Old 01-18-2003, 02:01 PM   #1
Flesher
Member#: 7921
Sliver
Default Hella FF300 Driving Light Wiring
Is there anyone out there who's managed to install a set of Hella Drivging lights (FF300 in my case) so that they work correctly (driving lights are only on with switch on and High beams on)? I tapped into the headlight switched ground, but that has resulted in Driving lights on with switch and not-lowbeams. In other words, the driving lights will come on with no headlights OR highbeams. Upon further investigation with a voltage meter, I discovered that the headlight wiring is:
Lights Off Low High
Red [HB switched ground] G Pos G
Red(Blue) [common positive] None Pos Pos
Yellow(red) [LB switched ground] G G Pos
Is there another wire that can be tapped that is grounded only when the HB are on?
Flesher is offline   Reply With Quote
Old 01-18-2003, 03:11 PM   #2
RidinLow
Member#: 329
1995 325i
Arctic Gray
Yep, I have the same thing going on with my FF200's. Pulling out the DRL relay behind the glovebox should fix it.
RidinLow is offline   Reply With Quote
Old 01-18-2003, 06:33 PM   #3
Gonz
Member#: 18642
2005 Impreza WRX STi
RidnLow,
which fuse is that? I'd like to try it. My Cibiés are wired the same as above. It's not a problem because the switch allows you to turn them off with parking lamps or headlights off.
I disabled my DRL's at the module near the factory boost solenoid.
G
Gonz is offline   Reply With Quote
Old 01-19-2003, 05:01 PM   #4
RidinLow
Member#: 329
1995 325i
Arctic Gray
It's not a fuse, it's a little relay behind the glovebox (fuses are on driver's side). Doing a search for DRL's in this forum should shed a little more light (no pun intended) on this subject... I can't remember what that thing is at the moment.
Disabling the DRL's by the boost controller only works if you don't have any aftermarket lighting.
Old 01-19-2003, 06:35 PM   #5
Flesher
Member#: 7921
Sliver
In probably the most counter-intuitive piece of wiring ever in a non-british car, the LB ground lead goes hot when the HB is grounded. I have thus wired the blue Hella lead to the LB, and the rest of the connections as in the instructions. This seems to work so far. Putting 100W bulbs in the lights, however, smokes the fuse pretty fast. I think I'll be content with 55W for awhile.
Nathan
Old 01-19-2003, 10:05 PM   #6
Flesher
Member#: 7921
Sliver
Now that it's dark, I went out and tested my new wiring. They seem to be working perfectly. So, for those trying to hook up Hella (and possibly other) driving lights, ignore the whole ground-switched concept. Hook the relay lead up to the Low Beam wire (driver's side is Yellow-Red), and the battery connections as in the instructions.
Nathan
Old 02-28-2003, 10:27 PM   #7
thechickencow
Member#: 16840
98 M3, '14 outback
03 ktm 640a
Thank you...
Does this setup allow the driving lights on with just parking lights? I'm trying to draw a schematic in my head...
Jay
thechickencow is offline   Reply With Quote
Old 08-08-2003, 02:39 AM   #8
wrxinfx
Member#: 10515
2002 WRX Sedan
Default here's a way to do it...
Hi guys - I finally figured out a pretty elegent way to wire my FF200's so they are triggered by the High beams. Check my thread here:
http://forums.nasioc.com/forums/show...13#post3770113
Casey
wrxinfx is offline   Reply With Quote
Old 08-08-2003, 08:28 AM   #9
WRX Bamboo Steamer
Member#: 8239
I have been using this method (http://forums.nasioc.com/forums/show...hreadid=306666) for well over a year now without any problems. Basically, the driving lights only come on with the AUX switch pressed and the high beams on. It uses the factory relays so no extra parts are needed.
WRX Bamboo Steamer is offline   Reply With Quote
WTT Hella 500 Driving Lights for Hella 500 Fogs XanRules Private 'Wanted' Classifieds 1 02-22-2009 11:22 PM
Supertone/Hella 500 Driving Lights Wires G Langa Electrical & Lighting 0 10-02-2008 09:45 PM
wiring trouble: hella 500 driving lights! summitwrx Interior & Exterior Modification 9 11-24-2007 12:12 AM
Hella FF1000 Driving light or 500 Driving STi Tokyo Electrical & Lighting 50 10-29-2004 12:24 AM
Hella FF300 driving lights installed. HIHO Legacy Forum 9 01-16-2002 11:46 AM
