Old 04-25-2004, 11:08 PM   #126
Turb0flat4
Member#: 53735
2003 Bugeye WRX
Does this have to be done immediately after an ECU reset without going into boost before the procedure.
Or is it OK to do it after you've been driving (normally, hitting boost on and off) for a day or so after an ECU reset. The car still feels slightly rough, so can this procedure still be done (without another reset) to smooth things out ? Or should the ECU be reset again before doing the process ?
Thanks a lot.
Turb0flat4 is offline   Reply With Quote
Old 04-25-2004, 11:26 PM   #127
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
reset it...
Old 04-29-2004, 02:44 AM   #128
killermike
Member#: 59318
2004 350Z Roadster
Pearl White/Blue
Can you do this if you have an Accessport?
killermike is offline   Reply With Quote
Old 04-29-2004, 12:24 PM   #129
Jeff_DML
Member#: 32018
2008 M3 Sedan
Interlagos Blue
I would think you should be able to since accessport retains the learning functionality of the ECU. Might not get the 10-2hp but you should maximize the accessport map you are using. I havent tried it yet though.
Jeff_DML is offline   Reply With Quote
Old 04-29-2004, 08:32 PM   #130
pat
Member#: 2071
A few observations if I may...
Most forced induction Impreza ECUs from MY99 to 2004- operate an advance multiplier. This limits the maximum amount of POSITIVE knock correction the ECU can apply. There is virtually no limit to negative correction.
A happy ECU should normally be at 16 or very close. If you reset an ECU that's already at 16 the result will invariably be a loss of power (which will be restored over the next 50 to 200 miles). If the ECU isn't already at or near 16 then there's something wrong with the fuel, map or engine. Duff fuel can cause the multiplier to drop and sometimes it gets "stuck", in these cases a reset can help.
Learning procedure is heavily car dependant. New Age WRX models learn really quickly between 3000 and 4000 RPM at 0.5 bar. MY99-00 turbo models don't need much boost to learn. MY99-00 STi models need a good 0.7bar to learn, and will normally jump to 10 first, then 12 then 16. New Age STi models like to learn going up through the gears rather than being held on a particular load. They also like to idle for a while, stood still and out of gear, after a reset before they want to "play".
There are additional criteria for learning, such as coolant temp, VVT operation etc. Each model has its "sweet spot", if you can get it there it will learn in 200 yards or so, if not it can take ages (notably STi models are a bit more fussy).
The learning makes more advance available. Typically the ECU should be adding at least 8 degrees on top of the base timing in the midrange. This is close to the limit of the stock maps, so with a multiplier of 8 it would be limited to about 4 or 5 degrees. Getting the multiplier up to 16 will allow another 3 or 4 degrees, which can be worth another 30 lb/ft.
A car that has a really low multiplier will feel "flat" or "hesitant" in the midrange, but this typically clears up over 4500 RPM. It may feel like a slight misfire, but it's just a lack of timing.
Bottom line is, if it feels wrong, it probably is. If it feels OK-ish then check the multiplier, if it's already 16 then leave well alone, if it's less then reset and keep an eye on it... if it falls down again use different fuel or remap.
Cheers,
Pat.
pat is offline   Reply With Quote
Old 05-05-2004, 10:57 PM   #131
surfer5567
Member#: 61199
2002 wrx wagon
wrb, s2, blouch 2.5, 6spd
what will this do for a completely stock wrx? i am planning to do this tonight?
surfer5567 is offline   Reply With Quote
Old 05-06-2004, 03:23 AM   #132
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
it will do nothing but "reset" your car to max timing advance, which is useful if you've recently run a bad tank of fuel.
It will take some time for the fuel trims to stabilize once again so it won't be perfectly smooth for quite some time still.
nhluhr is offline   Reply With Quote
Old 05-06-2004, 05:21 PM   #133
rlhaddock
Member#: 39969
2005 Legacy GT lmt
Garnet Red Pearl
If I haven't had a bad tank of gas, will the resetting of my ECU help anything? or should I leave it as is?? (total noob btw)
rlhaddock is offline   Reply With Quote
Old 05-06-2004, 06:55 PM   #134
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Unless something has changed with regards to the car in the last 1000 miles it won't do you any good. Fueling has been learned and timing has already set to your driving style and fuel quality. This "trick" is to advance the timing quicker than it would by driving around but in 1000 miles it will end up in the same place whether this "trick" was done or not. It is used primarily when a reset has been required because of a modification or has occurred for other reasons.
turboICE is offline   Reply With Quote
Old 05-07-2004, 10:48 AM   #135
rlhaddock
Member#: 39969
2005 Legacy GT lmt
Garnet Red Pearl
Thanks!!
Old 05-09-2004, 04:34 PM   #136
ZEROYONSWRX
Member#: 34442
03' WRX
white
Thumbs up reset
Ok, I am a total noob so please go easy on me. Let me know if this is how you do this?
I drive the car till it warms up. ( I HAVE A STOCK ECU BY THE WAY) Then while the car is still running disconnect the negative terminal and leave it unhooked then drive the car not getting into boost. Take off in 1st a little bit not getting into boost, then shift into 3rd and maintain 2600 for 5 secs or so. Then pull over and reconnect the negative terminal and go on down the road a little happier. Is it really that easy and is this correct way of doing it? Thanks
ZEROYONSWRX is offline   Reply With Quote
Old 05-09-2004, 06:50 PM   #137
Houdini
Member#: 51379
Sedona Red
No, your car will not start without the battery connected. Disconnect, reconnected, and then perform the procedure.
As a side note does anyone know how to pull the current value its at?
Houdini is offline   Reply With Quote
Old 05-09-2004, 06:55 PM   #138
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
No. Warm car. Turn off car. Disconnect battery. Press brakes. Reconnect battery. Turn car on. Get going to a normal speed pick a gear that is between 2500 and 3000 rpm at that speed. Using your left foot on the brake maintain the rpm between 2500 and 3000 rpm while getting boost between 5 and 10 psi for 5-10 seconds. It doesn't even have to be continuous you can do it for 3 seconds 3 different times.
But at least understand what this is about. When you reset the ECU it goes to a base state of fueling and timing. All this does is advance the point from which timing well be learned again by the ECU. It will not make your 227 hp car 243 hp. Basically a reset ECU is a tune that is around 210 hp and as learning occurs it increases if you are running good fuel. If you have been running the same gasoline for a while and do this you will end up pretty much back at the same place. This trick is done for when you have made modifications to the car and the ECU has to be reset because of it - but you want to do a dyno run right away, not wait until after you have driven 500 miles.
Delta Dash will pull what the current value of the advance multiplier is - but thus far it does not have that value for the US STi's though . I do not know if other scanners can - it is not part of the OBDII set of information.
Old 05-10-2004, 08:29 AM   #139
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
Made it a Sticky.......Good Stuff Shiv...
thanks
Old 05-11-2004, 04:44 PM   #140
chuglobal
Member#: 10041
2015 WRX Limited CVT
ISM
Default Yo
Good idea to make this a sticky to help individuals in the future.
chuglobal is offline   Reply With Quote
Old 05-11-2004, 06:29 PM   #141
STI-C-YA
Member#: 56825
2003 STI
Silver/Gold/Euroversion
Thanks Shiv
I have two questions:
Why does it has to be made at 2600 rpms?
Do you think that will work on my Eurospec 2004 STI?
STI-C-YA is offline   Reply With Quote
Old 05-21-2004, 12:49 AM   #142
perfusionista
Member#: 59471
2006 WRX Wagon
Crystal Gray
Default Re: Re: Re-Mapped ECU Learning Trick 10-20hp in 5 seconds :)
Originally posted by AZScoobie
Wanted to just state that left ft braking while in boost will drain the vac from the brakes power booster. This will cause the brakes to have no power assist.. Wont hurt anything.. just beware that you might not have strong brakes until you get back into vac.. I found this out on my car while doing some road tuning the otherday. Just FYI.
CT
OK. Let's think about what we're trying to achieve here. Do this while imitating the Monty Python Gumbys (they're the ones with the handkerchiefs on the heads and the wellington boots...) "if you press the brake pedal to restrict the speed while you press the throttle pedal at the same time it doesn't matter how much power assist you have... You are not trying to stop the car, you are only trying to stop it going faster..."
______________________________________
"You put one foot on the accelerator and one foot on the brake. It doesn't matter which one you press, as long as you press it HARD!" Pentti Arrikalla
perfusionista is offline   Reply With Quote
Old 06-08-2004, 09:15 AM   #143
jetwagon
Member#: 59872
2004 Impreza WRX
i've got an '04 with 2600 miles on the odo. i did this with the stock ecu. Seeing as how the ecu "learned" during the breakin period I noticed a difference. Good tip!
jetwagon is offline   Reply With Quote
Old 06-29-2004, 02:43 PM   #144
adg016
Member#: 45645
2004 WRX
WR Blue
I can't see a reason why it is NECESSARY to do the ECU reset to make this work. Anyone wanna weigh in?
Dan
adg016 is offline   Reply With Quote
Old 07-02-2004, 10:33 AM   #145
jetwagon
Member#: 59872
2004 Impreza WRX
I don't know but will guess anyways. If the ecu has 1000 hours of driving on it, then 5 seconds is about one millionth of that time. So the ecu would be comparing a point in time equal to one millionth to the rest of the time it has been working. It probably won't make any changes. Now, if it is reset, 5 seconds represents a higher percentage of the time the ecu has been managing the engine and significant enough to warrant change. But that's just applying logic. In truth, I have no idea if this is the way these things work.
Old 07-02-2004, 03:22 PM   #146
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
That's not true. The trick will work fine on an ECU that was not recently reset. The important thing to remember is that if for some reason your ECU has a low IAM without being reset, forcing the IAM to max may cause detonation if you don't know why the IAM was low in the first place. If all is well, the IAM should not be lowered by the ECU after a lot of driving time. That's why its really only a good idea to force it to max after a reset.
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 07-20-2004, 04:03 PM   #147
mcornale
Member#: 57449
07 Legacy spec B
sweet im goin to try this today will this still work with an auto wrx?
mcornale is offline   Reply With Quote
Old 07-20-2004, 10:42 PM   #148
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
I don't think it will work with an auto... I'd expect your tranny to down-shift with that much load at that RPM.
-- Ed
Old 07-21-2004, 12:32 AM   #149
adg016
Member#: 45645
2004 WRX
WR Blue
-- Ed
Ed,
Can you confirm that this still works on a 2004 in the same way and to the same degree?
Old 07-21-2004, 04:31 AM   #150
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
can't confirm it, sorry
-- Ed
re-mapped ecu tiger20002 Subaru Conversions 2 09-03-2014 11:36 AM
Zero to 100% operational in .5 seconds Strider Off-Topic 31 02-01-2008 04:10 PM
Fuel Vapor Technologies Car = 92 mpg and 0-60 in 5 seconds hampster Non-Subaru News & Rumors 11 07-19-2007 12:15 PM
0-60 in 5 seconds, Confirm please? kahtep Proven Power Bragging 11 07-17-2006 01:55 PM
10-100mph in 7 seconds! BlownCobra Off-Topic 39 12-03-2003 12:02 AM
