02-06-2003, 12:04 PM | #76 | |
Member#: 2992
NESIC
Vehicle:02 WRX Sedan Silver |
02-06-2003, 01:12 PM | #77 |
Member#: 8635
Vehicle:04 STI, 07 FXT |
My dd logs show that the ecu after a reset readily tests for proper timing. It usually is bouncing around and seems to retard with knock, hittting an upper limit at a certain rpm, or with maf changes. Since the ecu apparently does not adjust timing for knock above 5500rpm, my timing can easily get out of hand at the upper rpms. It typically will jump 3-5 degrees at 6200rpm. This timing jump can last anywhere from weeks to months. Once it settles down, you get a much smoother timing curve without big gaps in timing changes.
Does the shiv reset help with this problem? My ecu was already showing a smooth timing curve and the shiv reset didn't seem to effect it at all (why reset the ecu when timing looks good) so I can only assume it has no effect on this particular issue or that my ecu timing multiplier was already set. Too bad I can't say the same about my a/f learning. Apparently, it has to be set by another means. I guess I will have to wait another month or so and keep changing a/f to compensate. Greg |
02-06-2003, 01:13 PM | #78 | |
Member#: 12737
Vehicle:MY02 wagon 325/300, MBP |
sav |
02-06-2003, 04:06 PM | #79 |
Member#: 17796
Vehicle:2002 WRX Sedan Midnight Black Pearl |
No. Actually, I said exactly what I meant. There is a thread on one of these boards about disconnecting the power source to the ECU at the ECU, so as to avoid resetting the radio presets every time you disconnect the battery. I am asking whether the power source to the ECU can be directly interrupted with a switch without negative consequences to the way the ECU receives the power supply.
02-07-2003, 04:18 AM | #80 |
Member#: 30970
Juliano,
I thought about maybe at the fuse box? I havent modded yet so havent tried it Shotgun |
02-07-2003, 08:53 AM | #81 | |
Member#: 12737
"...rather than crawling into the passenger footwell every time.." I never considered that someone might actually be willing to climb into the foot well, pull back carpet, take off the kick plate, disconect/reconect power to the ECU, and then reassemble everything EVERY TIME they needed a reset, just for radio stations my bad |
02-07-2003, 12:05 PM | #82 |
Member#: 9643
Vehicle:'02 WRX Wagon WR Blue |
Found this on an Australian site. Hope it helps.
How to reset your ECU (without disconnecting your car battery!) Following extract from Brett Middleton of MRT Performance (Thanks Brett!) By the way its in the WRX book... ECU clear memory procedure is as follows: 1) With engine at operating temperature, turn engine off and place gear shift lever into park (auto transmission cars) 2) Locate the two ECU check connectors, for most cars they are located under the steering column and consist of a black plastic male and female connector, and a green male female connector. The exact location of the connectors varies with the different year models, but generally they are located under the steering column on the drivers side. With the ignition OFF connect black to black and green to green. 3) their exact location varies depending on the year model 4) Turn on ignition and cycle the gearshift lever from park to neutral and back to park (auto transmission), depress the accelerator pedal to full throttle and hold for a few seconds, and then release. Start engine and then drive for at least one minute, keeping road speed above 11 Km/h. (Ed. don't have to do the gear shift cycle in a manual car, only the auto) 5) At this point the check engine light should start to flash the all clear signal (steady 1/2 second interval flashes). If the check engine light does not flash, or indicates some other sequence, there is a fault present in the system, and should be professionally checked for necessary repairs. 6) the ecu is now clear and re set! 7) choose your favourite radio station without having to reset it ! (grin) for more data and regular info like this subscribe our regular update service........ http://www.MRTrally.com.au The TRUE rally based enhancement workshop regards, Brett (Disclaimer: If you don't think you are capable of following this, or have any doubts, DON"T DO IT! Go see your local performance shop ie MRT and ask for there help.) |
02-07-2003, 12:56 PM | #83 |
Member#: 17796
Rocket, If memory serves, those instructions don't apply to MY 02+. There is another procedure for new age WRXs.
Sav, my bad. What I meant to imply is that the best way of resetting the ECU is to disconnect it directly, rather than disconnecting the power for the entire car (I haven't reset it even once by disconnecting the ECU power source). Given that premise, I'm looking for a way of resetting the ECU in the best way, without crawling into the blah, blah, blah. If I'm going to do all that, I'd like to figure out a mod to do while I'm in there. So my (basic) question still stands. Can wiring and a switch be insterted into that circuit to allow an ECU reset at the ECU's power source? |
02-22-2003, 03:12 PM | #84 |
Member#: 22021
Vehicle:2002 Impreza WRX Silver |
Newbie question here. I don't have a boost gauge.....yet and I was wondering how easy it would be to do a Shiv Reset just by using the tach???
02-23-2003, 01:13 PM | #85 | |
Vendor
Member#: 14494
Vehicle:WRX Porsche 996 blue & black |
Cheers, Shiv www.vishnutuning.com |
03-11-2003, 12:53 PM | #86 |
Member#: 25227
Vehicle:2012 Escape Black |
Question (I hope this wasn't answered somewhere already) - how can one do this if one were not to have a boost gauge in one's car, even though one really wants to get said gauge really badly but one does not have funds for such purchases right now??
03-11-2003, 01:01 PM | #87 |
Member#: 17796
Two green connectors
Plugging the two green connectors together in an '02 and up WRX will put the ECU into a type of diagnostic mode. ECU will be reset and fans and CEL will cycle on and off. After unplugging the connectors and restarting the car everything will be fine expect for the ignition advance multiplier will be at ZERO, not the usual 8 or the best-for-performance 16 that the Vishnu Reset induces.
One could then use the ECU learning trick to advance the ignition advance multiplier, right? |
03-11-2003, 05:28 PM | #88 |
Member#: 7492
South East
Vehicle:No race cars www.tomhoppe.com |
Ok, stupid question.
Can we just do this WITHOUT resetting the ECU? Lets say Im on my way to an autox and just want to make sure the multiplier is good to go. Will doing this trick max it out,or does the ECU have some kind of failsafe built in, where this only works right after a reset. -Tom |
03-12-2003, 06:38 AM | #89 | |
Member#: 24981
Vehicle:2o03 Impreza WRX Bluish-Blue |
03-13-2003, 12:10 AM | #90 | |
Member#: 5756
Vehicle:2004 Jeep Rubicon Black |
03-19-2003, 11:00 AM | #91 |
Member#: 232
Vehicle:99 RS-T RIP 02 Forster-S |
Q's for Shiv and Jon:
1. It was said that any Subaru ECU should respond to the "Shiv Reset"... now my question is for the AFI folks will bypassing the turbo yield the most advance... I suppose the same question would apply for the FFI guys too (or why is 2psi the magic number?). 2. I'm running WAY too much fuel for my low boost setup and am almost maxed out on my AFM correction... I discovered that my ignition retard settings were great with smaller injectors but caused very choppy power with 420cc's. When I went back to factory RS timing all was well and I began playing with adding advance to the already aggressive RS timing curve... will this technique help/hurt the timing curve (since the RS was never intended to see boost) or (like in question 1) would bypassing the turbo yield the most aggressive timing curve? Juliano, the idea on a switch has been toyed with around here before... you should be able to wire in a kill switch to the ECU ground and interupt it (same effect as unplugging the neg battery terminal?). I think there may one or two folks on the board with an ECU reset switch, ask around. |
03-19-2003, 11:00 AM | #92 |
Member#: 232
03-19-2003, 02:27 PM | #93 |
Member#: 4800
TXIC
Vehicle:1990 Legacy & OB XT AWD 6MT EJ22T AWIC Swap |
Couple questions/comments here.
First comment is on the memory clear procedure that was posted from MRT. This procedure is the same across pretty much all newer subarus, 1990+ The 1990 Legacy FSM gives that procedure to clear the codes, connect the green & black connectors. The black connectors connected alone displays any active codes that are stored in the ECU's memory. The green connectors as shiv mentioned puts the car in an active diagnostic mode. Question here is.....is there a difference between resetting the ECU, and just clearing the codes? In the past I have said yes, there is a difference. But that was mainly due to how the car responded after disconnecting power from the ECU, vs. just clearing the codes with the connectors. Secondly....this question was asked earlier in the thread, but I didn't see an answer, does this trick work with n/a cars, and if so, what would be the proper procedure/instructions to get the ECU in the "mood" to raise the timing. I think that'll hold me over for now. |
03-19-2003, 04:04 PM | #94 | |
Member#: 2992
NESIC
03-19-2003, 04:33 PM | #95 |
Member#: 17796
I did the green connector thing today to reset a CEL. It worked fine, but still looking for Shiv to answer whether the ECU learning trick will work after this type of reset.
03-20-2003, 08:39 AM | #96 | |
Member#: 4800
TXIC
What about the old gen turbo legacies. Does this feature seem to only exist on turbo cars? |
03-25-2003, 05:27 PM | #97 | |
Street Racing Instructor
Moderator Member#: 110
Vehicle:1989 1989 XT6 |
Hello Jon
Why would you think that an N/A ECU would adjust timing differently when the patent you linked to earlier didn't seem ECU specific? *BTW: That was great information. I can't help keep reading through the patent(s) now, the diagrams, etc*. I'm looking through my XT6s FSM (Factory Service Manual) now (Yes OBDI and different ecu, etc) but I was thinking maybe the patent would apply to it also. It says that under normal operating conditions spark advance angle is calculated from the following three factors: 1) Engine speed compensation, 2) Advance when starting the engine, 3) Advance in all driving conditions except staring the engine, after engine speed exceeds the preset value. When knocking occurs (in the model...XT6), the ECU unit retards spark timing to prevent engine knocking. It keeps working in a cycle like this: 1) Knocking occurs, 2) Retard Timing, 3) Knocking is elminated, 4) Advance Timing gradually, 5) Feedback 5a) If no knocking go to #4, if knocking go to #2 In this instance, it doesn't mention any preset limits of advance. The only limitation seems to be when knocking occurs. I was thinking the same thing applied to the later scoobies as well. Any comment(s)? *BTW...this whole thread just blows me away. Lots of information, theories, etc. I love it* Also, I'm going to test this out myself at the dragstrip to see if any difference is found. I'm currently using 87 octane. I tested before with higher octane and found that my 1/4 mile time actually got worse (in a 1997 2.2ltr Impreza as well as my 1989 2.7ltr XT6). Now that I understand this ECU reset and quick learning advance timing bit, I'm going to test again...with 93 octane. Only one way to find out rather than just discussing it. Take Care Jon! |
03-25-2003, 09:29 PM | #98 |
Vendor
Member#: 6605
TRHoppe, Jim and Wes,
Don't know if anyone picked up your question, so I'll answer it here... The ECU is pretty much always using the advance multiplier. If you have been driving the car normally to aggressively, it will have learned up to its potential. You dont have to do this periodically to ensure good advance or anything. Shiv's trick is best for getting the car back to that normal, well-learned stage quickly after a reset. I wouldn't reset right before an autox at all. Normally, you can left foot the advance from 8 (starting) to around 12. The car can be a little more finickly getting to 16, but it doesnt take long even with normal driving. Go pull up a hill in fourth gear at 2900 - 3000 rpms and it gets there usually. If you left foot too aggressively you can take it the other way. Just yesterday, I had done a reflash, left foot braked to take the advance multiplier up from 8 to what I thought would be 12 or so quickly. The map was not aggressive, but I got too heavy with the left foot, trying to save time - the car bogged, and the advance actually dropped. Just be a little gentle. Ken Rally Performance |
03-26-2003, 01:35 PM | #99 |
Top Scoob 002
Member#: 32771
BAIC
Vehicle:03 Black WRX 04 White M3 |
I must have read it wrong or something. So just be at complete stop in third gear. Start going forward at around 2500rpm while braking to build boost while only moving at 2500rpm and do this for 5 seconds. Is that correct? By not pushing to hard on left foot you mean not braking to hard so u dont bog?
04-04-2003, 12:39 AM | #100 | |
Member#: 13826
Vehicle:2005 VW GLI -220hp '00 Miata,'05 Noble/order |
re-mapped ecu | tiger20002 | Subaru Conversions | 2 | 09-03-2014 11:36 AM |
Zero to 100% operational in .5 seconds | Strider | Off-Topic | 31 | 02-01-2008 04:10 PM |
Fuel Vapor Technologies Car = 92 mpg and 0-60 in 5 seconds | hampster | Non-Subaru News & Rumors | 11 | 07-19-2007 12:15 PM |
0-60 in 5 seconds, Confirm please? | kahtep | Proven Power Bragging | 11 | 07-17-2006 01:55 PM |
10-100mph in 7 seconds! | BlownCobra | Off-Topic | 39 | 12-03-2003 12:02 AM |
