Old 02-25-2001, 04:21 PM   #1
gerardchau
Member#: 1465
2000 rs sedan
brp
Post which air fitler is better?
AMSOIL or K&N?
which one is better? price and advantage?
i am planning to get larry cold air intake..
seem like this intake is better than all other intake..wepR, minam, JC,..
larry cold is really the best?
gerardchau is offline   Reply With Quote
Old 02-26-2001, 01:05 PM   #2
John2.5RS
Member#: 1140
2013 Ecoboost'd F150
Grey
Post
The new K&N is better than an Amsoil. Larry's intake is the best bang for your buck as far as intake's go.
John2.5RS is offline   Reply With Quote
Old 02-26-2001, 01:23 PM   #3
jlyttle
Member#: 2815
2004 Forester XT 5sp
Post
Why is it better? Do you have documentation?
jlyttle is offline   Reply With Quote
Old 02-26-2001, 02:25 PM   #4
WRX1
Member#: 3533
2002 Impreza WRX
WR Blue
Post
JUst Curious to why the K&N is better than the Amsoil. Is it price, air flow, easy cleaning?? Just curious. If it is price, I can fix that. I am an Amsoil dealer, so I will sell them at cost.
WRX1 is offline   Reply With Quote
Old 02-26-2001, 07:18 PM   #5
96Lconversion
Member#: 3604
2003 Impreza WRX
2004 S2000
Post
I have a K&N cone filter on my 96L sedan and it kicks a$$. No low end power loss, and a definite power increase throughout the power band that can be felt (and heard! such a nice sound!) I would definitely recommend the K&N! As for the amsoil I can't say, I've never had one in.
96Lconversion is offline   Reply With Quote
Old 02-26-2001, 07:19 PM   #6
ImprezaRS dot com
over boosted again
Member#: 1458
2006 B9 Tribeca LTD
2005 Impreza 2.5 RS
Post
I already sell AMSOIL's for $10 under my cost when you buy an intake !
The AMSOIL can go 25,000 miles between cleanings, and should last longer than K&N before falling apart - I would also assume the AMSOIL has more surface area to capture dirt. I believe they perform the same as a K&N.
So, that's what I think...
Larry www.ImprezaRS.com
ImprezaRS dot com is offline   Reply With Quote
Old 02-26-2001, 07:59 PM   #7
Delhi
Member#: 4511
Post
Larry,
Alot of ppl recommend your intake. Upon doing some search I notice that your intakes are too long therefore poking the fender out. Has that been corrected yet? Also there seems to be alot of iterations. It gets quite confusing. Are the specs on your website latest? Thanks.
Delhi is offline   Reply With Quote
Old 02-26-2001, 08:07 PM   #8
5 Door Man
Member#: 2019
Post
Delhi-The only problem with them poking the fender out was the fault of the installer not being careful when positioning it inside the fender. I followed that post rather closely.
5 Door Man is offline   Reply With Quote
Old 02-26-2001, 08:53 PM   #9
ImprezaRS dot com
over boosted again
Member#: 1458
2006 B9 Tribeca LTD
2005 Impreza 2.5 RS
Post
Delhi - Once the intake is attached to the airbox, it is 1.5 - 2" away from the inside of the outer fender, and CANNOT touch the fender and ding it. Don't forget the picture someone posted showing their fender dented in from an accident, and the pushed in fender still NEVER contacted the intake that was on the car at the time.
It was likely occuring during the install, and even then, only 3 or 4 people out of over 100 Version 5's sold had this unfortunate mishap - and all the info at the wesite is current.
I thought about cutting the intakes shorter anyway, but it is still possible to poke it in too far and ding the outer fender no matter how much pipe I remove, unless I make the intake only 4 inches long so you can't reach the inside of the outer fender But, then it wont reach the airbox...
Which Car Mag is Better? el~sharko General Community 0 05-18-2003 05:58 PM
which set up is better? 1WRX2NV Bay Area Impreza Club Forum -- BAIC 6 11-06-2002 01:20 AM
which head unit is better? littleblue Car Audio, Video & Security 8 11-05-2002 03:01 PM
which brake kit is better gqzboy Brakes, Steering & Suspension 5 10-15-2002 03:02 PM
Which ECU reset is better? Fred Fredburger General Forum Archive 2 01-10-2001 12:23 AM
Message Board Statistics All times are GMT -4. The time now is 08:01 AM.
