Old 04-29-2001, 02:28 PM   #1
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Post What does "closed deck" mean?
I have been researching different STI engine and it is said that the version three is a much better design because of its "closed deck"? What does this mean and how does it make the engine work better.
Which is your favorite STI engine?
Thanks
Brad
MY99 2.5GT is offline   Reply With Quote
Old 04-29-2001, 02:39 PM   #2
S.Damery
Member#: 1770
Post
Brad,
Here's a picture of a closed deck Subey (courtesy of Cobb Tuning
<IMG SRC="http://www.cobbtuning.com/images/ct-closed-deck.jpg" border=0>
And heres an open deck
<IMG SRC="http://www.cobbtuning.com/images/sohc-engine05.jpg" border=0>
A closed deck is more rigid and will hold up better under stress. The free standing sleeves of the open deck engine are prone to moving around when the engine is under severe stress (i.e. using high turbo boost/ high rpms.) Hope this helps.
-Shawn
S.Damery is offline   Reply With Quote
Old 04-29-2001, 03:07 PM   #3
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
Post
Note that the new Subaru WRC car (and the STi v7?) use a semi-closed deck rather than a fully closed deck. I've read that the closed deck inhibits cooling, hence the switch to a different design that provides cylinder support and allows better coolant flow.
bsquare is offline   Reply With Quote
Old 04-30-2001, 02:16 AM   #4
Jay_UK
Member#: 296
Post
Can some please tell me how a closed deck block inhibits coolant flow ?
The passages in the head where the coolant flows into, are the same size as the passages in the closed deck.. so making them larger (open) wont yield anymore flow between the two.
J.
Jay_UK is offline   Reply With Quote
Old 04-30-2001, 05:22 AM   #5
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
Post
Thanks for your replies. Does anybody know where I can get a closed deck block like the one pictured above?
Thanks
Brad
Old 04-30-2001, 05:28 AM   #6
Cacophony
Member#: 213
2004 Mazda RX-8
Post
Yeah, ther Ver. III's had closed deck blocks, but the newer, phase 2 STi motors had much improved bottom ends.. take your pick. I went with a Ver. V RA
Cacophony is offline   Reply With Quote
Old 04-30-2001, 06:23 AM   #7
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
Post
What change caused the ver 5 to have much improved low end power? Is there any way to modify the closed deck ver 3 motor to produce better lower end? Maybe better exhaust, better header??
Old 04-30-2001, 07:41 AM   #8
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Jay-- closed deck won't lower coolant flow but it does reduce the volume of coolant in the head. As you know the way coolant relieves heat from the engine is to receive heat from it by contact and carry it to the radiator to be cooled off. ...One would suspect that with less coolant in the block there is a lessened ability to absorb heat.
ColinL is offline   Reply With Quote
Old 04-30-2001, 10:03 AM   #9
Cacophony
Member#: 213
2004 Mazda RX-8
Post
When I referred to "bottom end" I meant the block assembly, not a part of the overall powerband. I'm just having a partial brain stall and can't remember exactly what differs between phase I and phase II blocks
Old 04-30-2001, 10:12 AM   #10
Really_Soaked
Member#: 4992
2000 Impreza 2.5 RS
Blue Ridge Pearl
Post
Check with Trey Cobb, they can sell you a closed deck block.
-Simon
Really_Soaked is offline   Reply With Quote
Old 05-01-2001, 10:41 AM   #11
mhj
Member#: 3057
Post
Or, if you want a brand new closed deck block, order the Legacy Turbo 2.2L block. Unconfirmed rumors say it costs about $1000 for the short block (block+internals, no heads) from subaruparts.com. Get some stronger rods, higher compression pistons (maybe), and some 2.5RS heads,(plus manifold, water & oil pumps, etc.) and you got a high boost monster motor.
edit: open deck opinion below
I think the only advantage to open deck blocks is that they are cheaper to manufacture. They use a mold that can slide out of the water jacket rather than a sand cast mold.
[This message has been edited by mhj (edited May 01, 2001).]
mhj is offline   Reply With Quote
