Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 01-17-2003, 11:26 PM   #1
joe_white
Visiting NASIOC Timeout
Member#: 23112
2002 WRX Sedan
Midnight Black Pearl
Default [email protected] on stock turbo....believe it or not
Well tonight i got faster. Let me start off by saying i'm posting this for the guys that believe and i don't want a flame war started. I just want to let the guys that care know. My quest to 12's is really close.
I ran 5 times.....
My best was
0.53
1.88
5.37
[email protected]
[email protected] Fourth run
My others were
[email protected] Last run
[email protected] Secon run
[email protected] Third run
[email protected] First run after driving 45 miles from Waco with no cooldown.
I will tell you that i had just under a 1/4 tank of 93 octane gas and the temp was about 30.
I have the ecu reflash on order. I'm really afraid that i will run slower with that. Brett says that boost will be considerably lower than what i run now but the timing and fuel adjustments will make up for it. Boost was pretty high tonight. I'm seeing 16-16.5 in 1st-3rd gear. The car seems to like it. 12's should be next time at the track if the ecu does anything. Next mod is going to be 16" ssr comps in the 11 pound version
joe_white is offline   Reply With Quote
Old 01-17-2003, 11:45 PM   #2
jmott
Member#: 6713
2007 Prius
brown
in 30degree weather at that psi I believe it.
if you go with the ssr comps, make sure you get lightweight tires too.
if you put azenis on there, its going to be heavier overall
jmott is offline   Reply With Quote
Old 01-17-2003, 11:50 PM   #3
QA Guy
Member#: 6739
No flames here. Those are good times.
Can't you run a bleed or ball and spring MBC or something with the reflashed ECU to keep your boost high (but still hopefully within your turbo's efficiency range) without any undue problems?
QA Guy is offline   Reply With Quote
Old 01-18-2003, 12:17 AM   #4
Bolster
Member#: 22290
2002 WRB WRX Wagon
Well, that's good, but I'm currently running 0's in the quarter mile. My last run was 0.25 @13,455 mph. My 60 ft times are usually around 0.00003 or so, if I get a good launch. Wanna know how I do it? It's those splitfire sparkplugs that Pep Boys sells combined with a bottle of slick 50 gas treatment and very fine tunning of tire pressures on the stock RE92's.
OK, I was lying- at least about the slick 50 part. Seriously, good times though. This weather seems like the right stuff for good times. Was it very windy? -Bolster
Bolster is offline   Reply With Quote
Old 01-18-2003, 01:12 AM   #5
metoo
Member#: 4764
2004 STi sold :(
forizzle
Other than a 100% stock WRX turbo and 1/4 tank of 93 octane gas, what was your total 1/4-mile setup (mods, weight reduction, chemical enhancement etc.)?
metoo is offline   Reply With Quote
Old 01-18-2003, 01:17 AM   #6
joe_white
Member#: 23112
2002 WRX Sedan
spare tire and jack removed was only weight reduction (unless you count me only weighing 125!)
PDE uppipe
APS turboback (catless)
Hallman mbc
Samco hoses
HKS BOV
K&N filter with resonator/silencer removed
bfgoodrich comp ta kdw 205/55/16 (stock wheels)
Old 01-18-2003, 01:29 AM   #7
metoo
Member#: 4764
2004 STi sold :(
forizzle
PDE uppipe
Hallman mbc
Samco hoses
HKS BOV
Subaru must have accidently shipped you their ringer that was supposed to go to magazines for testing.
Old 01-18-2003, 01:50 AM   #8
joe_white
Member#: 23112
2002 WRX Sedan
Maybe so?!?!?! Hope so
Old 01-18-2003, 08:32 AM   #9
jmott
Member#: 6713
2007 Prius
brown
at 30degree temps he is getting a big power boost. like 15hp just from air density, and how knows how much from increased intercooler efficiency
Old 01-18-2003, 01:41 PM   #10
stickman
Member#: 13890
2007 Mazda CX 7
Icy Blew
good times
let see the same when it gets warmer
stickman is offline   Reply With Quote
Old 01-18-2003, 04:17 PM   #11
joe_white
Member#: 23112
2002 WRX Sedan
you will, because by then i'll have some more mods
Old 01-18-2003, 08:03 PM   #12
2003 sedan
Member#: 24103
Thumbs up Good run joe
Very good run. As you all know I'll be at redline in the afternoon. I have been posting it all week long (or longer)!!!! I am out to back joe up on his stock turbo times. All I have is the silencer box out. GMK boost controler, and a strait pipe where the muffler was. I am expexting 8.5s or better with a under 2.0 60ft my car pulls hard with no spark knock I also have an unrestricted up-pipe and done the resistor mod. Stock WRX $100.00 and some labor I should be in joe's time area. I will post it in the evening good or bad. Wish me luck. GMK
2003 sedan is offline   Reply With Quote
Old 01-18-2003, 09:09 PM   #13
stickman
Member#: 13890
2007 Mazda CX 7
Icy Blew
dwight u are being very optimistic.
i think the cats in the downpipe and mid pipe will hurt ur times just a little
let us know tho
Old 01-18-2003, 09:39 PM   #14
2003 sedan
Member#: 24103
Talking We shall see
We shall see.
Old 01-18-2003, 09:39 PM   #15
wrx320
Member#: 28631
2002 WRB wrx wagon
AVO stg I,II Shiv ECUtek
good luck. I cant wait 2 see how you do.
<---- *having never made a pass down a dragstrip* How do you guys launch your car to get less than 2.0 sixty footers?
wrx320 is offline   Reply With Quote
Old 01-18-2003, 09:44 PM   #16
2003 sedan
Member#: 24103
Talking re
how you do it? By listening to Cake "Going the distance" over and over and over then in the morning I'll drink alot of coffee with no food. I will either be lighting fast with my reactions or pass out on the starting line. Iam running 17-18 psi of boost by the way I hope this would help its spools very fast and I can speed shift with the best of em. Hey stick whats up! Wish you could make it. I hope someone can or ya'll will treat me like Joe
Old 01-18-2003, 09:55 PM   #17
stickman
Member#: 13890
2007 Mazda CX 7
Icy Blew
damn thats alot of boost for stock turbo and restrictive (somewhat) exhaust.
launching these things are no joke. its hella hard.....
Old 01-18-2003, 10:07 PM   #18
wrx320
Member#: 28631
2002 WRB wrx wagon
ROFLMAO..*I just took out my Cake CD*..I was just wondering since I havent evar gotten a time slip.....Since I am a street driver I don't do tranny drops at green lights So I just wondered how hard you have to be on your WRXs drivetrain in order to get a 1.8-2.0 sixty footers,dig?
Old 01-18-2003, 10:15 PM   #19
Smahatma
Member#: 21492
you have to drop it like a ***** in heat
Smahatma is offline   Reply With Quote
Old 01-18-2003, 10:33 PM   #20
2003 sedan
Member#: 24103
Talking Cake
Thats the best place to do a 4 whell burn is on the street. No VHT on the stoplight starts.Reluctantly crouched at the starting line. He's going for speed. She all alone all alone in her time of need. anyhow. Wish not failures
Old 01-18-2003, 10:34 PM   #21
2003 sedan
Member#: 24103
Default by the way
I'll call it GMKstage 2 mods.
Old 01-19-2003, 03:03 PM   #22
krave
Member#: 13908
2002 WRX Sedan
296 whp
Not bad, you should be able to get a better 60' then that though.
The MPH is believable only because of the freezing weather.
krave is offline   Reply With Quote
Old 01-20-2003, 01:18 AM   #23
wrx320
Member#: 28631
2002 WRB wrx wagon
