Old 07-21-2004, 04:51 AM   #151
adg016
Member#: 45645
2004 WRX
WR Blue
Originally Posted by Vaus
can't confirm it, sorry
-- Ed
Thanks for the honest reply. Anyone else? I didn't see any appreciable increase in whp using this reset as opposed to a standard reset on my 2004.
adg016 is offline   Reply With Quote
Old 07-22-2004, 05:34 AM   #152
Simon Lines
Member#: 1540
92 JDM GC8 WRX
2004 2.5 twin scroll 6MT
Your only going to get an increase if it's got bad (low) learning, it could get slower!
Cheers
Simon
Simon Lines is offline   Reply With Quote
Old 07-22-2004, 02:35 PM   #153
adg016
Member#: 45645
2004 WRX
WR Blue
Cheers
Simon
Are you providing confirmation that this type of "trick" will work on a 2004, or don't you know for sure? A reset will, of course, bring back power after some bad learning, but will the Vishnu method yield any more?
Old 07-23-2004, 07:35 AM   #154
Simon Lines
Member#: 1540
92 JDM GC8 WRX
Look the "Vishnu Method" is just a hard EMS re-set followed by utilisation of the optimal load speed / load sites to get the advance multiplier up to 16. Once it's on 16 (assuming it stays there) you get best usage of the ign correction 3d map and therefore "best" ign advance.
However, as in most cases this is not a hard and fast rule, more a general assumption. It could be that your vehicle is running well it's multiplier has been on 16 for ages and it has positive learning in it's fine ign correction, this mean's your getting more than it you did the re-set and got it onto 16 again because the learning (good learning in this case has been wiped)
Without the ability to check your just stabbing in the dark...
Cheers
Simon
Old 07-24-2004, 05:29 AM   #155
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Simon, can you respond to Stephen Done's recent assertions that once IAM=16 there is no more fine learning to be added to the total timing?
http://forums.nasioc.com/forums/showthread.php?t=600203
http://forum.ecutek.com/topic.asp?TOPIC_ID=413
nhluhr is offline   Reply With Quote
Old 08-01-2004, 06:37 PM   #156
KJY9
Member#: 66264
Originally Posted by Vishnu Performance
Just a little trick that has been shown to accelerate the factory ECU's ignition timing learning process.
.....Second: Drive to a nice open road without traffic. Don't go on boost until you get there. Put the car into gear (3rd gear works the best) bring the revs up to 2600rpm. Push the go pedal down slightly so boost stays right around 2-4psi. You will need to MAINTAIN 2500rpm and 2-5psi for approx 5 seconds. You can do this by left-foot braking gently as to prevent acceleration. During these few seconds, the advance multiplier (which you can't see so you'll have to trust me) will go from 8, to 12 and then to 16. Works like a charm. And on our reflashed ECU, is worth an immediate 10-20 horsepower
....Cheers,
shiv
www.vishnutuning.com
UGH easier said than done.....I gave up LOL
KJY9 is offline   Reply With Quote
Old 08-03-2004, 11:03 PM   #157
blackie
Member#: 42979
03 wrx
blizzzack stage IV
I did this trick succesfully my first try and it made a big difference over a normal reset, felt like 15-20 hp too! i have cobbs stage 2.5 map with vf-34, gruppe-s header, TBE, fuel pump, 565cc injectors, and hyperflow TMIC. the car is way pepier down low even in the 107 degree weather. My one question is, how long will it last? will the ecu learn to be conservative again?
blackie is offline   Reply With Quote
Old 08-06-2004, 10:51 PM   #158
SilverRush
Member#: 55595
2004 WRX
[quote=Vishnu Performance]
First: With the car fully warmed up, reset the ECU. This can be done by killing power the ECU or by simply pulling off the neg. battery terminal and pressing the brake pedal for a couple of seconds.
Second: Drive to a nice open road without traffic. Don't go on boost until you get there. Put the car into gear (3rd gear works the best) bring the revs up to 2600rpm. Push the go pedal down slightly so boost stays right around 2-4psi. You will need to MAINTAIN 2500rpm and 2-5psi for approx 5 seconds. You can do this by left-foot braking gently as to prevent acceleration. During these few seconds, the advance multiplier (which you can't see so you'll have to trust me) will go from 8, to 12 and then to 16. Works like a charm. And on our reflashed ECU, is worth an immediate 10-20 horsepower QUOTE]
Shiv,
Isn't this a potentially dangerous trick? I will have to take your word that it will work but if you are artificially setting a parameter within your ECU that otherwise might not get that high couldn't it cause some damage? What happens if you do this trick and it goes to 16 but because of some issue with your car or the gas you are getting or any other number of factors your ecu would usually normally set this parameter at some lower number. If this is the case how long does it take the ecu to adjust this number down from 16. I assume it is much faster than moving it up but is it an instant thing or could you possibly go full boost a couple times (and consequently cause some damage) before it adjusts down.
Look forward to some more information.
Keith
SilverRush is offline   Reply With Quote
Old 08-11-2004, 01:48 AM   #159
Rally Performance
Vendor
Member#: 16588
Default agh
Back to this thread -
Basically, Shiv pointed out a good method for getting your car to learn to advance more quickly here.
The same thing is achieved simply by driving up a hill. You are subjecting your car to load so that it learns. Otherwise the car will wait for some load to learn.
If you've gotten some bad fuel, an ECU reset may help you, otherwise it is a bit of a waste of time...
Keith - good question here. Actually, you aren't setting anything artificially up for the ECU to get ahead of itself. If it doesn't like the current fuel, it simply won't advance as far... as Stephen said I believe, you'll get back to the place that you were. On the other hand, if two tanks ago you got bad fuel and now you're back to good gas... the car may not have decided to advance fully just yet. By doing the reset, you're giving it a chance to start fresh.
Many people, without a full understanding of the reset, do it much more often than necessary in a nervous effort to keep the car happy. Our counsel: relax and let ECU do its job. The left foot brake method is an easy way once you've done a reset to feel quick results. But the end result is still the same.
Regards,
Ken
ScoobySport N.A. / Rally Performance
Rally Performance is offline   Reply With Quote
Old 08-11-2004, 04:47 AM   #160
Impreza2fast
Member#: 14088
2002 WRX (RIP)
I was just wondering, I have a unichip in my car right now, (probably the only one that still have it) and will this reset help my car or will it just stay the same or make no different??????
Impreza2fast is offline   Reply With Quote
Old 09-10-2004, 06:58 PM   #161
elcue
Member#: 69766
Default HKS FCD Question
I have a HKS FCD from my supra tt, can I use this unit in my STI an if so, what should I set it to and how. Thanks Johnny
elcue is offline   Reply With Quote
Old 09-10-2004, 07:27 PM   #162
supermarkus
Member#: 6971
2008 WRX STi
SSM
What the heck does this have to do with the topic? Start a new thread in the proper forum and you'll probably get the answer you need.
supermarkus is offline   Reply With Quote
Old 09-13-2004, 01:23 AM   #163
bobhooks
Member#: 70205
04 STI
My stock 2004 STI has a knocking issue. Will this help? What can I do to reduce the knock. I run standard 91 octane.
bobhooks is offline   Reply With Quote
Old 09-13-2004, 11:28 AM   #164
ThatSteveGuy
Member#: 43581
2002 Nightmare WRX
Take it back to the dealer...
ThatSteveGuy is offline   Reply With Quote
Old 09-26-2004, 08:01 PM   #165
Trunk_Monkey
Member#: 71032
2003 WRX
World Rally Blue
Originally Posted by JimmyOOOOO
my great-grandaddy always used to say... "better safe than sorry when it comes to yer brakes!"
Great grandaddy must be REAL young...
Trunk_Monkey is offline   Reply With Quote
Old 10-04-2004, 11:38 PM   #166
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
Hey I've got a Vishnu EMI for $75 bucks, it's supposed to make the uni-chip more stable.
silver arrow is offline   Reply With Quote
Old 10-18-2004, 07:25 PM   #167
hondaeater69
Member#: 60324
Advancing the timing on a car that's already knocking will NOT help it. You'll need better gas to keep your car from knocking, or get a more conservative map. You need retarded timing, not more.
Old 11-28-2004, 03:24 AM   #168
ncarn8
Member#: 71419
Originally Posted by Snowphun
Might want to rethink that, as those distances in 5 seconds work out to 90-180mph.
Paul
hahah
ncarn8 is offline   Reply With Quote
Old 11-28-2004, 03:30 PM   #169
WilmoWRX
Member#: 73981
2002 Impreza WRX
platinum silver metallic
what is knocking?
WilmoWRX is offline   Reply With Quote
Old 12-17-2004, 11:57 PM   #170
unkadave
Member#: 55525
02 wrx wgn 2.5
Keep Right
I did this once with my vf34 and it worked great. Iíve since done more mods and put in a vf22. Have EcuTek under a UTEC, with an AVC-R. Ran across this FAQ again and decided to re-do it.
Thing is the VF22 really is working at 2,500 rpm to develop boost that low. I ran it in third after resetting the ECU. I had to give the 02 wrx quite a bit of gas for 4psi, and ride the brake hard, to keep the rpmís from jumping.
Held it for a good five seconds. But I just got a whirr sound coming from the turbo, NO boost either. Drove the car down to the shop. Noise is coming from the turbo. I thought maybe I erased my EcuTek reflash - - but alas I blew the center cartridge. Iím putting in a 2.5 Axis anyway and have a 20G ready to go.
Cliff notes. VF22 may not like trying to push 4psi at 2.5 gr for five seconds. They are not the best turbo and donít even spool until 3.4 gr.
unkadave is offline   Reply With Quote
Old 12-20-2004, 02:32 PM   #171
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
the trick works at 3100RPM.... you could have probably done it fairly easily at 3100... not that it matters since your ecutek reflash most likely starts with an IAM of 16 and your UTEC is controlling absolute timing anyway.
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 12-20-2004, 04:05 PM   #172
unkadave
Member#: 55525
02 wrx wgn 2.5
Keep Right
-- Ed
I needed a FP Green anyway.
But thx
Old 12-25-2004, 04:25 PM   #173
wonkothesane26
Member#: 33362
2004 WRX Sedan
Pockmarked/dented silver.
So, since turbo'd cars are happier in the cold (air temp, density...) since it is now below freezing, does it even pay for me to do this to my stock ecu?
Matt
wonkothesane26 is offline   Reply With Quote
Old 12-26-2004, 07:39 AM   #174
chuglobal
Member#: 10041
2015 WRX Limited CVT
ISM
Default Humm
I wonder if the same trick works on STIs?
chuglobal is offline   Reply With Quote
Old 01-22-2005, 10:22 PM   #175
hey1
Member#: 72106
2002 Impreza WRXagon
Platinum Silver Metallic
interesting.
hey1 is offline   Reply With Quote
re-mapped ecu tiger20002 Subaru Conversions 2 09-03-2014 11:36 AM
Zero to 100% operational in .5 seconds Strider Off-Topic 31 02-01-2008 04:10 PM
Fuel Vapor Technologies Car = 92 mpg and 0-60 in 5 seconds hampster Non-Subaru News & Rumors 11 07-19-2007 12:15 PM
0-60 in 5 seconds, Confirm please? kahtep Proven Power Bragging 11 07-17-2006 01:55 PM
10-100mph in 7 seconds! BlownCobra Off-Topic 39 12-03-2003 12:02 AM
