Old 01-15-2003, 01:42 AM   #1
aspera
Member#: 7879
Default anyone heard of an anti-lag system that injects air into the exhaust?
I was reading a British car magazine at the book store. There was a Celica GT4 homologation car that had this hidden feature. Ever heard of it?
[expecting John Felstead to answer first]
aspera is offline   Reply With Quote
Old 01-15-2003, 03:59 AM   #2
aspera
Member#: 7879
All I can find out is that newer WRC cars use some kind of ALS+EGR. This EGR must be different from emissions EGR.
I also read that some Mistubishis inject fuel into the turbo!??
Old 01-15-2003, 04:56 AM   #3
aspera
Member#: 7879
Default BINGO!
Old 01-16-2003, 01:44 AM   #4
Subayai WRX
Member#: 18589
2002 WRX, Formerly
it was blue
Use of the old "air-pumps", or air-injection was common on mid sixties and later cars to get the unburnt air-fuel mixture that leaves the combustion chamber to burn completely. Actually I should say that it was required on all California cars to pass California's tougher emissions regulations. The down side of this system was the slight HP drain from another accessory driven belt pump, and premature exhaust valve wear due the allowing the combustion process to occur on escaping exhaust gases.
My old '66 Mustang was just one victim of the air-injection systems. First thing most people did was plug the holes in the manifold (leaving the lines running to them), and then removing all the vanes from the rotary air pump.
From the description given in the link I would suspect that they are simply re-directing the pressurized air, rather than to atmosphere (like most of the factory BOV's do), and re-directing it to the exhaust inlet stream of the turbo compressor to keep the air flow up, hence the impellor RPM's. But this is only my speculation.
Subayai WRX is offline   Reply With Quote
Old 01-17-2003, 01:45 PM   #5
aspera
Member#: 7879
Default detour around the engine to create a jet engine
...so compressed air from the turbo basically "goes around" the engine, and straight into the exhaust. This air is supplied from the BOV when the throttle plate is closed.
That seems like a good way to use otherwise wasted air.
The more modern Anti Lag System that I've read about uses the ECU to retard timing and add fuel. I've also read about a "kicker" that keeps the engine above 4000RPMs or so.
It seems like there are many versions of ALS. I wish somebody would explain them, but they're probably racers' secrets.
Anyone interested in an Anti-lag system? TurboSetch Alaskan Impreza Club Forum -- AKIC 26 04-27-2009 04:38 PM
anyone heard of an 09 sti in vegas??? RGV_wagon News & Rumors 39 06-13-2007 10:31 PM
Anyone heard of an RC injector failing? 8Complex Normally Aspirated with bolt-on Forced Induction Powertrain 10 04-22-2003 10:16 PM
Anyone heard of an LPO Lease? auricom General Community 11 12-06-2002 07:12 PM
Anyone Heard Of An Improper Fuel Pump Install Causing Car To Explode? the Dabbler Normally Aspirated with bolt-on Forced Induction Powertrain 18 08-11-2001 12:46 AM
