Old 04-28-2009, 01:36 AM   #51
clean 93
Member#: 181440
1993 wrx
Good job. Going to port my td05 soon.
clean 93 is offline   Reply With Quote
Old 11-12-2009, 07:53 PM   #52
mysuby
Member#: 166953
everything i'm reading has been about the 2.5L, well my o3 wrx 2.0L i believe has boost creep. i just installed a tbe and now my boost climbs up to .12 bar (i believe thats almost 18psi) in 5th gear by like 5000rpms.. i've been reading about porting the waste gate opening,..but will this help my 2.0? also the pics that were in that thread..no longer are there or will open. i need to fix this prob asap..any help would be wonderful thanks so much.
mysuby is offline   Reply With Quote
Old 11-12-2009, 07:55 PM   #53
mysuby
Member#: 166953
oh and i have a turbo xs mbc ...and still stock turbo with EM if that helps anyone, i'm pull my turbo off this weekend, cause i'm doin a header and catless up pipe,...so i figure while its off or almost off i should address this issue but not sure the best way thanks again in advance
Old 11-12-2009, 08:17 PM   #54
quazimoto
Member#: 70395
You do not get boost creep on a 2.0L.................boost spike and boost creep are two different things.
quazimoto is offline   Reply With Quote
Old 11-12-2009, 08:28 PM   #55
Chi_San
Member#: 53558
2002 WRX Wagon
Boost creep is caused by a wastegate that is too small for the boost (volume of exhaust gas) you are running, period.
You can get boost creep on a TD04, you can get it on a TD06, you can get it on a VVT.
The easiest way to get rid of it is to get a hybrid controller and control your boost more precisely in all gears, or to get an EWG that is large enough and can flow enough gas to keep your boost from getting out of hand.
Going to have to deal with this on my car soon. Gah.
Chi_San is offline   Reply With Quote
Old 11-12-2009, 08:39 PM   #56
bajozzy
Member#: 137556
2011 STI Sedan
nevermind....
bajozzy is offline   Reply With Quote
Old 11-12-2009, 08:40 PM   #57
mysuby
Member#: 166953
i understand the difference between spike and creep, i have creep..it slowly rises as rpms rise..doesnt drop.
i dont really have any money to throw at this problem right now, and i will have the turbo off this weekend....so like was sayin...is this porting of the wastegate hole a good fix too? will it work on mine? i also read a little bit somewhere about lengthening the wastegate arm...? any idea on if that would work as well.? should i do both or one or the other?
Old 11-12-2009, 08:40 PM   #58
Austin
Member#: 7089
2016 STi
False. You certainly may get boost creep on a 2L engine.
Originally Posted by Chi_San View Post
The easiest way to get rid of it is to get a hybrid controller and control your boost more precisely in all gears ...
False.
If your boost controller functions by controlling the wastegate (which it does), then changing controllers will do nothing for you.
If your wastegate is 100% open with type A controller (meaning type A controller is acting to spin your snail as slow as possible), then why would you expect different results by changing just the controller? Type B controller will also open the wastegate 100% - but the amount of exhaust flow bypassing the turbine wheel will be the same, because you have the same wastegate and the same flow dynamics.
Austin is offline   Reply With Quote
Old 11-12-2009, 09:06 PM   #59
Chi_San
Member#: 53558
2002 WRX Wagon
False.
You fail to comprehend my point.
My point was to get something that can be tuned by gear for boost.
Also, if you get boost creep at 22 PSI, but you don't at 20 PSI or less, then you would want to set the boost to 20 PSI (or, if you're smart, 19 PSI for some buffer). If your MBC cannot physically let you set it to 20 PSI, it's either 22 or 14, then what's the point of the MBC?
Edit: Also, if you're using an EBC, and you overboost, you can get into that annoying overboost range. Having a hybrid setup probably would be a good idea then, at least from the Propaganda that I've seen, as they tend not to be so 'boost spike' happy (can you even overboost due to a boost spike?)
Old 11-12-2009, 09:08 PM   #60
mysuby
Member#: 166953
please... can anyone tell me an easy fix for this..... porting the wastegate hole? lenghten the wastegate arm? once again thanks all for the replies? and why the " nevermind"?
Old 11-12-2009, 09:11 PM   #61
Chi_San
Member#: 53558
2002 WRX Wagon
Depends on your setup.
Big turbo? Big power? Don't mind a little more noise? Got a little money? Buy an EWG kit and forget the waste gate in the turbo. Don't forget to get tuned.
No money? Simple, turn down the boost.
Old 11-12-2009, 09:20 PM   #62
mysuby
Member#: 166953
money is pretty tight right now...that why i was asking about the fixes i had mentioned. i dont really have the boost turned up, just a tad over factory,
i have the stock turbo, and no i dont mind noise,, and my next mod i'm planning is a cobb ap just gotta save up some doe
does anyone have any experience with either of the fixes i've mentioned? or that is mentioned at the very begining of this thread
Old 11-12-2009, 09:24 PM   #63
Austin
Member#: 7089
2016 STi
You should probably contact whomever posted at the beginning of this thread...
Old 11-13-2009, 05:59 PM   #64
mplspilot
Member#: 229889
3 ways to fix this:
better WG duty boost control throughout rpm
running higher boost
porting that internal wastegate divider hole
mplspilot is offline   Reply With Quote
Old 08-22-2013, 04:22 AM   #65
jaydnisevil
Member#: 193662
Would be great if somebody could re-upload the images for this..
I've got an STi 2.0 with the VF35 and it's a creepin :P
jaydnisevil is offline   Reply With Quote
Boost CREEP!!!! HELP andrew3776 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-22-2008 01:16 PM
Fuel Cut? Boost creep? Help with stutter phoenix_wrx AccessPort 19 02-04-2008 11:28 AM
Boost creep and Spiking STOCK!!! Help! Helium Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 12-07-2005 02:29 PM
boost creep? need help gmanwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-30-2005 06:21 PM
Boost creep- vets. please help tntmstr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 11-30-2002 04:22 PM
