Old 03-29-2001, 01:50 PM   #1
SubieFL
Member#: 1622
2000 Impreza 2.5 RS
Question Power steering fluid or ATF?
I am going to change my Power steering fluid and bought some Valvoline synthetic power steering fluid to do that. When I looked at the owner's manual it said to use ATF Dexron II, II E, or III. What should I use?
SubieFL is offline   Reply With Quote
Old 03-29-2001, 03:56 PM   #2
pleiades
Member#: 2491
06 Miata
81 Fiat Spider
Post
Use the ATF.
pleiades is offline   Reply With Quote
Old 03-29-2001, 08:40 PM   #3
bender
Member#: 1839
Post
use atf. I used p/s fluid on my last car (88pulsar)when the manual said atf. the pump sounded like a ford p/s pump until I changed it to atf
bender is offline   Reply With Quote
Old 03-29-2001, 08:47 PM   #4
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Post
Always use what the manual says. Otherwise, you can develop a p/s problem (i.e. leak, pump failure).
tmat3 is offline   Reply With Quote
Old 03-30-2001, 06:25 AM   #5
SubieFL
Member#: 1622
2000 Impreza 2.5 RS
Post
Thank you very much guys. You probably saved me alot of money and time.
05 wrx power steering fluid dot 3 or 4? Subey03 Newbies & FAQs 7 04-03-2010 06:20 PM
Power steering fluid, manual tranny fluid, and rear diff fluid ex_boyometric Vancouver Impreza Club Forum -- VIC 17 03-09-2008 05:54 AM
Power Steering instead of ATF...oops rt4me Off-Topic 13 05-21-2007 11:11 AM
power steering fluid not interchangable with ATF? prometheum Service & Maintenance 8 05-08-2007 03:49 AM
is this power steering line or transmission fluid line? thanks racerxl99 Transmission (AT/MT) & Driveline 2 04-05-2006 07:53 AM
