Welcome to the North American Subaru Impreza Owners Club Monday August 3, 2015
Old 01-15-2003, 10:09 PM   #1
TaiChih
Member#: 3467
1998 Dinan3
Bleck
Question ? What is needed for an RS to WRX tranny swap?
Ok, just wondering if someone has the definite answer on what's needed to convert an MY99 RS tranny to a 2002-3 WRX tranny swap? Do I need the half shafts,drive shaft, Rear diff or LSD? Any info would be much appreciated, thanks,
TaiChih is offline   Reply With Quote
Old 01-16-2003, 10:44 PM   #2
amelnikov
Member#: 9827
2002 WRX Wgn 292whp
Alex Performance
Why would you do that? You basically have the same tranny ( unless you have an auto), just with a different final drive ratio. I think you may even have a numerically higher ratio then WRX.
Alex...
amelnikov is offline   Reply With Quote
Old 01-16-2003, 11:03 PM   #3
TaiChih
Member#: 3467
1998 Dinan3
Bleck
My issue is the clutch and the torque capacity differences of pull vs. push type clutches. I understand that with the RS tranny I get faster acceleration and lose top end, but I would like a tranny that would hold close to 300ft-lbs torque all day long. The ACT clutches are rated at 304ft-lbs and the WRX clutches can handle 400 ft lbs without having to go to 4 or 6 puck.
Need Help 2.5 RS into WRX tranny swap? jproland Transmission (AT/MT) & Driveline 6 01-16-2007 07:02 PM
Do I need 16" wheels for RS to WRX Rotor Swap? Evzen Brakes, Steering & Suspension 1 12-17-2006 12:37 AM
What is needed for an external wastegate setup fatray Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 42 05-27-2005 01:12 AM
no wiring(plug and play) for 02 rs to wrx engine swap? warpspeedwrx Subaru Conversions 3 11-09-2004 07:23 PM
Newbie to manuals. Can you help inform me of what is needed for a swap? DoctorNick Transmission (AT/MT) & Driveline 2 08-02-2004 11:48 AM
