Welcome to the North American Subaru Impreza Owners Club Thursday March 5, 2015
Old 01-17-2003, 03:24 PM   #1
simwahWRX
Member#: 20870
Midnight Black mica
Default electrical question
Using the Hyper Ground System, I'm doing a grounding mod using five points and the existing ground wires.
The instructions are generic, and I need to find the five best points to connect for my WRX. The instructions say "1. cylinder head, 2. manifold or surge tank, 3. cylinder block or transmission, 4. right side of chassis, 5. left side of chassis."
My initial idea is: each side of chassis(2), each side of intake manifold (2), tower strut (1). These will not be in series.
A) any better ideas using five points?
B) best way/point to connect to cylinder head (hanger?), engine block? transmission?
C) will any electrical benefit be lost by connecting to each side of the intake manifold?
simwahWRX is offline   Reply With Quote
Old 01-17-2003, 05:10 PM   #2
Narcisse91
Member#: 3931
WRX, Ninja, RX-7
Legacy, Fiat 850
The biggest affect comes from grounding both sides of the intake manifold. Run a wire from each over to the negative terminal of the battery. The strut towers did nothing (on my car) and neither did grounding near the tranny.
I was really bored last spring when I tried it and actually brought some equipment out to my car and measured the affects of the ground wires...
Narcisse91 is offline   Reply With Quote
Old 01-22-2003, 11:13 PM   #3
mattjk
Member#: 16615
I ♥ my TE51
2009 Nissan 370z
nice!
mattjk is offline   Reply With Quote
Old 01-27-2003, 11:04 AM   #4
Will98RS
Member#: 15816
1998 Impreza RS
how are you connecting wires to these various places? are you just using existing bolts or are you tapping or what?
will
Will98RS is offline   Reply With Quote
Old 01-28-2003, 10:23 AM   #5
pdximpreza
Member#: 17606
2002 Impreza 2.5RS
Use the existing bolts, but make sure it is direct metal to metal contact. Then cover with some sort of petroleum or such to protect against corrosion.
pdximpreza is offline   Reply With Quote
XT electrical question scottsubarus Service & Maintenance 5 01-23-2011 09:45 PM
Electrical question Hazdaz Interior & Exterior Modification 2 05-19-2002 11:45 PM
Basic Electrical Question SubEd New England Impreza Club Forum -- NESIC 6 11-09-2001 11:40 PM
WRX electrical question? PunksWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 08-26-2001 02:20 AM
