Old 01-15-2003, 11:42 PM   #1
Haase14
Member#: 25070
2000 2.5 RS
silv/black
Default rear main seal replacement?+ flywheel and pressure plate bolt torque?
How hard is it to change it. I've got the tranny and clutch out for a clutch replacement. So I thought I might as well replace the seal . Does it just pop out with a pick or do you have to split the block halves. Also is there a special seal driver to put it back in.
Also Act pressure plate and flywheel bolt torque any one have this
Any info would be appreciated. Thanks
Haase14 is offline   Reply With Quote
Old 01-16-2003, 02:15 AM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
my 2 cents, don't replace it, if it's not leaking don't touch it. I have seen people think this wasa good idea and end up gouging a crank in the process then having to do it all over again, and the seal rides in a holder you remove the holder and pop the seal out.
Jeremy
Old 01-16-2003, 12:15 PM   #3
Haase14
Member#: 25070
2000 2.5 RS
silv/black
Actually it is leaking! What holder are you talking about. Because all I see is block, seal, crank no holder?
any more info?
Old 01-16-2003, 12:24 PM   #4
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Are you sure it's leaking? There is a plate on the rear passenger side of the motor that covers a wrist pin access hole that VERY commonly leaks. Both hndatch and I have had to go in and reseal ours. It appears as almost a random leak towards the rear of the motor, very hard to track down.
Old 01-16-2003, 12:54 PM   #5
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
yup
Old 01-16-2003, 04:01 PM   #6
TaiChih
Member#: 3467
1998 Dinan3
Bleck
I know for sure that the pressure plate torque is very little, 11-14ft-lb. But I think 45ft-lb for the flywheel.good luck
TaiChih is offline   Reply With Quote
Old 01-17-2003, 01:45 AM   #7
Haase14
Member#: 25070
2000 2.5 RS
silv/black
Went to dealer today got the seal . Couple of bucks, also bought a service manual for the car $30 dollars for the 1 out of 8 that they print for the impreza. All you have to do is pop out the old and use a seal driver to put in the new. Cost of new seal driver $22 (not bad to have laying around). Also I will check the plate in back the one that has "33" stanped in back of it . I'll probably re seal it just for added safety . Anyway thanks for all the info.
Old 01-17-2003, 10:42 AM   #8
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
FYI, you need an impact driver to get that plate off. It's got friggen phillips flathead screws on it, so it's either use one of those hammer-based impacts or strip out the head.
Rear Main seal replacement, what else while in there? ScubaruImpreza05 Transmission (AT/MT) & Driveline 5 03-22-2010 11:25 AM
FS NJ: 07 STi Clutch and Flywheel and Pressure Plate w/ 2k Miles cynet2k Drivetrain 9 01-15-2009 11:20 PM
Rear main seal replacement Lee MD Legacy Forum 14 04-26-2007 08:51 AM
Flywheel & Pressure Plate bolts? BillJC Transmission (AT/MT) & Driveline 4 04-25-2006 03:31 AM
stuck need torque specs for flywheel and pressure plate??? scooby Transmission (AT/MT) & Driveline 2 07-17-2002 11:06 AM
