Old 01-30-2005, 04:04 PM   #176
RallyImprezive
Member#: 5476
2007 WRX UGM
2010 FXT
For those with no hills, or left foot brake experience, just pull the ebrake up a little bit to get a very consistant resistance. Works well for me.
Andy
RallyImprezive is offline   Reply With Quote
Old 01-30-2005, 04:31 PM   #177
kool168
Member#: 61006
Originally Posted by chuglobal
I wonder if the same trick works on STIs?
i tried but it is very hard to keep it for 5 sec, since the full boost comes 3k rpm. then i gave up.
kool168 is offline   Reply With Quote
Old 02-01-2005, 11:55 PM   #178
23b_Rex
Member#: 79394
02 gda
wrb
very glad to be part of this community, thanks for the info shiv
23b_Rex is offline   Reply With Quote
Old 02-23-2005, 10:25 PM   #179
blshipe
Member#: 72412
2002 impreza wrx
do you have to remap the ecu everytime you upgrade factory parts such as the intake or exhaust?
blshipe is offline   Reply With Quote
Old 03-05-2005, 02:05 AM   #180
boostlandiscool
Member#: 70659
ecutek and delta dash
boostlandiscool is offline   Reply With Quote
Old 03-05-2005, 02:05 AM   #181
boostlandiscool
Member#: 70659
are the greatest i have heard
Old 03-16-2005, 07:59 PM   #182
Bob Marthfield
Member#: 83026
2005 Impreza WRX
Crystal grey
Any particular reason why this won't work just sitting in your driveway revving the engine?
In other words, does the ECU and the engine "know" that the wheels are turning?
Obviously, I assume this won't work, but I'd still like to know.
Bob Marthfield is offline   Reply With Quote
Old 03-16-2005, 09:09 PM   #183
Got Groceries?
Member#: 25323
2003 WRX Wagon
It's more than just RPMs, engine load figures in as well. I guess if you REALLY hated your clutch you could sit in your driveway with the e-brake on and the clutch barely engaged, but keep a fire extinguisher handy! Along with a grand for a new clutch and flywheel. LOL
Got Groceries? is offline   Reply With Quote
Old 03-28-2005, 12:36 PM   #184
gingertooth
Member#: 82242
2005 wrx wagon
wooh wooh!!!!!
awesome, i have to try it too.
gingertooth is offline   Reply With Quote
Old 03-31-2005, 01:44 PM   #185
Mr. Mercado
Member#: 36559
2003 Impreza WRX
What if you don't get it done the first time? Can you did over and over again until you get it right? Or do I have to reset each time I screw up?
Mr. Mercado is offline   Reply With Quote
Old 04-06-2005, 04:40 PM   #186
funsti
Member#: 42744
2005 STU STi White
Addicted to AutoX
Ok, so.. definitively: Does this trick work on STIs or not?
People have mentioned that IAM cannot be logged with Delta Dash on an STi, is that proof?
funsti is offline   Reply With Quote
Old 05-19-2005, 09:23 PM   #187
richde
Member#: 79498
2013 XV
Default No boost gauge!!
ok, for those of us without a boost gauge, approx how much throttle is that?
Rich
richde is offline   Reply With Quote
Old 05-31-2005, 11:20 PM   #188
Vishnu Performance
Vendor
Member#: 14494
WRX Porsche 996
blue & black
[quote=funsti]Ok, so.. definitively: Does this trick work on STIs or not?
QUOTE]
Yes it does. But the proceedure is a bit different. First you have to reset the ECU. Then let the car idle until it is fully warmed up in closed loop fuel control. Then hold approx 4-5psi of boost at 3500rpm for 3-4 seconds. This usually results in a bump of 20whp. This 20whp is something that you would probably see eventually over the course of a few days of driving. But this takes a few seconds and is great for those who are dyno testing/tuning or are just really impatient.
cheers,
Shiv
Vishnu Performance is offline   Reply With Quote
Old 05-31-2005, 11:23 PM   #189
Vishnu Performance
Vendor
Member#: 14494
WRX Porsche 996
blue & black
Originally Posted by adg016
Ed,
Can you confirm that this still works on a 2004 in the same way and to the same degree?
Yes it works the same as the other WRXs. Even with the 4EAT.
shiv
Old 06-14-2005, 08:09 PM   #190
manofoblivion
Member#: 87382
That did not work for me Shiv. I recently installed a couple subs in the trunk and in doing so, I disconnected the battery. When I went out for a 'test listen' I noticed right away that I had lost all my power. Since then I have tried your ECU quicklearn trick many times. I still get beat by all the Cavaliers. The power loss is just incredible. I still reach full boost, there are no error codes, just an insane loss of power. There is no trick that isn't in your post right? I am doing exactly what your post entails, but no restoration of my power. I am quite good at left foot braking though. Is there any other way to manually set my ECU to 'power mode' instead of '***** mode'?
oh, it edited out my cat reference mode, ha!
manofoblivion is offline   Reply With Quote
Old 06-18-2005, 03:36 PM   #191
Triton05
Member#: 69910
2005 debaged sleeper
Platinum Silver WRX
works for me every time I do a reflash .. I love it
Triton05 is offline   Reply With Quote
Old 10-20-2005, 05:09 AM   #192
Buzzman
Member#: 32468
2003 WRX
shiv
Hey Shiv... U've done the "sub zero" upgrade for me back in 2004, in June, I think. I have a 2003 WRX. I was wondering if this was done for me already, during the reflash u've done for me.
BTW, I was the one that u guys left the "adapter" in my car and I mailed it back to u, HAHHAH!
-Buzz
Buzzman is offline   Reply With Quote
Old 10-28-2005, 07:06 PM   #193
jkjersey
Member#: 8399
GC8 JDM STI V swap
cardinal red
will this work with GC8 ECUs?
jkjersey is offline   Reply With Quote
Old 11-27-2005, 04:30 PM   #194
crispyduck
Member#: 98680
Default ECU Fast Learning Article added to www.scoobypedia.co.uk
Shiv and all,
This is great information although I've had to read this massive thread to extract it.
(Shiv) I've added your information to a page called Fast Learning Trick on my www.scoobypedia.co.uk knowledge base. I thought this would be a great addition to this free site helping many other people to benefit from your experience.
If you would prefer I don't plagiarise your words in this way just let me know and I'll delete it, no questions asked.
(All) Please feel free to edit or update the information here (click the edit link and enter a name in the Author field) if it is out of date or you find details of other Impreza variants that have a different procedure.
Thanks again,
-Steve.
crispyduck is offline   Reply With Quote
Old 12-17-2005, 10:41 PM   #195
hondaeater69
Member#: 60324
cheers,
Shiv
are you saying moving the DAM from it's half way position to it's full position results in a gain of 20WHP? I'd like to see that
Old 01-12-2006, 09:49 PM   #196
WRobX
Member#: 102467
2004 WRX
This is a very great trick.......... I wanted to bring this thread back to life!!
Edit: didn't realize this was a sticky......still a great trick though!
WRobX is offline   Reply With Quote
Old 04-19-2006, 10:54 PM   #197
SOCIOPATH
Member#: 5246
2003 wrx
sonic yellow
this trick will not change anything if u have the cobb maps loaded in the car??
SOCIOPATH is offline   Reply With Quote
Old 05-01-2006, 04:34 AM   #198
subiee sTi
Member#: 86944
04 Sti
Blue & Black
Thats a great tip shiv...but I was also wondering will it work if my car was already reflashed by you? Well the reason why I wanted to try it is because I took out my silencer..would it be a good idea to reset the ECU or just let it be?
subiee sTi is offline   Reply With Quote
Old 05-24-2006, 03:06 PM   #199
LosGatosSTI
Member#: 115800
2005 WRX STi
subscribed
LosGatosSTI is offline   Reply With Quote
Old 05-31-2006, 03:53 PM   #200
indelible
Member#: 99573
2015 FXT
I have an HKS TBE and no EM so would it benefit me to do this trick?
indelible is offline   Reply With Quote
re-mapped ecu tiger20002 Subaru Conversions 2 09-03-2014 11:36 AM
Zero to 100% operational in .5 seconds Strider Off-Topic 31 02-01-2008 04:10 PM
Fuel Vapor Technologies Car = 92 mpg and 0-60 in 5 seconds hampster Non-Subaru News & Rumors 11 07-19-2007 12:15 PM
0-60 in 5 seconds, Confirm please? kahtep Proven Power Bragging 11 07-17-2006 01:55 PM
10-100mph in 7 seconds! BlownCobra Off-Topic 39 12-03-2003 12:02 AM
