Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 01-11-2011, 04:03 PM   #276
ericsson
Member#: 208672
2013 WRX STI Limited
Obsidian Black
Will this work for 08+ models with non-modified ECUs?
ericsson is offline   Reply With Quote
Old 01-12-2011, 01:04 PM   #277
ericsson
Member#: 208672
Obsidian Black
I tried it last night.. I did not notice anything different..
Old 01-20-2011, 10:23 AM   #278
KillerBV13
Member#: 229262
06 STI
white/gold
nice i will try this week when i go to the dyno. thanks for the trick
KillerBV13 is offline   Reply With Quote
Old 01-26-2011, 10:51 PM   #279
wildwilson
Member#: 265047
2011 STI
I'll give this a try.
wildwilson is offline   Reply With Quote
Old 01-31-2011, 07:10 AM   #280
Smokin' Joe
Member#: 219679
2011 Impreza WRX
Considering the original post was in 2003 and how much the current ECU's in newer models are; I wonder if this is still a valid technique at all and if it's reading the same tables for the ignition advance multiplier. I can't see any harm in trying it if you're going to reset the ECU anyways (I've tried it a time or two and it seemed to run just fine, but not a real difference from the butt-dyno or ear inspector, lol). If there's anyone with some detailed information on this reset technique and the newer ECU's please chime in! Thanks
Smokin' Joe is offline   Reply With Quote
Old 02-16-2011, 11:28 PM   #281
Toledo
Member#: 274201
2001 Subaru WRX 2001
I have a WRX 2001 and it really works!
Regards,
Toledo
Toledo is offline   Reply With Quote
Old 03-24-2011, 01:20 PM   #282
subiel94
Member#: 265602
1994 legacy
Aegean Blue Metallic
What all vehicles this work on? I got a 94 legacy turboed will it work for it?
subiel94 is offline   Reply With Quote
Old 03-28-2011, 03:37 AM   #283
rustywrx
Member#: 277263
2011 WRX Limited
I don't believe this is valid for 08+ wrx's. Eric from Torqued Performance has posted on the 3gwrx forum an explanation of the IAM for a 3rd gen wrx:
"Dyn. Adv. Mult. (DAM) or IAM [RR]
This is used as part of Subaru's knock control strategy. The Subaru ECU pulls timing to reduce knock and in extreme cases can richen the fuel mixture and disable boost control leaving you at wastegate boost. This value is multiplied to the timing advance table and added to the Base timing table to create the maximum timing advance. If the value is 1 full timing advance is being used. If the value is less than 1 only that fraction of the timing advance table is being used.
ex. If the DAM equals .5 and the timing advance table calls for 5 degrees advance. .5*5 = 2.5 degrees will be added to the base timing.
What you need to know. The DAM is set in a stock ecu to .5 after ecu reset. The tuner may modify this value to start at any value they want. Generally as you drive around this value will increase to 1. You will need to be at engine loads that apply timing advance to raise this multiplier as well as other factors. If your car does not raise this DAM or reduces it. It is because of feedback from the knock sensor. This is an indication that either knock is occurring or false knock is being picked up through the knock sensor. It is a safety precaution when bad gas or low octane gas is used.
If the value drops below .35 the alternative open loop enrichment table is used. This is a much richer table then the normal open loop enrichment table.
If the value drops below .2 the ECU disables Boost control. This will leave you car running at wastegate boost and you will always have 0% Wastegate Duty Cycle. It will not be turned back on till the DAM increases to above .65.
The value you are looking for is a DAM of 1"
The original poster is referring to the IAM being a minimum of 8 and a max of 16, and Eric's post from 3gwrx forum is saying the it should be 0.5 to 1 for a 3rd gen wrx.
I have a 2011 WRX with 500kms on the odometer so far. I did some logging with romraider and it shows the IAM is a value of 1. So it seems it doesn't take long at all to go from the default 0.5 to 1.
rustywrx is offline   Reply With Quote
Old 05-07-2011, 02:04 PM   #284
Supercharged
Member#: 270035
2007 Impreza WRX
World Rally Blue
Today we've been modifying maps in my 2008 WRX and after uploading a map once again the technique is to get to the road with no boost, then put the car into 2nd gear at low 15 mph speed, then use 50% throttle and once car pick up to this level, increase throttle steadily down to the floor.
We get immediately IAM of 1, if everything is okay with your map of course. These cars are "learning" really that fast.
Supercharged is offline   Reply With Quote
Old 05-09-2011, 07:28 PM   #285
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
the knock control is basically the same....so yes it still works.
But there is harm in it....because if your car is not happy at an IAM of 16 (16bit ecu) or 1 (32 bit ecu) then you will make it knock everytime you do this "trick"
It still works. As i just posted the IAM is just different on the older 16 bit ecus as todays 32 bit ecus.
The 16 bit ecus used 16 as 100% advance....12 (75%)....8 (50%)....4(25%)
the 32 bit ecus use 1.0 as 100% advance....0.75(75%)....0.50(50%) and 0.25 (25%)
Phatron is online now   Reply With Quote
Old 05-09-2011, 07:29 PM   #286
Phatron
Member#: 36033
CEO PhatBottiTuning
what is the point in doing that?
if you're modifying your ECU why dont you just make the IAM 1 to start off with in the map?
Old 08-03-2011, 08:47 PM   #287
Dirtisthefunstuff
Member#: 288269
not to jack this thread.. new contacts are killing me its tough to read but will this work for a NA motor? i keep seeing boost related things so im curious.. thanks
Dirtisthefunstuff is offline   Reply With Quote
Old 08-25-2011, 11:19 AM   #288
Y_I_K_E_S
Member#: 159449
2005 WRX STi
"Ali"
+1. I'm too impatient between revisions when I'm doing a tune so I always set the initial value to 1 or 16.
Even if you use the stock initial value, your [happy] car will "learn" an IAM value of 1 or 16 within minutes anyway. You do not gain anything by this trick.
Y_I_K_E_S is offline   Reply With Quote
Old 09-01-2011, 03:06 AM   #289
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
This.
The description of IAM in Vishnu's post was incorrect, and the his learning workaround is unnecessarily cumbersome. It's time for a sticky that reflects today's better understanding of what IAM is and how to completely skip that part of the reset process.
Old 09-21-2011, 08:25 AM   #290
ercuz
Member#: 295166
good job,thanks...
ercuz is offline   Reply With Quote
Old 09-22-2011, 02:59 AM   #291
NSFW
Member#: 140444
05 Stage Free LGT
I just realized that I forgot to post a link to the new thread:
http://forums.nasioc.com/forums/show....php?t=2235130
It does the same thing suggested in this thread, but it works faster and with less effort.
Old 01-25-2012, 12:38 PM   #292
Redley78
Member#: 299985
2012 WRX
Wow, i just wasted so much time reading a Sticky from beginning to end.
Why is this a sticky again if it is no longer relavant?
ECU's on WRX 08+ dont work the same way as older cars, so it should not be a sticky.
Redley78 is offline   Reply With Quote
Old 01-25-2012, 01:25 PM   #293
Phatron
Member#: 36033
CEO PhatBottiTuning
^^ why do you say the 08+ doesnt work the same? The IAM is still there...and still not 1 from the factory....
but yes this process is very out dated
Old 01-25-2012, 04:15 PM   #294
NSFW
Member#: 140444
05 Stage Free LGT
That is a very good question.
However, the 08+ cars aren't really any different, and the methods I posted in the alternative thread will work on older cars too.
Old 03-18-2012, 09:17 PM   #295
jege41
Member#: 280754
Hi
I have a 2011 WRX and used your procedure and YES there was an initial increase of probably as you say 10 to 15 % . but then it seemed as though some of it disappeared ( possibly my thirst for more power)
THX
jege41 is offline   Reply With Quote
Old 03-23-2012, 02:27 PM   #296
Onejamasubaru
Member#: 312346
2012 WRX
Satin White Pearl Sedan
I would sure love a video
Onejamasubaru is offline   Reply With Quote
Old 03-23-2012, 05:38 PM   #297
Nawratil
Member#: 306659
2012 Impreza WRX
Obsidean Black Pearl
^Same
Nawratil is offline   Reply With Quote
Old 03-24-2012, 01:01 AM   #298
jege41
Member#: 280754
Default Why a Video??
Sorry but why would you need a video do perform such a simplistic procedure?
Old 03-27-2012, 01:40 PM   #299
VIsubi
Member#: 187834
06 2.5i impreza
Red
How does this work on one an N/A set up reflash with Cobb AP and Supercharged at 10 psi 2006 2.5i. I know once knock is noticed it can take weeks for ecu to learn so I just reset and car seems strong again no hold back from ecu. Yes I know turbo vs what im talkin bout N/A
But all ecu's learn and if I'm not mistaken newer 2.5i's ecu's bit rate is still over ej205's so maybe learning curve acceleration is achievable?? Anyone in the tuning department care to chime???
VIsubi is offline   Reply With Quote
Old 01-05-2013, 08:27 PM   #300
Ed05WRX
Member#: 319401
05 WRX
WR BLue
I did what you said. Seems like it pulls a little better, but wanna make sure I did it right.
Unplugged the negative wire off the battery. Pressed the brakes for about 6 seconds, them put the negative back on, drove off and didn't boost till I got to third gear and reved to 2600 rpms, after I did that I looked at my gauge and all the lights came on the gauge and immediately it turned back on. Was that right? It had to do that?
Ed05WRX is offline   Reply With Quote
re-mapped ecu tiger20002 Subaru Conversions 2 09-03-2014 12:36 PM
Zero to 100% operational in .5 seconds Strider Off-Topic 31 02-01-2008 05:10 PM
Fuel Vapor Technologies Car = 92 mpg and 0-60 in 5 seconds hampster Non-Subaru News & Rumors 11 07-19-2007 01:15 PM
0-60 in 5 seconds, Confirm please? kahtep Proven Power Bragging 11 07-17-2006 02:55 PM
10-100mph in 7 seconds! BlownCobra Off-Topic 39 12-03-2003 01:02 AM
