Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 02-15-2001, 10:21 AM   #1
Tuning Factory Inc.
Vendor
Member#: 3600
Post 2.1 liter kit
Some of you may have already seen this but I thought it was cool.
<IMG SRC="http://www.toda-racing.co.jp/product/item/piston/13000EJ20T0.jpg" border=0>
2123cc kit from Toda Racing. Unfortunately it's $3200 and for some wierd reason they say 8.5:1 CR.
Tuning Factory Inc. is offline   Reply With Quote
Old 02-15-2001, 10:31 AM   #2
Jay_UK
Member#: 296
Post
Stoker kits are quite common... but can offer good increases in torque.
The stock CR is 8:1... they have simply upped it slighty...
The pic looks like it uses a stock Subaru crank and rods... with aftermarket pistons.
I could be wrong..very difficult to tell just looking at a pic.
J.
Jay_UK is offline   Reply With Quote
Old 02-15-2001, 11:23 AM   #3
DeliciouSpeed
Member#: 3389
07 STImpreza
Satin
Post
Toda is good for that, the honda B16a to b18 kit is noting more than the crank and rods from a B18 with custom pistons balanced and the like.
Ken
DeliciouSpeed is offline   Reply With Quote
Old 02-15-2001, 01:01 PM   #4
roninscar
Member#: 2306
2000 RS Sedan
Blue Ridge Pearl
Post
If it has shorter conrods, then the combustion chamber volume will increase, thus overall displacement will increase. Of course, that would lower the compression though.
scotto
roninscar is offline   Reply With Quote
Old 02-16-2001, 12:13 AM   #5
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
Jay - If it raises the output volume, wouldn't it HAVE to have a new crank? I though pistons only change compression ratios.
Old 02-16-2001, 12:29 AM   #6
Dustin
Member#: 1188
2007 FJ Cruiser
Wink
Hmm... Larger bore maybe?
db
Dustin is offline   Reply With Quote
Old 02-16-2001, 12:44 AM   #7
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
Hmmmmm... why would they include a crank in the kit then?
Old 02-16-2001, 08:52 AM   #8
Aspen
Member#: 145
Banned to
Housework for Summer
Post
8complex,
You can do it any of the three ways or combinations to get increased displacement.
crankshaft, connecting rods, pistons.
Aspen is offline   Reply With Quote
Old 02-16-2001, 10:36 PM   #9
Aspen
Member#: 145
Banned to
Post
Yup, Yup, I stand corrected on just using the connecting rod issue.
Old 02-17-2001, 12:10 AM   #10
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
Post
Yeah, what he said... If the piston isn't as tall as stock it'll increase the volume of the comp chamber.
EDIT: Tall meaning distance between the connecting rod and the top of the piston.
[This message has been edited by horatio102 (edited February 16, 2001).]
CosmoTheCat is offline   Reply With Quote
Old 02-17-2001, 12:15 AM   #11
Catfish
Member#: 1322
2000 2.5RS Sedan
72 Datsun 240Z
Post
Roninscar...
Not so.
Shorter Con_rods only lower the CR because the piston will not travel as far up the cylinder, thus reducing the 'squish' area. But, the overall distance the piston travels will be the SAME as before unless you change the stroke.
To increase the engine capacity, you must either do one, two or all of the following...
A: Increase the stroke of the crankshaft
B: Increase the diameter of the pistons
C: Get more a bigger engine with more cylinders.
There is no other way to increase static displacement.
Remember the formula for engine capacity is:
Engine Displacement = #Cylinders x pi/4 x Bore(2) x Stroke
Cylinder Volume = pi/4 x Bore(2) x Stroke
See, Conn_rods are nowhere in the equation.
This kit must increase the stroke, otherwise why would the crankshaft be part of the kit? Maybe it still uses stock rods, but has different pistons to accomodate the different piston pin offset required to keep them from banging into the head.
Dave
[edit] forgot something
[This message has been edited by Catfish (edited February 16, 2001).]
Catfish is offline   Reply With Quote
Old 02-17-2001, 03:04 PM   #12
Section 8
Member#: 821
Post
On the crank issue.....
It could be a OE crank that has had material added to the rod journals (??? the area where the rods attach to the crank) and reground effectivly making a longer stroke with a "standard" crankshaft.
Or it could be a completely new casting/forging.... I can't tell by a picture.
Greg
Section 8 is offline   Reply With Quote
ALAMO 2.1 stroker kit - piston problems ? ElSpa Built Motor Discussion 35 09-30-2009 10:32 PM
2.5 liter oil pan on 2.0 liter, oil pickup cabe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-07-2008 11:31 AM
Interchangeability of 2.2/2.5 liter Driveshafts? whtlegacy Transmission (AT/MT) & Driveline 1 04-13-2004 12:16 PM
2.5 liter heads on 2.2 liter block evo2rex Subaru Conversions 1 01-27-2004 03:46 PM
2.2 or 2.5 liter STI for US market? Oldnslow News & Rumors 26 08-01-2002 04:41 PM
