Old 03-31-2001, 11:48 PM   #1
Joncas
Member#: 5349
Post 99 RS seeks heavy breathing intake...
99 RS seeks heavy breathing intake that doesn't lean out or break $300 MAF's. (real life experience necessary).
In all seriousness - does anyone make an intake that can work with the 99's standard ecu and MAF - and still make a few ponies? JC Sports? Weapon R? Anyone have any real life HP expectations?
Pre-Thanks
Joncas is offline   Reply With Quote
Old 04-01-2001, 07:56 AM   #2
Safir
Member#: 3873
. Paradise is
like Disney with hookers
Post
I believe both rallispec and larry ganz have intakes that work with the MAF on MY99 but I do not know for sure if they tend to cook them or not... anyone with actual experience?
Safir is offline   Reply With Quote
Old 04-01-2001, 04:00 PM   #3
Joncas
Member#: 5349
Post
What about running lean - do all the intakes do this? Is there one that doesn't? Any real life experience?
Thanks
Old 04-01-2001, 05:11 PM   #4
Buckbomb
Member#: 2573
Post
You are going to run lean no matter what. It is an ECU problem, not an intake problem. In order to correct it you need a SAFC. The car only runs lean at WOT. Unles you drive at full throttle all the time, you really won't have any lean running issues. Have fun!
Buck
Buckbomb is offline   Reply With Quote
Old 04-01-2001, 07:32 PM   #5
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Post
Revision is offline   Reply With Quote
Old 04-02-2001, 12:16 AM   #6
P.K. Motorsports
Member#: 1110
1999 RS
Post
Any Impreza intake can be adpated to a '99 with a minimum of work and a couple of readily available additional parts. Please do a search, this has been covered hundreds of times.
P.K. Motorsports is offline   Reply With Quote
Old 04-02-2001, 12:40 AM   #7
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
Post
I'd go with the JC Sports one, it so far has the longest track record of working w/o causing the blowing up MAF's.
GTBGUY is offline   Reply With Quote
Old 04-02-2001, 09:25 AM   #8
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Post
ISR's intake seems very MAF friendly. I have it on my 99 and its very solidly mounted. Look into it. I can send you pics if you want to see it installed. I have added a custom made heat shield for it, and I love it.
STiShawn is offline   Reply With Quote
Old 04-02-2001, 01:58 PM   #9
Joncas
Member#: 5349
Post
Thanks for the real life opinions. I'm used to setting up HO v8's with carbs and distributors, the computer stuff is new to me. Does anyone run a Apexi S-AFC? Did anyone install/configure it themselves? How hard is it?
Thanks as always
Old 04-02-2001, 11:43 PM   #10
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Post
You can get a a cone filter conversion kit from www.imprezars.com/spectrum.htm#filtermaf that doesn't need an AFC and improves breathing of the motor.
<IMG SRC="http://www.imprezars.com/images/filtermaf.jpg" border=0>
I am trying to finish up a similar intake that uses a shielded cold air filter but the 3" maf adapters I am getting at wholesale cost are held up a little longer.
Larry
ImprezaRS dot com is offline   Reply With Quote
99 Forester intake manifold same as 99 RS? jwan01 Normally Aspirated Powertrain 1 09-14-2006 12:03 PM
Whats the difference? 99 RS intake manifold & 00-01 RS? STi - IMPREZA Normally Aspirated Powertrain 10 10-03-2003 09:10 AM
Heavy Breathing...pant pant... MattSEG Off-Topic 20 02-18-2003 08:32 PM
Need to hear from people who put an intake on a 99 RS... JasonRan Normally Aspirated Powertrain 5 01-25-2002 03:58 PM
cold air intake for 99 RS PEARLBLK99RS Normally Aspirated Powertrain 11 07-09-2001 09:22 AM
