Old 06-05-2001, 04:29 PM   #1
inpreza kid
Member#: 3334
Post how do you hook up a voltmeter up to the front o2 sensor?
ok the rear o2 sensor doesn't work worth crap when trying to get a decent reading off it with a A/F guage. i want to hook up a digital voltmeter to the front o2 sensor. here is the hard part. i know you hook the positive wire from the voltmeter to the front o2 sensor(connector b134 wire 22) but where do you hook the ground from the voltmeter? just any ground wire? also what votages should i aim for with a wide band sensor when tuning with a AFC?
inpreza kid is offline   Reply With Quote
Old 06-05-2001, 05:47 PM   #2
Safir
Member#: 3873
. Paradise is
like Disney with hookers
Post
Any piece of metal should do, the entire chassis is grounded, you should be able to pull any screw and use it as a ground.
Safir is offline   Reply With Quote
Old 06-06-2001, 04:38 AM   #3
LUME
Banned
Member#: 2641
2000 Impreza 2.5 RS
Dirt and Bird Poop
Post
Wow, trying to read voltages from an O2 sensor with a multimeter is HARD. It fluctuates SO much...
--Roy
LUME is offline   Reply With Quote
PS3 owners, how do you hook up to DVI inputs? MF-DIF Off-Topic 8 11-19-2008 07:32 PM
How do you hook up DCCD in a WRX with a USDM tranny? DRWRX28 Transmission (AT/MT) & Driveline 7 07-22-2005 12:45 AM
How do you hook up JDM lights with Hanabi 8000k already in them? samwY Electrical & Lighting 0 01-14-2004 04:39 PM
how do you hook up the hpbc w/a UTEC frdawg Engine Management & Tuning 1 04-17-2003 01:00 PM
how important is it to get the front o2 sensor replaced? inpreza kid Canada Region Forum 1 08-02-2001 02:35 PM
