Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 01-17-2003, 09:14 AM   #1
Jack
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
Default Brake Fluid Thread
Like any consciencious track whore, I look for stuff that I'll need for the upcoming track season, do web research and either order what I need or foget completely and get something that doesn't work as well for twice the price last minute.
I've started in the first phase in brake fluid research and have found some interesting stuff. You guys buying Super Blue (gold) might save some money.
First, since we all bleed our brakes before every event (you better!), only the dry boiling point is of interest. I've converted to degrees F to avoid confusion. Plus many of the fluids use this temp in their name.....hey, if we wanted to be metric and SI units, we'd elect Fidel Castro and....... <rant end>
Here's the meat. I'll list what I've got. Product, dry boiling point, price and units sold in. Starting with the highest temp. I have requested info on several of these products, as some say "tested to" the temp. I don't know for sure if that means that its dry boiling point IS that or not. I'll update this when I find out.
626F: "tested to" Wilwood exp600. $19.75/16 oz, $330/<edit 20> case
610F: Neo 610 12oz can. Anyone ever heard of them?
590F: Castrol SRF. $69.95/1L
585F: Motul 600. $12.99/.5L
570F: Wilwood 570. $?
550F: tie: performance friction $6.27/16 oz and
Ford dot3HD (surprise). Don't know price, but it's very cheap.
536F: ATE Super Blue (gold). $9.95/L
527F: AP551. $12.95/L
If this Wilwood exp ends up being all that it looks to be, I'll most likely buy a case and pass some savings on to you track whores. For those of you crying over the fact that ATE Super Blue is actually sub par to pedestrian Ford fluid.....I was as surprised as you. I know lots of guys use it in showroom stock because it's so darn cheap. They bleed after every run if needed. Now I realize that they had better fluid than some of us did.....although I've used Motul mostly.
jack
Old 01-17-2003, 09:18 AM   #2
xstar
Member#: 10821
2008 WRB STi
Jack,
Where did you source your motul fluids?
thanks
xstar is offline   Reply With Quote
Old 01-17-2003, 10:56 AM   #3
re92
Member#: 4715
Big balls, no brain
yo,
when will you have a chance to try out the wilwood exp600 on track? if you still like it after that, i'd be happy to buy some of the cases from you
raj
re92 is offline   Reply With Quote
Old 01-17-2003, 11:09 AM   #4
Jack
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
Alex,
I went searching all over, but the Motul is typically about that price. Shipping is not included and when I've bought it usually look more carefully. Do a google search on motul 600 brake fluid and you'll find a bunch of sources.
Wilwood is pretty widely respected (except their 4 pot Subie upgrades), so I'd have no problem getting a case. Probably just one to start. $330 won't kill me. I think the first track day is in early April......often conflicting with my vacation in the Caribean, but we'll see.
jack
Old 01-17-2003, 11:37 AM   #5
re92
Member#: 4715
Big balls, no brain
$330 buys a set of kumho's for the rainy days at the track let me know if you end up buying the 24 cases - i'll get a few from you for whatever unit price + profit
raj
Old 01-17-2003, 11:48 AM   #6
Snowphun
Member#: 1800
WRX /9-2x/Cooper S
awd/awd/fwd
Default Re: Brake Fluid Thread
Hmm, bleeding and flushing are two different things. If you're just bleeding between events, you've still got a lot of fluid remaining in the system. Flushing all the fluid in the system between events seems excessive (and expensive) to me.
I've used the Ford stuff without issues in the past, but to be honest I've never had serious brake issues.
Paul
Snowphun is offline   Reply With Quote
Old 01-17-2003, 01:46 PM   #7
fastfood
Member#: 7202
2002 Impreza WRX
TrackWhore #09
I've read that some "race" fluids, although high temp are extremely absorbant and can damange the brake system. Also they are not compatible with DOT fluid. Is there truth to this?
Berndt
Sitting on a couple liters of ATE.
fastfood is offline   Reply With Quote
Old 01-17-2003, 02:59 PM   #8
Jack
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
I have read a lot on that. All the fluids that I've listed are compatible with DOT 3 and DOT 4. Some (Motul) don't even list a DOT, from what I remember. They can absorb moisture faster than a regular DOT 3 in some cases. If you are changing (flushing) fluid between track sessions, I can't see it being a problem. Joe Jamoke changes his fluid every 5 years...by buying a new car. An enthusiest changes it every year. Track whores change it by-weekly.
Oh, another "jack's strong opinion" statement: DOT 5 is a fashion statement, not a fluid for "real" cars.
jack
Old 01-21-2003, 11:12 AM   #9
Jack
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
added info from another site....
Heavy Duty Brake Fluid Chart
Brand
DOT Rating Dry Boiling Wet Boiling
AP Racing 550
DOT 3 550F (287C) 284F (140C)
AP Racing 600
DOT 3 572F (300C) 284F (140C)
ATE Super Blue
DOT 4 536F (280C) 382F (194C)
ATE Super 200 (amber color, aka Type 200)
Bosch DOT 3
DOT 3 491F (255C) 288F (142C)
Bosch DOT 4
DOT 4 509F (265C) 329F (165C)
Bosch DOT 4+
DOT 4 536F (280C) 356F (180C)
Castrol LMA
DOT 4 446F (230C) 311F (155C)
Castrol SRF
DOT 4 590F (310C) 518F (270C)
Ford HD (C6AZ-19542-AB)
Motul DOT 5.1
DOT 5.1 509F (265C) 365F (185C)
Motul Racing Brake Fluid 600
DOT 4 594F (312C) 421F (216C)
Performance Friction Z-Rated
Wilwood 570
DOT 3 570F (299C) 284F (140C)
Wilwood EXP600 Plus
DOT 4 633F (330C) 417F (213C)
Min. Temp. for DOT Rating
DOT 3
401F 284F
DOT 4
446F 311F
DOT 5
500F 356F
Old 01-21-2003, 12:03 PM   #10
jsnow
Member#: 14335
I can't believe the dry boiling point of DOT 4 SuperBlue is lower than that of the DOT 3 fluid listed above it.
I think I'm just going to jump to Motul 600. Everyone I know has had good luck with it, and even with SuperBlue, with fresh (read: thick) pads and fresh fluid, I was seeing only very minor amounts of fade even at NHIS.
Thanks for this info, Jack.
jsnow is offline   Reply With Quote
Old 02-07-2003, 02:39 PM   #11
jpmarotta
Member#: 20391
'01 Range Rover HSE
NESIC TrackHoh #555
Default For those having a hard time...
... reading the above table, here's a link:
http://www.seinesystems.com/BrakeFluids.htm
jpmarotta is offline   Reply With Quote
Old 03-10-2003, 12:16 PM   #12
jpmarotta
Member#: 20391
'01 Range Rover HSE
NESIC TrackHoh #555
Default Check this link...
... anyone have any experience with "Project Mu" brand?
http://www.daliracing.com/v666-5/cat...cfm?focus=1002
Looks like one of the highest dry/wet boiling temps and is only $25/liter!
Old 03-10-2003, 05:03 PM   #13
TetsuoMX5
Member#: 13106
95 Gnd Caravan AWD
NESIC TrackH0z #13
Here's another site for ya: http://www57.pair.com/lane/bfluid.htm
Seems to have come to many of the same conclusions as you, Jack. That's a good thing - at least you're not way out in left field.
I'm quite surprised that ATE Superblue ranks so low. Personally, I've never had any trouble with it - brake pads have always given out first. But keep in mind that I've used it in rather light cars - my Miata (2100lbs) and a pair of Saturns (2400lbs). The extra weight of an Impreza might push it past its boiling point a bit quicker - especially if you know what you're doing and are using the brakes for all they're worth.
Still, the next time I change fluid, I may strongly consider the Ford HD. It's a little better than Superblue, and cheap. Do you guys know the story of how and why Ford HD was created? It's rather amusing.
TetsuoMX5 is offline   Reply With Quote
Old 04-04-2003, 11:43 PM   #14
deimos
Member#: 18134
As I'm prepping for my first track day, I'm going through the list of things I'll need. Brake pads and fluid are on the list. I'm going to go looking for some FordHD or ATE to start. However, the big question comes down to flushing. Anyone used those semi-automatic brake fluid flushing machines?
deimos is offline   Reply With Quote
Old 04-24-2004, 02:22 PM   #15
Thug
Choke Artist
Member#: 603
Bump for a great thread.
Tomorrow Im installing:
-PBR Metal Master pads; Front 4 pot, rear stock
-New front OEM 4 pot rotors
-New rear rotors from AutoZone($29.99/each with a 1 year warranty )
-Goodridge Motorsports coated stainless brake lines
-Single Stage brake booster and master cylinder out of Jack's L
-Hella 500s(yellow) w/Kartboy brackets.
Thug is offline   Reply With Quote
Old 04-24-2004, 03:55 PM   #16
re92
Member#: 4715
Big balls, no brain
Today I:
- Installed Carbotech XP's on my car
- Bedded them in (luckily avoiding the local constabulary, who may not have been amused watching a black STi standing on its nose)
- Helped Arex fix his ABS sensor
- Helped Arex bleed his brakes
- Bled my brakes
- Put the stock pads back in
- Loaded all my tools and race tires
Summit Point, here I come!!!!!
Raj
Old 04-24-2004, 03:58 PM   #17
jsnow
Member#: 14335
By which you mean you pulled the fuse, right?
Have fun guys.
Old 04-24-2004, 03:59 PM   #18
re92
Member#: 4715
Big balls, no brain
Have fun guys.
It was a bit harder than that I helped him take off the rear seat and held one end of the left rear ABS sensor while he did all the hard work. I even cheered him on
Raj
[Edit: Btw, I believe he already has his ABS fuse pulled. Btw2, I leave my ABS on. I don't drive that hard and I'd rather not flat spot my tires braking too hard. YMMV, of course ]
Old 04-24-2004, 06:51 PM   #19
xstar
Member#: 10821
2008 WRB STi
Have fun guys.
No, my left rear ABS speed sensor was broken... Long story. It's fixed now.
Old 04-24-2004, 08:06 PM   #20
Rovah
Member#: 1375
2003 WRX Rally Car
For a list of New England MOTUL dealers, please visit htpt://www.triplecaution.us
Cheers! John
Rovah is offline   Reply With Quote
Old 04-24-2004, 09:12 PM   #21
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
All that shiznit better have penetrating fluid stains on it by now or I'm kickin your arse tomorrow.
Fitz
Fitz is offline   Reply With Quote
Old 04-24-2004, 09:24 PM   #22
Thug
Choke Artist
Member#: 603
Done and done.
Old 04-24-2004, 10:08 PM   #23
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
You're a good man... I don't care what Red Rocket says about you.
Fitz
Old 04-25-2004, 08:58 PM   #24
Thug
Choke Artist
Member#: 603
Many thanks to Fitz for doing much more than just helping today. And thanks to Paul too for installing my Hellas. You guys rock. Next time we go out beers are on me.
Disclaimer: Maximum of 10 beers to be bought by me. This means you, Fitz.
Old 04-25-2004, 09:10 PM   #25
paultg
Member#: 437
'91 Miata MX5 (Red)
'09 Impreza OBS (Blk/Gry)
No problem. Thanks again Fitz for the use of your floor space and jack so I could finally get my snow tires off.
Paul G.
paultg is offline   Reply With Quote
Endless Brake Sale - Vita Nuova/SS-S Brake Pads w. RF650 Brake Fluid DriveLineSales Suspension/Brakes/Handling 3 10-09-2009 09:07 PM
STi Brake Pads / SS Brake Lines / Brake Fluid TicketsForMePlease Private 'Wanted' Classifieds 4 11-30-2006 10:47 AM
Brake fluids being mixed when replacing the brake fluid? DVN428 Brakes, Steering & Suspension 1 12-06-2004 02:37 PM
Brake Fluid/Steering Fluid/Diff. Fluid/Transmission Fluid Jasno999 Brakes, Steering & Suspension 11 09-27-2002 11:22 AM
How many ounces of brake fluid to switch fluid? Steppin Razor Brakes, Steering & Suspension 3 09-26-2002 06:36 PM
