Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 06-03-2001, 10:07 AM   #1
Jimmy
Member#: 586
Post Mobil One synthetic Tranny fluid is it worth it
It it worth using this in a Impreza RS 99
I am hopefully getting a turbo from ASR
I want to change the tranny fluid to synthetic how is that done and does any body know how to do it.and how many quarts does the RS use
thanks jimmy
Jimmy is offline   Reply With Quote
Old 06-03-2001, 10:36 AM   #2
PunksWRX
Member#: 5504
2004 Impreza WRX STi
Post
I assume you are talking about a manual transmission and gear oil? If so I wouldn't recommend Mobil 1 75W-90 in the transmission. It is too slick and the syncros may not operate correctly causing occassional gear crunch - I know from experience. I am running Red Line 75W-90NS in my transmission (and in my 00 RS when I had it) and it works fine. The NS formula doesn't have the friction modifiers in it that effect syncro operation.
As far as changing it . . . there is a large plug (19mm or 21mm) plug on the bottom of the transmission case right near the Y where the exhaust pipes come together. Remove that plug to drain the gear oil (watch out for the little washer on the plug), and make sure you have pulled the gear oil level dipstick so there is no air-lock to prevent all the oil from draining. Fill the tranny through the dipstick hole. I believe the RS holds about 3.7 U.S. quarts.
Punk
PunksWRX is offline   Reply With Quote
Old 06-03-2001, 11:03 AM   #3
Jimmy
Member#: 586
Post
I was going to buy Mobil one you dont think thats good
I notice know that the syncros right know runnning the regular stuff at high rpms it crunchs sometimes
Redline is good huh
Nobody in my area carrys it well I don't think anybody does
75w-90ns does mobil one make anything like it
Old 06-03-2001, 11:26 AM   #4
PunksWRX
Member#: 5504
Post
Jimmy,
The Mobil 1 gear oil is good stuff but it just doesn't work very well in Subaru's finicky transmissions. I recommend it wholeheartedly in the rear diff. If you go to Red Line Oil's website www.redlineoil.com they can direct you to the nearest dealer. I got mine from Summit Racing Equipment www.summitracing.com for a good price too!
Cobb Tuning www.cobbtuning.com has a good article on synthetic gear lubes in their technical section. Just remember though that Subaru requires a GL-5 rated gear oil. Some people use gear oils that are not GL-5 rated and Subaru could deny any warranty claim for not using a GL-5.
Punk
Old 06-03-2001, 01:45 PM   #5
cvalle-sd
Member#: 420
2001 Cr-V
Post
I used 3 parts Redline 75w90NS and 1 part Redline lightweight Shockproof. The thing is like butter. I used to run Mobil1, but as the other lads say, the gearbox was a bit crunchy. It's a great gear oil, but not for us. I've also heard that Motul 300 is great, but it was easier for me to find Redline.
cvalle-sd is offline   Reply With Quote
Old 06-03-2001, 01:54 PM   #6
goose
Member#: 3578
Post
Motul MT-90 may be a good choice as well, I was going to get it myself, but apparently the MT-90 stuff isn't rated for performance below freezing, so I went with Redline 75w90NS, gonna change it this weekend- I'll let you know how it feels-
goose is offline   Reply With Quote
Old 06-04-2001, 07:14 AM   #7
Jimmy
Member#: 586
Post
iam going to go with the redline gear box oil
thanks for the info
Jimmy
Mobil 1...is it worth it? MPRZIV Off-Topic 68 11-14-2006 01:29 PM
Lots of mobile one synthetic motor oil! ryanjorunner Private 'For Sale' Classifieds 12 03-26-2006 08:51 AM
Attic Roof Fan - Is it worth it to buy one? Cjchaps Off-Topic 22 05-09-2005 03:18 PM
Manual Tranny, Is it worth it. WRXImprezYa Newbies & FAQs 21 02-09-2003 10:49 PM
Mobil One Synthetic SupaSench Tri-State Area Forum 13 06-11-2002 02:16 AM
