Old 01-16-2003, 03:29 AM   #1
Benjamin Tang
Member#: 4496
2009 Forester
red
Default what is the going rate for 2.5 GT wheels/tires?
thinking about selling the ones on our legacy... came from a 99 model, has one or two rock chips, no curbing, but it has marks from wheel weight removal , re92's at 50%. what can i expect from them?
Benjamin Tang is offline   Reply With Quote
Old 01-16-2003, 09:04 AM   #2
subarurabbit
Member#: 4083
2011 OB 3.6R
I got a set summer 2001 that had pretty good rash for $200. Came with bald Dunlop sp 5000s...
$200 - $300 seams reasonable
subarurabbit is offline   Reply With Quote
Old 01-16-2003, 01:05 PM   #3
Mx5racer
Member#: 2629
A good set of subie 16" wheels are $100 - $125 a piece, no problem. I paid $500 for mine (from an RS).
The tires are near worthless unless they are good tires and are nearly new. I don't think many people want used RE92s, but you may get lucky.
Mx5racer is offline   Reply With Quote
Old 01-16-2003, 01:06 PM   #4
Mx5racer
Member#: 2629
(oh, I think the $500 included $25/wheel shipping).
Chaz
Old 01-16-2003, 01:31 PM   #5
KD7000
Member#: 16653
2012 Mazda 3
2013 Toyota Vanling
I recently paid Crazy Ken ~$500.00 for a set of Legacy wheels with Nokian NRW's. But the tires alone were easily worth $100.00 each...
Your biggest obstacle is the used RE-92's. Generally, no one really wants those; they're just adding bulk to the shipping costs.
The going rate for WRX take-offs with new RE-92's seems to be about $300-$350 around here- you have much nicer & rarer wheels, but crappy tires... RS wheels tend to go for more $ because they're 7" wide and clear bigger brake kits...
I'd ask $350 plus shipping and see what you get.
-Brian
KD7000 is offline   Reply With Quote
Old 01-16-2003, 03:17 PM   #6
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Are the GT wheels 16x7 with a 53 offset?
Old 01-16-2003, 03:21 PM   #7
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
16x6.5, +50 or +53.
Dave
DLC is offline   Reply With Quote
Old 01-16-2003, 05:07 PM   #8
scubaracer
Member#: 4909
1992 legacy 2.2Turbo
silver sports sedan
really? cause the RS wheels are 53offset and i am pretty sure the legacy wheels are 55offset, but atleast 53. i think the wrx wheels are the same as legacy gt.
scubaracer is offline   Reply With Quote
Old 01-16-2003, 07:30 PM   #9
KD7000
Member#: 16653
2012 Mazda 3
2013 Toyota Vanling
The Legacy wheels are either +53 or +55. As are the WRX wheels. I'm pretty sure it's +55, but I can't remember for sure.
Certainly not +50.
Both are 16x6.5"
-Brian
Old 01-16-2003, 07:37 PM   #10
ciper
Member#: 15543
90BJ Legacy LS ABS
So the only advantage to these wheels over the WRX take offs that are flooding the market would be to those people that want a big brake kit.
I think the only reason they fit the big brakes is the slight offset decrease. Realize you can get the WRX stockers to fit if you use a 3mm spacer, reducing the offset to 52.
Anyone know weights of the two?
Old 01-16-2003, 07:51 PM   #11
KD7000
Member#: 16653
2012 Mazda 3
2013 Toyota Vanling
No, they're also much, much rarer and prettier
I doubt the Legacy wheels truly offer better brake clearance. Offsets are the same. I think the weights are pretty close as well...
Anyone ever measure the spoke clearance on 'em?
If not, I can do this in the spring, when the Leg wheels come off my wife's Impreza and the WRX wheels come off my Legacy
-Brian
Old 01-16-2003, 11:19 PM   #12
Benjamin Tang
Member#: 4496
2009 Forester
red
argh... all i know is that the 2.5 rs wheels are 16x7, are lighter, and have enough clearance for 4-pot sti brakes, whereas my gt wheels are 16x6.5 and do not clear 4-pots. i'm pretty sure the rs wheels have a different offset because it dosen't sit as deep in the wheelwell, but i'm guessing that's because they had to make sure the extra 0.5" dosen't hit anything on the inside?
there... the cat is out of the bag
Old 01-17-2003, 01:21 PM   #13
Mx5racer
Member#: 2629
Yes, the offsets are different with the RS wheels I have. Actually, they do sit deeper in the wheel well, and can cause problems on hitting stuff on the inside.
I can not put on 225/50-16 on my car (Y2k wagon) because I have the RS Wheels. There is not enough clearance on the inside of the rear tire to put a bigger tire on. (Well, it might work, but I seriously doubt it).
With either the stock Outback, or the GT, there is plenty of clearance at my tight spot to put a wider tire on, like the 225.
Maybe I should just get a spacer, but not being able to use 225 tires was a surprise I was not expecting from the RS wheels!
Chaz
Old 01-18-2003, 01:00 PM   #14
etam
Member#: 439
www
It is all about demand and supply.. I sold mine (very good conditions) locally for C$650 last summer (wheels only).
etam is offline   Reply With Quote
Old 01-19-2003, 11:53 AM   #15
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Default rim size
Look at the back of the rim.
It will show the size, something like 16x6.5jj53.
The 16 is dia, the 6.5 is width, the jj is lip style (shape) and the 53 is the offset.
What is the going rate for a stage 2 Protune? tommott77 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-06-2009 09:52 AM
What is the going rate for 2003 Foresters these days? twiztid Forester Forum 9 11-13-2002 08:53 PM
what is the going rate for a consultant? (IT) Fish Off-Topic 23 11-06-2002 05:59 PM
what is the going rate for wrx wheels/tires? Benjamin Tang Vancouver Impreza Club Forum -- VIC 23 06-10-2002 01:37 AM
What is the going rate for TEIN front and rear pillow ball mounts? Robmat Brakes, Steering & Suspension 0 07-19-2001 06:59 PM
