Old 04-29-2001, 10:48 AM   #1
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
1998 Forester, lifted.
Post Safe horsepower level's with stock tranny (5spd)
What could I do to my scooby without blowing my transmission up? I was considering keeping it N/A but a small turbo could be in the future or a supercharger perhaps.
Old 04-29-2001, 11:41 AM   #2
Longshot
Member#: 2359
2001 Impreza 2.0 WRS
Post
210 ft-lbs of torque is a general consensus of what the stock clutch can take, after that getting an ACT clutch will keep the car going for a bit longer, if you're planning on going past 300 ft-lbs.. you may wanna think about a better transmission anyways.
This is all stuff on the RS which you have I dunno what the WRX can handle.
Korey
Longshot is offline   Reply With Quote
Old 04-29-2001, 03:41 PM   #3
Tony
Member#: 287
2005 9-2X Aero
Desert Silver
Post
Clutch holding torque aside, most tranny problems with big horsepower are due to poor shifting techniques by the driver. The tranny can take a lot but even at stock power levels a ham-fisted (or rather footed) driver can blow it up. Do a search on "shifting techniques", there's plenty of info out there on double-clutching, heel-toeing, etc.
Tony
Tony is offline   Reply With Quote
Old 04-29-2001, 03:50 PM   #4
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
95 993 C4, 71 911, 04 STI
Post
Great stuff here: www.spdusa.com/shifting.htm
Jon Bogert is offline   Reply With Quote
Old 04-29-2001, 03:52 PM   #5
tom@kartboy
Member#: 67
1999 Outlasting
the competition.
Post
huh.. i guess i need to learn how to drive then
tom@kartyboy.com
Old 04-29-2001, 04:19 PM   #6
Tony
Member#: 287
2005 9-2X Aero
Desert Silver
Post
Maybe, how did your's go? Very few tranny failures I've seen/heard about were from the tranny just "letting go" while in gear. Most failed while shifting into second and are a shock failure rather than a torque failure. I bet if people didn't hurry the 1-2 shift (also the largest % gear change) there wouldn't be 90% of the failures out there.
Tony
Old 04-29-2001, 04:25 PM   #7
Rivenoak
Member#: 6175
Post
Depending on how much time and money you're willing to invest, and how long you intend to keep your car would be the best starting info to answering your question.
You don't sound serious about real power. I suggest two courses of action based on your post.
1.) Minor bolt-ons, tires, and lie alot.
2.) Decide you may need 3x the proposed
budget & 3x the maintenance and go for
real power.
Rivenoak is offline   Reply With Quote
Old 04-29-2001, 04:33 PM   #8
Tats
Member#: 5692
WTF? YES! I am
better than you!
Post
From what I hear, trannies have problems when there is too much torque. You can have 400+hp and honda like torque figures and still be totally safe. But as soon as you seriously up the torque the tranny has problems holding together. And as we all know.....us scooby owners LOVE our torque!
Tats.
Tats is offline   Reply With Quote
Old 04-29-2001, 04:51 PM   #9
Thug
Choke Artist
Member#: 603
Post
RalliSpec even said that almost all turbo'd RS tranny failures were due to shock, not too much HP. So just dont slam 2nd and you should be OK. If you're blowing 3rd gear, you've got more problems than we need to get into.
Thug is offline   Reply With Quote
Old 04-29-2001, 10:10 PM   #10
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
Post
So from what you guy's are saying I can keep the stock tranny safe as long as I don't abuse it (rarely do I abuse it) also would wrx like power be O.K ?
How many of you have stage 4 WRXs with stock tranny? EVOTHIS Transmission (AT/MT) & Driveline 17 10-09-2005 01:32 PM
2.5 block swap with stock tranny?? K2Skier Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 08-13-2005 04:22 PM
Is the AP safe to run with stock injectors and fuel pump on an STi? Irishman Engine Management & Tuning 5 08-30-2004 02:10 AM
Stage 4 With Stock Tranny mikeg313 Transmission (AT/MT) & Driveline 9 05-29-2003 11:04 PM
So if EJ25 is torquey enough to mess with stock tranny Caddy Daddy Normally Aspirated Powertrain 23 11-14-2002 05:24 PM
