Old 04-29-2001, 04:41 AM   #1
NA Impreza
Member#: 4267
1999 rs
white
Question is my clutch slipping or......?
or is it just me driving bad? recently when i lauch uphill i sometimes get this fairly violent shake....it "feels" like wheel spin or something but i'm sure its not wheel spin...it's like something is slipping which makes me think if it's the clutch....this scenario is hard to imagine but i hope others with the same problem can help me here...thanks
NA Impreza is offline   Reply With Quote
Old 04-29-2001, 05:26 AM   #2
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Post
If the clutch slips, then the tach would speed up as you step on the gas but the speed does not change. So, it's almost like putting the into neutral.
I would think that it's the clutch that's trying to engage at harder force, thus shaking the car. Not sure until I can exactly feel what you're talking about though.
tmat3 is offline   Reply With Quote
Old 04-29-2001, 07:52 AM   #3
tonytiger
Member#: 3844
1993 Legacy 1.8
Talking
I think I know what you're meaning, I have had the shake with my launches too. It happens when lifting the clutch too carefully with a little gas. I don't think mine clutch is malfunctioning. Maybe it's the same with your case. Just give it a little bit more gas and take the clutch all the way up relatively fast. Watch out for the tires to slip
tonytiger is offline   Reply With Quote
Old 04-29-2001, 03:31 PM   #4
jhuang76
Member#: 1284
2005 Legacy GT
Royal Blue Pearl
Post
Does this seem to occur more often when the car is just warming up (within 10-15 minutes). I've always had an annoying clutch shutter, worse when cold and damp. From the other i-clubbers, they suggested it's due to condensation on the clutch face.
Joe
jhuang76 is offline   Reply With Quote
Old 04-29-2001, 07:10 PM   #5
Memnoch
Guest
Member#:
Post
Do a search for clutch shudder or clutch chatter and you'll find everything you want to know. It's fairly common.
Old 04-29-2001, 10:19 PM   #6
oldpreza
Member#: 5259
1995 Impreza
Post
This was out of the workshop service manual.
to test if u got a slip:
1. Engage parking brake all completely.
2. Step on clutch.
3. Shift into 5th gear.
4. Slowly release clutch until the "bite" point.
5. If it stalls immediately, it's not slipping.
oldpreza is offline   Reply With Quote
Old 04-30-2001, 12:53 AM   #7
NA Impreza
Member#: 4267
1999 rs
white
Post
yeah....it happens when i "try" to be smooth without giving too much gas....thanks for the advice
Is my clutch slipping? or something else? Jncominco2 Rocky Mountains Impreza Club Forum -- RMIC 37 04-29-2009 03:10 PM
HELP is my clutch slipping? CHwrx Transmission (AT/MT) & Driveline 30 10-16-2006 07:28 PM
Look at these logs...is my clutch slipping? quickscooby Proven Power Bragging 11 03-06-2006 01:37 PM
is my clutch slipping gsteclipse33 Transmission (AT/MT) & Driveline 5 04-30-2005 12:43 AM
is my clutch slipping? aznfoos Transmission (AT/MT) & Driveline 1 11-03-2004 11:12 PM
