Old 03-29-2001, 09:18 PM   #1
RebelINS
Member#: 2953
2000 Impreza 2.5RS
2005 Impreza WRX STi
Post Rich run condition causing CE light
My CE light seems to come on about once a week, and today when it came on I looked over at my Air/Fuel ratio gauge, and it said my car was running as rich as the gauge could register. I was thinking that maybe this rich run condition was causing bad emissions, and my o2 sensor was setting off the CE light. Does this sound right to anyone else? The light will come on only when I am at WOT. I had my CE light come on for no reason before, and I took it too the my car to the dealership, and all they did was replace the o2 sensor. If it is coming on from a rich run condition, is there anything that Subaru can do to fix this problem. My car is still under warranty, so I would like to get rid of this problem. Also, when the light comes on it stays on for only like a day, so when I get to the Subaru delearship with no CE light, are they just going to tell me that nothing is wrong? I know I am asking alot of questions but I just have one or two more. If Subaru doesn't do anything would a S-AFC work to lean out my mixture, even though I have a 2000 with a MAP sensor? If that won't work, is there anything else I could do to lean out my mixture up top. The only mod I have is an intake.
RebelINS is offline   Reply With Quote
Old 03-30-2001, 05:17 AM   #2
dlkennedy
Member#: 3005
Post
My guess is that you have another bad O2 sensor and that is what is causing the rich condition.
dlkennedy is offline   Reply With Quote
Old 03-30-2001, 07:25 AM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
Post
yeah back to dealer .. when they are done change your spark plugs...if you have been running rich for a long time they will be.. well..... icky ...plus its only $8
Could rich condition cause CEL (UTEC)? ScoobieSnaX Engine Management & Tuning 3 10-09-2002 10:09 AM
CE light, car runs fine? ilmaestro Normally Aspirated Powertrain 9 04-05-2002 10:41 AM
My car is running BETTER with the CE light on..!!??(kinda long) Aaron'z 2.5RS Normally Aspirated Powertrain 10 01-23-2002 12:48 AM
('93-'01) Turbo kit and CE light issues - what causes it and how to prevent it? Jessie James Impreza Forum 4 06-05-2001 09:12 AM
Someone running an ITC without a CE light TMR Impreza Normally Aspirated Powertrain 6 10-16-2000 12:49 AM
