Old 04-29-2001, 12:09 AM   #1
BlueRidgeRS
Member#: 1953
2002 WRX SportWagon
Platinum Silver
Post Compression test
Bought a compression tester kit and these are the numbers I got:
Cylinder #1 - 205 psi
#2 - 205 psi
#3 - 215 psi
#4 - 220 psi
They seem high to me but this is my first Subaru so this might be normal. I have a Maxima SE and all cylinders came up around 173 psi. V6 vs. H4 might explain the big difference. The engine is stock except for a K&N drop-in filter. It's got over 10K miles. Has anyone else done a test like this?
BlueRidgeRS is offline   Reply With Quote
Old 04-29-2001, 12:50 AM   #2
jhuang76
Member#: 1284
2005 Legacy GT
Royal Blue Pearl
Post
I want to state that I've never ran a compression test (seen it done as a bystander).
How many miles does your Maxima SE have? 10K for an engine is nothing (esp. a Subaru one which is pretty tight in the first place) and I'd expect it to have a very small leak.
As a rule of thumb, your pistons will leak more as the engine gets older (see more miles).
jhuang76 is offline   Reply With Quote
Old 04-29-2001, 03:50 PM   #3
BlueRidgeRS
Member#: 1953
2002 WRX SportWagon
Platinum Silver
Post
The Maxima has 176K miles on it. Chilton's service manual for the Maxima states the 173 psi is the max for this engine.
I basically did the test to get a baseline of a fairly new engine. That way I'll know if it's leaking and also see how the engine is wearing over time.
Old 04-30-2001, 09:07 PM   #4
SubyTechMaster
Member#: 4423
'04 08 Tribeca, SVX
Gold, Maroon
Wink
If your RS is a Phase I or Phase II motor the Spec. from Subaru is 185psi @ 350RPM. Since you are over that spec., you are probably spinning much faster.
SubyTechMaster is offline   Reply With Quote
Old 05-01-2001, 03:01 PM   #5
BlueRidgeRS
Member#: 1953
2002 WRX SportWagon
Platinum Silver
Post
I've got a MY00, so are the results normal? And why are cyl. 3 & 4 higher than 1 & 2? Shouldn't they all be uniform?
Old 05-01-2001, 06:03 PM   #6
SubyTechMaster
Member#: 4423
'04 08 Tribeca, SVX
Gold, Maroon
Post
Yes, even the lowly '99 with only 9.7/1 compression has the same specification.
General rule is you want all the cylinders to be within 10% of each other. There are too many variables to affect compression; speed the motor is cranking, carbon build-up, oil in cylinders, fuel in cylinders, etc.
If you are really concerned about low compression, the next step would be a wet compression test or take it to an experianced Technician.
You can't compare figures with a differant kind of motor or even differant year/same motor. A V6 Nissan has less compression and more friction, it spins slower.
The purpose of this was a baseline. Go enjoy your car and put another 10,000 miles on it and check it again. Make sure you note as many variables as you can think of; Engine temp, oil viscosity, battery health, etc.
Old 05-02-2001, 01:46 AM   #7
Thug
Choke Artist
Member#: 603
Post
But the MY00+ supposedly have 10:1 compression. So it would be higher than a '99 on a compression tester.
Thug is offline   Reply With Quote
Compression Test Results. OK? Dane509 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 06-02-2010 04:27 PM
Recommonded Shop for Compression Test and Leak down test? stook2003 Vancouver Impreza Club Forum -- VIC 0 07-02-2007 05:20 PM
Odd compression test and leakdown test numbers SloRice Built Motor Discussion 10 11-13-2006 11:07 AM
What the compression test and leakdown tests SPEC for 05 STI hilfiger4you Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 12-25-2005 05:43 PM
Compression Test vs. Leak Down Test dug-e-fresh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 08-17-2002 12:42 PM
