Old 01-13-2003, 01:00 AM   #1
Hawk296
Member#: 14555
1995 Impreza L
Baja
Default ignition coil wires
Anyone have a wire diagram they could scan for a 95 Impreza L 1.8 liter?? I need the wiring diagram for the engine. I need to see where each of the three wires from the coil go to. I have manuals for all models 99 and 2000 and 2002 impreza, but i do not have one for my car, a 95 If someone has one that they could easily scan a page off of that would be awesome, otherwise oh well. thanks a lot.
Hawk296 is offline   Reply With Quote
Old 01-13-2003, 03:06 PM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
One is a 12 volt lead and the other two are the trigger. They eventually lead to the ignition module, which on the 2.2 legacy lives right in the center of the firewall.
What are you wanting to do? The reason I could see you asking is for an upgraded ignition.
Im running an MSD DIS-2 currently on my 2.2l
Old 01-14-2003, 12:49 AM   #3
Hawk296
Member#: 14555
1995 Impreza L
Baja
Which one is the 12 volt lead and which wires are which triggers?
Old 01-14-2003, 02:57 AM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
If you look on the plug it has three wires. If you look close to the coil you have two wires for the 1-2 coil and two wires for the 3-4 coil.
The wires that are the same color on the coil come together and connect to the middle plug (I think). This is the 12 volt switched (with ignition).
Old 01-14-2003, 02:31 PM   #5
Hawk296
Member#: 14555
1995 Impreza L
Baja
Awesome, thank you. I will check this out today.
Right ignition coil wire for tach sense on STi? BritSti Electrical & Lighting 8 11-10-2009 08:48 PM
WTB: WRX/STI ignition coil wiring suberdave Private 'Wanted' Classifieds 1 11-15-2008 01:46 PM
DPR Headquarters releases Ignition Solutions direct replacement ignition coils. DPR Racing Int. Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 05-22-2005 08:36 PM
4 Wrx Coils, Ignition Coil Packs, navyissuesuby Private 'For Sale' Classifieds 16 03-05-2005 02:07 PM
Need to identify right ignition coil wire for tach sense BritSti Car Audio, Video & Security 2 02-09-2004 07:10 PM
