Old 01-14-2003, 10:53 AM   #1
McGuyver
Member#: 8834
2010 Forester
Default 22mm vs. 22-24mm adjustable front sway bar
I'm thinking about adding a new front sway bar to my 2.5RS and I have a question - is the adjustable 22-24mm front sway bar worth the extra money? I have a 2002 model that I run in GS on Kumho E700s.
The cost difference between the 22mm bar and the adjustable 22-24mm is about the same as a set of mud flaps. It snowed again today and my doors look like terrible covered in all the black slushy goo.
Thanks for the help.
Chris
McGuyver is offline   Reply With Quote
Old 01-14-2003, 11:06 AM   #2
Draken
Member#: 16
1968 Saab
Sonett II V4
I don't have experience with the adjustable bar. Also, I have a '99 2.5RS, so my results might not be of help.
I run the 22mm MRT front bar. I like it quite a bit. I'm not sure I would need anymore though.
Chris H.
www.subrew.com
'99 Subie 2.5RS (G-Stock)
Draken is offline   Reply With Quote
Old 01-14-2003, 11:32 AM   #3
ITWRX4ME
Member#: 24472
2001 Miata
There's been a lot of debate about the use of a front sway bar in the Suspension forum. The problem is that Imprezas understeer pretty badly. Most people correct this with a rear sway bar. Adding the front sway bar(assuming you have a rear bar) could make the car understeer again, only flatter.
If you have a rear sway bar, you probably won't need the adjustable bar.
My .02
ITWRX4ME is offline   Reply With Quote
Old 01-14-2003, 12:51 PM   #4
McGuyver
Member#: 8834
2010 Forester
Unfortunately, changing the rear sway bar is not an option if I want to stay in Stock. I understand that understeer could be an issue but right now my biggest problem is the wallowing of the front end (the other guys in the region call my car the S.S. Impreza - I've had people get car sick when riding along during a run) so I'm willing to risk that in order to increase the responsiveness to turn inputs and reduce some of the front roll.
Chris
Old 01-14-2003, 01:12 PM   #5
zzyzx
Member#: 815
2013 Boss 302 White
2008 S2000 CR ABP
A larger front bar will nonetheless induce copious amonts of understeer when you need it least...
Go with the cheaper bar since you probably won't have it on for long...
- Steve
zzyzx is offline   Reply With Quote
Old 01-14-2003, 02:58 PM   #6
Draken
Member#: 16
1968 Saab
Sonett II V4
With my G-Stock setup on my '99 2.5RS, I did not find any increase in understeer when going from the 19mm to the 22mm front bar. By keeping the car flatter, there is less camber loss during hard cornering, letting the tires work a bit better.
In fact, I found turn-in sharpened up a bit, and the car actually came off the corners with a bit less on throttle push. This is not to say I don't have some understeer, but with proper tire pressures, shock settings and rear toe settings, I have learned to dial a lot of this out.
I was mildly competitive last year on the national scene in G-stock with what I consider to be a very basic setup with off-the-shelf parts.
Chris H.
www.subrew.com
Old 01-14-2003, 06:33 PM   #7
Templar
Member#: 483
2010 RSV4
Aprilia Racing Black
I am currently, and have been running for over a year on a 25mm front and 24mm rear sway bar settup. I have NO understeer. As a matter of fact it is quite easy to induce throttle oversteer with this settup. There is also a local Legacy driver who has had fantastic results with a 25mm front bar and 22mm rear. I also know of several other Imprezas with 22mm on the front that they are extremely happy with.
This is on a MY00 2.5 RS.
I even had the rear sway bar mounts break once during an autocross and didn't know it until the event was over. Even then the car was only mildly pushing.
Our best guess as to why this is, is that the larger front bar keeps the mass, and therefore the weight, from transferring outward in the turn.
Templar is offline   Reply With Quote
Perrin 22 mm adjustable front sway-bar with endlinks and bushings gling Tri-State Area Private Classifieds 1 05-28-2008 08:33 AM
FS in CT: Perrin 22 mm adjustable front sway-bar with endlinks and bushings gling NESIC Private Classifieds 2 05-28-2008 08:33 AM
WTB: Perrin or Whiteline 22 mm Adjustable Front Sway Bar sr20dehauler TXIC Private Classifieds 0 08-23-2007 11:33 AM
WTB: Perrin 22 mm Adjustable Front Sway Bar sr20dehauler Private 'Wanted' Classifieds 0 08-08-2007 11:24 AM
PERRIN 22 mm adjustable front Sway Bar low miles 75$+shipping sekretskwirl Suspension/Brakes/Handling 8 03-09-2007 06:09 AM
