Old 01-13-2003, 04:38 PM   #1
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Default CELS, do you clear them or fix the error and they disappear?
Okay, the way Ive understood subarus Check Engine Light scheme was the following.
Error detected, no CEL
Error continues or repeats x times, Cel illuminated
If error was constant for a long time but stopped Cel go's out and code is stored
If error was repeating cel will go out until the error happens again, code is stored
Cel will NOT illuminate if old codes are stored but not currently active
Now I have heard many people talk about "clearing codes" and pulling the battery terminal to turn the CEL off. From all the knowledge I have gained I always knew this to not apply to subaru.
Basically what Im asking is if Im right in the belief that the CEL will illuminate ONLY when the problem is occuring, not afterwards. The only thing CLEARING CODES does is get rid of non active codes currently stored.
Old 01-13-2003, 06:11 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
basically there two types of codes.
hard faults
and non-hard faults.
a hard fault, is set, it can only be cleared after the problem has been fixed.
ie your maf sensor is on the fritz, the ecu will set a code, if you attempt to disconnect the battery or clear with a scan tool, the code will come right back as soon as you start the car because it is a hard fault.
non-hard faults or intermittent problem, will illumanate the cel when the problem is occuring, if the problem goes away, after a certain number of 'drive cylces' without the ecu seeing the fault again, the code will be stored in memory and the cel will be go out.
when you disconect the battery you will clear the ecus memory in turn clearing all intermittent fault codes stored.
you are correct in that a fault must occur on obdII vehicles IIRC 5 times before the cel is tripped, untill that time the codes will be 'pending' and most scan tools will let you see what codes are pending.
there is more too it, but thats basically how it works. Emmission system codes will trip the cel and it will stay illuminated, untill cleared....like evap codes set due to leaving your car running while filling up.
thats about all I can think of now, im sure jeremy will pop in and maybe be able to correct me if im wrong as my memory isnt great... eheh
Jay McDade
Lincoln/Mercury/Jaguar Tech.
Old 01-13-2003, 07:01 PM   #3
ciper
Member#: 15543
90BJ Legacy LS ABS
Thank you. So in short disconnecting the battery is not the correct method to turn the CEL off.
Old 01-13-2003, 07:37 PM   #4
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Depending on the type of code......as he said, if it's a non-hard fault. Disconnecting the battery will clear it.
It's probably not the most appropriate way, but it does work for those particular types of codes.
I've done it.......granted OBD1 is slightly different then OBD2.
Legacy777 is offline   Reply With Quote
Old 01-13-2003, 07:50 PM   #5
Karl
Member#: 13110
If you have a CEL, you probably would want to know what it is before you clear it anyway. If you don't have a scan tool of your own, Autozone will pull codes for you.
Karl is offline   Reply With Quote
Old 01-13-2003, 10:55 PM   #6
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
no not the correct method because your clearing the entire ECUs memory including its adaptive stradgey. (over time your ecu will learn, it will learn what type of gas you use, as parts wear it will learn to compansate for that as well, etc etc.)
All this it will have to re-learn, usually giving you bad gas mileage and poor performance untill it re-learns.
will it work yes, is it the best method, no.
Jay
Old 01-21-2003, 02:29 PM   #7
xzchaos
Member#: 32051
How long should it take for the ECU to re-learn? Also, if you were to get a misfire code and left the CEL on while still driving, would this CEL put the ECU into a "safe mode"?
xzchaos is offline   Reply With Quote
Old 01-23-2003, 06:20 PM   #8
romoranger
Member#: 14701
94 camaro
big cam/heads/slicks
how or where do you get these scan tools of your own?
romoranger is offline   Reply With Quote
Old 08-06-2005, 07:55 PM   #9
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
I've disconnected my battery several times for a few minutes and my codes stay. I have one thing that will cause a code and it's my egr temp sensor. The only reason it causes a cel is because I haven't threaded the 2.5 intake for it yet and it's tied to a cable temporarily. I still have two other codes for my idle control valve and throttle position sensor. Their cels were on because I accidentaly cranked the car with them disconnected. Now that they are connected, the code will not erase from memory. I am going to leave the battery disconnected with the parking light switch on for thirty minutes this time. My ecu is a 1995 OBD1 for a 1.8l. Hope it works.
2slofouru is offline   Reply With Quote
Old 08-06-2005, 09:53 PM   #10
2slofouru
Member#: 90539
95 L with ej257k
powa, Raven R6
Default 45 minutes did the trick
Yay it worked! This time I left the battery disconnected for about 45 minutes and voila, no more codes. I even drove it for about ten minutes and no cel! When I got home, I checked for any codes and none were stored. Apparently I can't just "disconnect the battery and push the brakes a few times", it takes a little longer (on my model anyway).
Old 06-03-2016, 08:23 AM   #11
jdicapua
Member#: 448168
2002 Legacy gt BE
01X ( white frost pearl)
Default P0065 02 lgt
If I'm throwing the false code p0065 and I've replace the sensor and the code is still on do I have to clear it with the scanner
jdicapua is offline   Reply With Quote
Old 06-03-2016, 08:51 AM   #12
quazimoto
Member#: 70395
Yes.....and if the DTC comes back it was not the sensor that was the problem.
quazimoto is offline   Reply With Quote
Old 06-03-2016, 11:59 AM   #13
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Auto Parts Stores, Amazon, etc.
Samurai Jack is offline   Reply With Quote
Old 06-08-2016, 07:25 PM   #14
hotdog
Member#: 197520
2015 WRX
This thread is of legal age in Kentucky.
hotdog is offline   Reply With Quote
on the highway, do you pass cars, or pass them UP? Matt K Off-Topic 34 02-17-2008 04:02 PM
People with kids, or people planning to have kids, How do you punish them? brucelee Off-Topic 65 09-21-2007 02:03 AM
DC's Pro Spec 1.0...Now That You Own Them, How Do You Like them? skimobile Motorsports 7 07-16-2007 04:44 PM
do you dodge bullets, or do they dodge you? Handsdown Off-Topic 3 05-19-2006 07:28 PM
How do you clear a CEL? Sordid Philosopher Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-31-2002 03:10 PM
