Old 01-20-2003, 03:48 AM   #1
M3sum
Member#: 18226
2001 M3
Laguna Seca Blue
Default How does our fuel system work?
I got some various questions here. I tried searching but didn't get any specific answers
How do you calculate injector duty cycle in relation to the wrx system. the injectors are ~420cc/min, pump is 130lph, but how do you calculate the cycle? I assume we gotta factor in the boost too.
Also, how much psi of fuel pressure does our system push PER psi of boost? A friend of mine is using a vortech 8:1 on his miata so he's getting 8psi of fuel per psi of boost so i am wondering what ours is on the stock FPR. Thanks.
M3sum is offline   Reply With Quote
Old 01-20-2003, 04:42 AM   #2
Austin
Member#: 7089
2016 STi
Default Re: How does our fuel system work?
Injector duty cycle is the percentage of time the injector is actually open compared to the maximum time available to be open.
If you know the time the injector is open during a given cycle (injector on time), you simply divide that number by the maximum injector on time.
Injector on time is based on load determination and determined by the computer's fuel delivery equation.
Maximum injector on time is based on motor RPM.
Austin is offline   Reply With Quote
Old 01-20-2003, 04:59 AM   #3
Austin
Member#: 7089
2016 STi
Your fuel pressure regulator sets a static fuel pressure of 43.5psi. 43.5psi is 3 bar.
Static means referenced to atmosphere. The FPR is referenced to manifold pressure/vacuum. At idle, when there is 15-18-ish inches of vacuum in the intake manifold, fuel pressure is lowered by that much.
The stock FPR is a 1:1 rate.
29.92 inches = 14.7psi = 1 atm. 1 bar = 14.5psi, so it's almost a 1:1 conversion.
At idle, your fuel pressure should be 35-38psi.
Under boost, fuel pressure is more than 3 bar. Boost pressure + 3 bar = fuel pressure.
If you're at 14.5psi boost (which is 1 bar boost), then your fuel pressure should be 4 bar.
Injectors are rated at 3 bar. The stock 420cc injectors flow that much at 3 bar fuel pressure.
With a 1:1 regulator, the differential pressure across the injector (fuel rail pressure - manifold pressure) remains at a constant 3 bar. Because of that, the only variable to determine fuel delivery is injector on time.
Old 01-20-2003, 05:43 AM   #4
hotrod
Member#: 14141
2002 Impreza WRX
Default Another bit of info
Austin has already done an excellent job of covering most of your questions, but here is a thread that you might want to look at for some additional information on the subject.
http://forums.nasioc.com/forums/show...&highlight=IDC
By the way the injector dead time (IDT) for our High impedence injectors is 1.3 - 1.4 ms according to the folks at RC engineering.
Larry
hotrod is offline   Reply With Quote
Old 01-20-2003, 06:08 AM   #5
M3sum
Member#: 18226
2001 M3
Laguna Seca Blue
Default Re: Re: How does our fuel system work?
Cool thanks for all that info Austin!
I guess what I am still confused is what you said here. Do you mean that at 3 bar fuel pressure, the injectors are flowing 420cc?? What happens at boost and 4 bar fuel pressure? How can it flow more than its rated? Or maybe im just not getting what you are saying......
Old 01-20-2003, 06:17 AM   #6
Austin
Member#: 7089
2016 STi
Default Re: Re: Re: How does our fuel system work?
At 3 bar differential pressure, a 420cc injector will flow 420 cc's of fuel per minute. Injector on times are measured in milliseconds. A 420cc injector will flow 7 cc's per second, or .007cc's per millisecond.
Your boost guage shows you pressure inside the intake manifold. The spray end of the injector is subjected to intake manifold pressure. If intake manifold pressure is 14.5psi (1 bar) and fuel pressure is 58psi (4 bar), then there's 3 bar differential pressure across the injectors. If intake manifold pressure is 0psi, then fuel pressure is 3 bar, and d/p across the injectors is 3 bar. If intake manifold pressure is -8psi (about 17 inches of vacuum), then fuel pressure is 35.5psi, so there's still a 3 bar d/p across the injector.
That 3 bar differential pressure remains constant so that, when the computer wants to deliver a certain amount of fuel, all it needs to do is vary the injector on time.
Old 01-21-2003, 12:33 AM   #7
M3sum
Member#: 18226
2001 M3
Laguna Seca Blue
Damn Austin, you know too much, but thanks for your info!
Anyways I *think* I get it now. Previously I had the misconception that the 420cc/min just means the max the injectors will flow but say at idle it will be doing 100cc/min. I guess the injector flow stays constant but the duty cycle varies.
So to rehash, basically what you are saying is that it will flow 420cc/min at any point that its on, the only difference being that under light load, it will have less injector on time, and at heavier loads, it will have more injector on time which than equates to higher duty cycle.
So with the STi 565cc/min injectors, since its squirting more when "on", it doesn't have to be "on" as often....
Correct me if I am wrong.
Old 01-21-2003, 01:29 AM   #8
Austin
Member#: 7089
2016 STi
You're exactly correct.
With my TEC I see/log my duty cycles all the time. At idle, I'm usually at 1 or 2% duty cycle. During cruise, I'm usually <15% duty cycle. Only under high boost (about 20psi) at high rpms do I approach 90 or 100% duty cycle with my 650cc injectors.
Keep in mind that, for the same injector on time, duty cycle at 3500 rpm will be half what it is at 7000 rpm. That's because at slower engine speeds, there is more time available for injectors to be open.
Here's a screen capture of my current map's duty cycle table. Keep in mind that 101kpa = 14.7psi, so about 205kpa is 15psi boost. Only at 21 psi boost at 7000 rpm do I hit 100% duty cycle.
Old 01-21-2003, 03:53 AM   #9
SuicidalLabRat
Member#: 4096
noun [ ve·hi·cle ]
a carrier,as of infection
Or you can run a really high base pressure and push your injectors, though you may become prone to pattern failures.
SLR-
SuicidalLabRat is offline   Reply With Quote
How does a Cobb Accessport work and will it work with my parts? Twin_Cities_WRX General Community 5 03-08-2009 01:39 AM
How does a Cobb Accessport work and will it work with my parts? Twin_Cities_WRX Newbies & FAQs 2 03-07-2009 07:22 PM
Lost Oil Pressure ?? how does the oil system work 500hp sti StiChip Normally Aspirated with bolt-on Forced Induction Powertrain 5 11-26-2007 12:13 PM
Fuel system work CrowbarKen Mid Atlantic Impreza Club -- MAIC 14 06-11-2004 09:21 AM
How Does WRX Fuel Injection Work? 03GLHWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-09-2003 05:59 PM
