Old 09-30-2008, 09:45 AM   #251
rkramer
Member#: 118209
2015 WRX Limitec
THIS TRICK DOESN'T EXIST! It does nothing useful that will have any lasting results, and could potentially cause damage. It doesn't matter what year, it has the same affect on basically every fuel injected vehicle on the planet. They all have preset conditions with knock learning functions, and they all can be temporarily tricked.
Bad information just doesn't die!
Old 11-21-2008, 04:14 PM   #252
VinnieisSouth
Member#: 192214
02 2002 WRX
I personally find this trick b**s**t. I blew my head gasket letting it rev for 5 seconds. who knows after it gets back from the shop it could be running like a champ if not I'll try it again.
VinnieisSouth is offline   Reply With Quote
Old 11-21-2008, 04:32 PM   #253
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
i cant believe this is still a sticky.
this "trick" is useless with romraider and the ability to easily set the IAM to start at 16 (16 bit ecu) or 1 (32 bit ecu).
all the trick is doing is increasing the IAM quickly from its reset level in the ecu.
no one that tunes leaves the IAM down at the stock reset level.
Old 12-11-2008, 09:33 PM   #254
Zumble
Member#: 34860
2005 Forester CGM
I leave my IAM at .75 and it easily comes up to 1.0 within seconds of giving it a little bit of throttle. No need to do a song and dance.
Zumble is offline   Reply With Quote
Old 02-20-2009, 03:41 PM   #255
oddwater99
Member#: 203561
1999 Impreza wagon
Custom painted semi-flat
crazy
oddwater99 is offline   Reply With Quote
Old 04-23-2009, 02:40 PM   #256
05wrx09
Member#: 204111
2005 WRX
what if you can't get your IAM to go to 16 and it just gets stuck at 15?
05wrx09 is offline   Reply With Quote
Old 05-21-2009, 11:34 PM   #257
GreasyThumbs
Member#: 211502
Good to know.
GreasyThumbs is offline   Reply With Quote
Old 06-05-2009, 10:06 PM   #258
ScubaruRex
Member#: 192545
i have cobb ap v2 ots stage 2 map would this work or would i have to have a pro tune?
ScubaruRex is offline   Reply With Quote
Old 07-07-2009, 09:47 PM   #259
2xr
Member#: 216466
i have seen/heard about many "quick tunes"...
but, its always better to work with people who have experience and knowledge. not so hard to make a wrong map.....
better pay to who know the job and have good name. prooven stuff
2xr is offline   Reply With Quote
Old 07-07-2009, 11:32 PM   #260
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
Then you find the problem that is making IAM drop rather then simply reset the ECU and do nothing to the tune.
If IAM is dropping, the ECU is detecting knock under rough correction and is lowering IAM in an effort to SAVE YOUR ENGINE. Fix the knock, then IAM will not drop - pretty simple.
Leslie.
wrxsti.l is offline   Reply With Quote
Old 07-25-2009, 01:57 AM   #261
jay_parot
Member#: 202352
1996 STI V3 JDM
WHITE
i have a crazy problem , my car was not turbo i put in a haltech ECU and a WRX TURBO engine, but when we tune the car it just wont go over 4.800 Rpm !!! its like it running out of spark or gas just backs fire or some like it wide band shows too rich or too poor rise gas and lowered and same thing , and i have 4 WRX STI coils and 255 fuel pump check everything cant find the problem .... i try with another Haltech ECU same model same problem WTF !!! try different map settings etc etc
any sugestions ??
jay_parot is offline   Reply With Quote
Old 07-25-2009, 09:00 PM   #262
05wrx09
Member#: 204111
2005 WRX
any sugestions ??
this isn't the place to post that, though I'm sure someone would gladly help you out... you just need to post it somewhere else
Old 10-19-2009, 02:36 AM   #263
MiNi*Me_03wrx
Member#: 224805
2003 WRX
YELLOW =)
sounds like a great tip, tryin it tomorrow.
MiNi*Me_03wrx is offline   Reply With Quote
Old 10-19-2009, 07:43 AM   #264
joedrewniak
Member#: 206431
2002 Impreza WRX
World Rally Blue
very good, gotta try it.
joedrewniak is offline   Reply With Quote
Old 10-19-2009, 09:07 AM   #265
007WREX
Member#: 165518
Nice i'm gonna give that a shot
007WREX is offline   Reply With Quote
Old 10-26-2009, 11:36 AM   #266
D.Hiere
Member#: 225438
D.Hi http://tierussi
D.Hiere
Default Re Mapped ECU Learning Trick 10 20hp in 5 seconds
rnOK...rnrnI was just looking at getting an iPhone and was reading that they run Windows and thought...why not.rnrnSo its not as simple as installing the Halwin software on the iPhone then rn
D.Hiere is offline   Reply With Quote
Old 11-04-2009, 01:05 AM   #267
WhiteNoise
Member#: 227235
2005 Stage 2.501 LGT
/\ truth. I had e tunes by another sites highly praised vendors and just about all my tunes were pig rich taking out the $150 upstream, 9k rpm spikes and 19-20 psi on stock vf40 causing vacuum lines to blow apart often. They even had watered down tunes that would crack a stock TMIC. I went and got a real tune and haven't had any new issues since.
WhiteNoise is offline   Reply With Quote
Old 11-11-2009, 08:49 PM   #268
dbeltran72
Member#: 205686
2007 STi
thanks for the tips.
dbeltran72 is offline   Reply With Quote
Old 01-27-2010, 12:11 AM   #269
shmuliks87
Member#: 236199
good tip i'll tryit
shmuliks87 is offline   Reply With Quote
Old 03-16-2010, 09:45 PM   #270
Cgimpreza
Member#: 169377
2004 Impreza WRX
Nice! I just flashed to cobb stage1, so I'll be giving this a try.
Cgimpreza is offline   Reply With Quote
Old 09-28-2010, 04:19 PM   #271
rallycar2001
Member#: 238947
wow! even on the rs ecu? or this is just wrx.
rallycar2001 is offline   Reply With Quote
Old 10-27-2010, 05:12 AM   #272
ce_dois
Member#: 262129
nice trick
ce_dois is offline   Reply With Quote
Old 11-08-2010, 03:38 PM   #273
D0nets
Member#: 129746
2007 stg3 WRX
WR Blue
All this does is get your ignition advance multiplier to one. Total Timing = Base + (advance * IAM). You dont have to brake boost like the OP suggested. Just get in 2nd at 2k rpms and give partial throttle to hold boost at 0 psi to about 4 or 5k rpms. Or like another poster said, set your intial IAM value to 1(32bit ecu's) or 16 (16 bit ecu's) in your rom.
D0nets is offline   Reply With Quote
Old 11-25-2010, 01:29 AM   #274
2.5 NW RS
Member#: 110066
2.5 NW RS is offline   Reply With Quote
Old 12-26-2010, 06:33 PM   #275
Alistairh
Member#: 268286
2011 STi
Dark Grey
Default ughh
Make sure if you do this, that your map is known to be good. Otherwise I could see you easily knocking your engine to death as the boost goes up.
Alistairh is offline   Reply With Quote
re-mapped ecu tiger20002 Subaru Conversions 2 09-03-2014 11:36 AM
Zero to 100% operational in .5 seconds Strider Off-Topic 31 02-01-2008 04:10 PM
Fuel Vapor Technologies Car = 92 mpg and 0-60 in 5 seconds hampster Non-Subaru News & Rumors 11 07-19-2007 12:15 PM
0-60 in 5 seconds, Confirm please? kahtep Proven Power Bragging 11 07-17-2006 01:55 PM
10-100mph in 7 seconds! BlownCobra Off-Topic 39 12-03-2003 12:02 AM
