Perrin divorced wastegate DP today. What kind of tool does one use to accomplish this task. My buddy has a garage full of em.
stormhalter is offline   Reply With Quote
Old 03-21-2008, 09:05 PM   #48
jobber
Member#: 164043
2015 WRX and FozzyXT
noticed some boost creep lately
2005 wrx stage 2, with catless uppipe and Cobb downpipe w cat.
jobber is offline   Reply With Quote
Old 03-21-2008, 09:08 PM   #49
makofoto
Member#: 25243
2006 Legacy Outback
tools ... first put penetrating oil/spray on the nuts
Old 12-25-2008, 09:06 PM   #50
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
Just installed a Helix catless dp and got this ****ing boost creep. How hard is it to port? Is there a list of tools that i need? Want to buy a used VF 39 exhaust housing
BlackFighter is offline   Reply With Quote
Boost CREEP!!!! HELP andrew3776 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-22-2008 01:16 PM
Fuel Cut? Boost creep? Help with stutter phoenix_wrx AccessPort 19 02-04-2008 11:28 AM
Boost creep and Spiking STOCK!!! Help! Helium Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 12-07-2005 02:29 PM
boost creep? need help gmanwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-30-2005 06:21 PM
Boost creep- vets. please help tntmstr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 11-30-2002 04:22 PM
