Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 01-15-2003, 02:42 PM   #1
Quick WRX
Member#: 19689
2002 GDA TXS stg 4+
280 whp
Default Flashing CEL vs. Solid CEL
I have had my TurboXS stg 4+ in for about a 2weeks now and have gotten 5 CEL's. They have all gone away after a day. I have no way to pull the code (I am working on that). My question is some CEL's flash some are solid, is there a differance? Also some last 10 min and some last a day, is there a differance? Thanks guys.
Quick WRX is offline   Reply With Quote
Old 01-15-2003, 02:48 PM   #2
zacek
Member#: 19467
02 WRX
WR Blue
flashing CEL's usually means a serious Mis-fire condition. If you have a lighweight Flywheel, that could be the cause. If not, it is highly recommended u have ur car checked. This is most likely related to P0301-304 codes for Cylinder mis-fire.
zacek is offline   Reply With Quote
Old 01-15-2003, 03:16 PM   #3
Quick WRX
Member#: 19689
2002 GDA TXS stg 4+
280 whp
I do not have a lightweight flywheel. I did get the flashing CEL when I hit the rev limiter in 3rd, hard! The solid CEL came on this moring when I started the car after a cold (california standards) night.
Old 01-15-2003, 03:25 PM   #4
nmyeti
Member#: 4980
Do you have a UTEC? If so the flashing CEL is the UTEC letting you know you are having detonation issues.
-Nathan
www.turboxs.com
nmyeti is offline   Reply With Quote
Old 01-15-2003, 03:46 PM   #5
araknyd
Member#: 24483
2008 STi
Dark Gray Metallic
I don't believe he's referring to a "flashing" CEL, but a CEL which comes on for a few hours or a few days and then disappears for a while (and then comes back). This is normal, at least for certain codes.
My rear O2 simulator went bad and I haven't got around to fixing it yet. The CEL comes on for a while, then goes off for a while. The trouble code doesn't go away, it stays there, and I can plug in a scan tool and read the O2 sensor malfunction code even when the CEL is off.
I can only assume the reason they turn the CEL back off is so that the light can still function as a misfire indicator or to come on if a different trouble code is generated. Or, maybe it only shuts the CEL off for non-serious situations, such as the rear O2 sensor malfunctioning.
araknyd is offline   Reply With Quote
Old 01-15-2003, 05:34 PM   #6
Quick WRX
Member#: 19689
2002 GDA TXS stg 4+
280 whp
Nathan - No I am still running my old UniChip
When I say flashing I mean lighting up for about a half second then turning off, it does this for 10-15 min.
Old 01-15-2003, 09:29 PM   #7
zacek
Member#: 19467
02 WRX
WR Blue
I think u need the Vishnu EMI adapter or the new "XEDE" device. Otherwise trade in your Unichip for a ECUtek re-flash!
Old 01-16-2003, 12:01 AM   #8
Quick WRX
Member#: 19689
2002 GDA TXS stg 4+
280 whp
Do most of you with a TurboXS stg 4 (or equivalent - VF34, STI injectors, fuel pump, uppipe, turboback, uprgade TMIC or FMIC) have CEL issues?
Flashing CEL-Solid CEL-no codes? Turbovan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-15-2009 10:32 AM
Solid CEL, Code P0103 IMPREZIV Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 08-07-2007 05:19 AM
STG2: Flashing CEL but no CEL code mvitic AccessPort 1 08-10-2006 10:43 PM
Solid CEL?? (cylinder1,2,3 misfire) cool555 Service & Maintenance 3 06-15-2005 01:52 PM
How long will solid CEL stay on for? 02R6 Newbies & FAQs 9 02-05-2003 05:32 PM
