Old 01-13-2003, 03:57 AM   #1
Kwyjibo
Member#: 17851
2003 WRX
R.I.P. 7.27.2005
Default Easiest place to tap for Oil Pressure guage.
I got an Oil Pressure guage and am feeling a bit lazy about removing the intercooler to get to the good spot to tap.
So, is there an easier spot to get to that doesn't require to much work.
I won't be running enough mods to warrant the preciseness(sp?) of the spot under the intercooler...my autometer pod had an extra oppening and I needed a guage to put in there
I just basically want to know if I lose all of my oil...
Besides if i'm gonna take out the intercooler I may as well put in some samco or perrin hoses....and I really don't want to have to spend that extra cash...
thanks in advance.
Kwyjibo is offline   Reply With Quote
Old 01-13-2003, 04:17 AM   #2
teiva-boy
Member#: 22825
My good guru friend Austin told me that you can order a plug from subaru that would fit my Greddy oil sensor. Perhaps it's the same for autometers? You would put this in the location under the intercooler. He also suggested that you could take out the factory plug under the intercooler and drill and tap it to the correct fitting.
IIRC the Subaru plug cost me $10 and change.
#11024AA210
teiva-boy is offline   Reply With Quote
Old 01-13-2003, 05:03 AM   #3
swan
Member#: 31621
white
Another option is to replace your current sender with a two port sender - one to the ECU and another to new gauge - if you go the electric gauge route of course.
swan is offline   Reply With Quote
Old 01-13-2003, 08:45 AM   #4
Bernie
Member#: 10730
02 WRX Sportwagon
91 300ZX Twinturbo,StgXII
yes, do as tevia-boy suggested. remove the plug and replace it with the pretapped one. it is very easy to remove the existing plug without removing the intercooler. simply get a hex bit with a long extension and maybe a swivel somewhere in there and you can unscrew it easily. or, you can just use a regular hex key/allen wrench, insert the short end into the end of a box wrench, tape it in place, and then simply use another wrench or vise grips on the open end of the box wrench to turn the whole deal.
Bernie is offline   Reply With Quote
Old 01-13-2003, 09:09 AM   #5
Zola
Member#: 16876
2002 Impreza WRX
WR Blue
Removing the intercooler takes about 2 minutes. Are you really that lazy? Anyway, I thought that was the most convenient spot so it's where I installed mine.
Zola is offline   Reply With Quote
Old 01-13-2003, 09:19 AM   #6
MisterX
Member#: 17275
2002 wrx wagon
wr blue
Why are people afraid to remove the intercooler? It literally can be done in less than five minutes. The only problem is reinstallation with the plastic, stock hose. Samcos make the reinstallation much easier, but even with the stocker, it isn't that bad.
Russ
MisterX is offline   Reply With Quote
Old 01-13-2003, 12:00 PM   #7
Kwyjibo
Member#: 17851
2003 WRX
R.I.P. 7.27.2005
Well, my licence plate is a derivation of Hate To Walk...you be the judge
I have the bolt on order thru my local dealership with the crush washer...i guess ill go pick it up today and take a closer look at the intercooler.
thanks guys
Old 01-13-2003, 03:16 PM   #8
gordon
Member#: 27665
'02 WRX wagon
WR blue
Forgive me, I'm a little slow - does this disable the factory oil pressure sender?
thanks,
g
gordon is offline   Reply With Quote
Old 01-13-2003, 03:18 PM   #9
Zola
Member#: 16876
2002 Impreza WRX
WR Blue
thanks,
g
No, the factory oil pressure sender is in another plug closer to the front of the car...I think it's under the alternator.
Old 01-13-2003, 05:27 PM   #10
Bernie
Member#: 10730
02 WRX Sportwagon
Russ
Why do it if you don't need to? Even if you can take it off in 5 and put it back on in 5, if you leave it on, that's 10 minutes off your install time... lol.
Where to tap for oil pressure gauge? joltdudeuc Normally Aspirated Powertrain 9 04-11-2006 09:46 PM
ideal place to tap for boost reading R.C.Y.K. Electrical & Lighting 6 11-17-2003 04:04 PM
Best place (WRX) to tap for a pressure switch? rwroth Factory 2.0L Turbo Powertrain 1 07-16-2002 04:38 PM
Is this ok place to tap for boost pressure reading Fubaru Factory 2.0L Turbo Powertrain 18 01-06-2002 10:53 PM
Here is the best place to tap for a Boost Gauge....(big pics) Jimmy S. Factory 2.0L Turbo Powertrain 16 12-15-2001 04:22 AM
Message Board Statistics All times are GMT -4. The time now is 07:28 PM.
