Old 01-17-2003, 02:46 PM   #1
no_rex_yet
Member#: 7351
04 330cic
Default how to pull cel codes?
i'm going to autozone to try to get a cel pulled. physically speaking, how do you go about pulling the code? is there a machine they give you, and if so, where does it plug in?
a newbie step-by-step description would be helpful. thanks!
no_rex_yet is offline   Reply With Quote
Old 01-17-2003, 03:09 PM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
they will plug in an OBD-2 Scanner
Old 01-17-2003, 03:24 PM   #3
no_rex_yet
Member#: 7351
04 330cic
cool. by the way, thanks for you all your help with this. do you know where it plugs in (in case they can't figure it out).
Old 01-17-2003, 05:55 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
It plugs in under the drivers side dash. If they don't know this you should run away and find another place to scan your car, all OBDII connectors are the same and are generally located in about the same place regardless of the type of car, that is part of the OBD standard.
Is there a way to pull cel codes without a scanner? Carlito2002WGN Newbies & FAQs 8 06-07-2007 01:11 AM
DIY way to pull CEL code? dgoodrich Normally Aspirated Powertrain 2 07-16-2005 09:00 AM
How to pull abs codes from 96 impreza? simpreza2 Brakes, Steering & Suspension 0 09-04-2004 01:21 PM
How to pull CEL code? PeteDucati Engine Management & Tuning 3 03-18-2004 09:36 PM
how to pull diagnostic codes from ecu? tluzziracing Normally Aspirated Powertrain 7 11-10-2000 08:51 PM
