Old 01-12-2003, 10:38 PM   #1
lukerussell
Member#: 14723
2008 Unlimited AWD
Redline Time Attack Champ
Default guess that noise!
have a turbo xs stage 4 kit. when the car has been running for less than 20 minutes, hard acceleration causes a horrible screeching noise. It happens around 3000 - 4000 rpm, when the car really starts to take off. it sounds like a belt, but can't be, all the visible ones look good. my clutch was suspect before i even installed the stage 4. i had the classic take off shutter it seems a lot of people have. when the screeching starts, it doesn't seem like i'm losing any power or the clutch is slipping. i've tried at low rpm's to get the boost up to see if it's boost related, but the screeching seems to intensify with rpm instead of boost. could an exhaust leak cause this type of noise? any other suggestions? If you think it's a clutch, what a good clutch flywheel combo that won't kill my transmission?
lukerussell is offline   Reply With Quote
Old 01-13-2003, 02:31 AM   #2
air_scooby
Member#: 24243
2002 wrx sportwagon
Default similar sounds
I have a similar problem. I went so far as to install new intake manifold gaskets, up-pipe gasket, new vf-35 (!), tried stock vs. aftermarket intercooler, I am not sure what it is. maybe it is the tranny as you suggest. Why would it whine vs. slip and smell funky?
mmm
air_scooby is offline   Reply With Quote
Old 01-13-2003, 02:59 AM   #3
koloumb
Member#: 28268
2002 WRX Sedan
Have you heard this horrible screeching noise on another car [non-WRX]? Or is it specific to your WRX [and possibly other stage 4 WRX's]?
Since you state it happens when "it really takes off" - what about the turbo itself or surrounding components [IC hose, Turbocharger Intake Pipe,]?
_0wen_
koloumb is offline   Reply With Quote
Old 01-13-2003, 12:52 PM   #4
WRX300
Member#: 17974
uppipe leak at uppipe-header connection...
gasket isnt thick enough and since oem gasket is two pieces of metal sandwiched together you get the same noise as if you blew into a piece of grass held b.w ur fingers. it goes away after 20minutes b.c the leak is small enough that the expansion of the uppipe and header from the heat seal the leak...
irvine subaru (a vendor on the club) sells extra thick gaskets...should cure the problem...
as far as it being rpm or boost related its both...as rpm rises there are more exhaust pules creating the ability to produce more boost as the turbine can spin X speed at Y rpm there is always "extra" exhaust gas that cant be utilized so it leaks out progressively worse as rpm/boost rises
hth
~wrx300
WRX300 is offline   Reply With Quote
Old 01-13-2003, 01:40 PM   #5
lukerussell
Member#: 14723
2008 Unlimited AWD
makes sense, but i can rev it to redline in neutral and it makes no noise, it only does it in gear.
Old 01-13-2003, 01:46 PM   #6
wayoutwest
Member#: 14379
2007 Acura
gray
Thats because the engine is not under heavy load and barely any boost
wayoutwest is offline   Reply With Quote
Old 01-13-2003, 02:56 PM   #7
Oo DaRk StAr oO
Member#: 27208
2001 Widebody MR-S
Absolutely Red
I have the same problem but mine goes away in a few minutes. Its an uppipe leak. Mine seems to seal itself out rather quickly.
Oo DaRk StAr oO is offline   Reply With Quote
Old 01-14-2003, 12:29 AM   #8
air_scooby
Member#: 24243
2002 wrx sportwagon
Default tonight
Yes, I will try to put in the new gasket tonight. I have already (with help from some great folks like Darthchicken and Jeff Sponaugle) replaced the up-pipe turbo interface gasket and the intake manifold gaskets. We just went at it and got them replaced in a hurry. Need to do the bottom gaskets asap though. That squeal is way loud.
Mm
Old 01-14-2003, 09:00 AM   #9
lukerussell
Member#: 14723
2008 Unlimited AWD
i think you're right. i re-torqued all the bolts last night, and it still makes the noise. but now it makes it in nuetral too, just not as bad. i called irvine, they said to use the stock gasket, they don't offer a thick gasket. did you get your gasket elsewhere?
Old 01-14-2003, 11:59 PM   #10
WRX Ver.7
Member#: 18251
1996 Skyline GT-R
Midnight Purple II
WOW!!! I figure that I was the only person that was having that problem. It is driving me crazy. I put all new gaskets in except for the up-pipe to turbo. That could probally be the problem area. It only happens when boost is over 6 psi.
WRX Ver.7 is offline   Reply With Quote
Old 01-15-2003, 01:10 AM   #11
DocDetroit
Member#: 24977
2003 WRX
Are you guys following the proper tightening sequence, and using a torque wrench set at 26 - 30 ft/lbs?
DocDetroit is offline   Reply With Quote
Old 01-15-2003, 01:44 AM   #12
BeavisNuke
Member#: 14981
2002 WRX Sedan WRB
TurboXS Stage 2.5
The graphite gaskets from prestige subaru fixed my leak.
I also left out the two up-pipe/turbo bracket bolts. They supposedly create a pulling effect on the lower flange.
BeavisNuke is offline   Reply With Quote
Old 01-15-2003, 02:25 AM   #13
tuca33
Member#: 24303
2002 Impreza WRX
I need pictures of those TUrbo brackets..
Where do thy connect??
I am installing DP tomorrow morning.
I want to know what they are to let them out.
TUca
tuca33 is offline   Reply With Quote
Old 01-15-2003, 03:00 AM   #14
BeavisNuke
Member#: 14981
2002 WRX Sedan WRB
TurboXS Stage 2.5
I don't have pictures but you'll see them pretty easily.
On the up-pipe to turbo flange, there are 5 bolts total, but only 3 of those actually connect the up-pipe and turbo.
Look around in there and determine which two are going into brackets and not through the actual bolts holes of the exhaust housing turbo flange itself.
Old 01-15-2003, 12:11 PM   #15
tuca33
Member#: 24303
2002 Impreza WRX
Ahhh ,,the brackets wont come loose of the car??
I only will not connect the bolt later on???
Or i will take it off definately?
Tuca
Old 01-15-2003, 04:19 PM   #16
BeavisNuke
Member#: 14981
2002 WRX Sedan WRB
TurboXS Stage 2.5
I just took the bolts off completely and didn't worry about the bracket.
Some people make shims with washers and put them in the bracket bolts to space it out more but I never wanted to have to get to the up-pipe again.
Prestige gaskets + bracket bolts was the winning combination for me. Been about 2.5 months/4k miles now without any signs of a leak.
Old 01-15-2003, 07:27 PM   #17
Kudagra
Member#: 19864
2006 B9
Obsidian Black Pearl
Damn I also thought I was alone in this..I was getting so fed up with it that I was actually willing to take it to a dealer if I didnt get any anwsers here.
This is the gasket on the BOTTEM of the Up pipe correct?
I had an Up-pipe I got from some one in the Private parts for sale section, an Exhaust Depot Down Pipe and a AEM cold air Intake. I got tired of the noise and constant exhaust leaks when I used the Irvine Subaru graphite gaskets( 3 times on that lower flange), so I just put it back to stock (Used the original gaskets)and am more then happy with it...till this noise came along..and its really pissing me off...Someone fix this and let me know if it works.
Proper tightening sequence?? WHat is the sequence?
Kudagra is offline   Reply With Quote
Old 01-15-2003, 07:49 PM   #18
BeavisNuke
Member#: 14981
2002 WRX Sedan WRB
TurboXS Stage 2.5
The proper way to install the up-pipe is to tighten the two bolts on the LOWER flange (manifold/up-pipe) first. I believe it's 26 foot pounds.
THEN tighten the upper bolts. (turbo/up-pipe)
Old 01-16-2003, 01:46 AM   #19
air_scooby
Member#: 24243
2002 wrx sportwagon
Default the squeal is gone
fixed.
check the 02 sensor.
check the gaskets on each end of the up-pipe.
it was one of these that fixed the squeal, I think it was the 02 sensor (having an 02 sensor socket helps out a lot.
mitch
Old 01-26-2003, 01:16 AM   #20
ellinopedo182
Member#: 11160
2002 Impreza WRX
WR BLUE 4EAT
oMg! im not the only one with this noise. i have the same exect symptoms! the car starts to squeel. it isnt as loud inside as it is outside. whenever i pass with rpms somewhat up there and boost somewhat over 5psi, there is an annoying screaching noise that just sounds horrible. well, to me. my friends like it, but im starting to feel loos of throttle response and it seems slower. it could also be me being all scared thats making me think that my car is actually slow. anyhow... im getting new gaskets and gonna have someone reinstall the gaskets with my aftermarket turboxs uppipe. hope that works!!!!!!
ellinopedo182 is offline   Reply With Quote
Lets guess whats that noise? J-Chow Normally Aspirated Powertrain 5 05-16-2010 10:51 AM
lets play guess the noise seanvetter123 Brakes, Steering & Suspension 8 05-10-2009 04:07 AM
Lets play guess the noise and smell (from my car) adam555 New England Impreza Club Forum -- NESIC 10 05-26-2005 11:46 AM
Whats that noise? Its a funny booming noise SubeDonC Tri-State Area Forum 3 03-09-2003 01:28 AM
What's that noise? Anyone else hear that noise? GreenRS New England Impreza Club Forum -- NESIC 16 06-24-2002 06:26 PM
