Old 01-20-2003, 02:45 PM   #1
RexTastic
Member#: 28666
2004 Impreza WRX
Default Quick Radar Detector Hard wire question
I want to hardwire my detector using the auto dimming mirror harness. Instead of cutting up my regular cord, I bought one that fits from Radio Shack. The cord that goes to the lighter has a fuse in it. Do I still need to add a fuse in line on my wire or is the harness already covered somewhere?
RexTastic is offline   Reply With Quote
Old 01-20-2003, 03:37 PM   #2
mhbrown
Member#: 12537
'02 WRX Sportwagon
WR Blue Pearl
The mirror harness is obviously fused. My wiring manual is elsewhere; but IIRC, it is a 15 amp circuit.
Your choice. If the detector gets funky, it will take a lot to blow the car's fuse box fuse. The inline fuse is a very low amp and will blow right away without affecting the rest of the stuff in your car.
My take -- be safe and fuse the detector.
mhbrown is offline   Reply With Quote
Old 01-20-2003, 03:58 PM   #3
RexTastic
Member#: 28666
2004 Impreza WRX
http://www.clubwrx.net/forums/showth...radar+detector
There PlatinumWRX says "If you wire straight into the car's power, you'll get a lot of electrical noise from the alternator and ignition and such. It'll hurt the performance of your detector BIG TIME!" then he goes on suggesting to buy a hardwire kit.
Unfortunately, there is no hardwire kit for my detector so what to do?
If I do hardwire it, I will fuse it just to be safe.
Old 01-20-2003, 10:56 PM   #4
il96
Gone... But not forgotten
Member#: 13082
That is B.S. The power you get from the 12V lighter socket is not filetered any better than at any other point in your car. The battery does filtering, so don't worry about it. Many people including myself have their detectors hardwired to various points in the car, none complaining. I would still suggest putting a 3 - 5 A fuse inline with your detector though. This way even if your detector burns it won't take out the whole interior lighting with it.
il96 is offline   Reply With Quote
Old 01-21-2003, 10:49 PM   #5
RexTastic
Member#: 28666
2004 Impreza WRX
Thanks for clearing that up. I will put a fuse in line but I have another question. You suggested a 3-5 amp fuse but I just realized that the fuse in the lighter cord is 1 amp. Should I use a 1 amp fuse? The manual says 1 amp fuse only.
Old 01-22-2003, 11:52 AM   #6
Jack
Add Lightness
Member#: 13699
2004 45k mile Outbac
(From General)
Your radar detector should have come with a fuse already. Use that one. The fuse is protecting you from too much current melting the radar detector wire....which is way smaller than wire in the car. 1A will probably do if you don't have one with the detector.
jack
Old 01-22-2003, 05:16 PM   #7
RexTastic
Member#: 28666
2004 Impreza WRX
jack
Since I will be using my own wire to power it (I won't be cutting up the one that came with it since I will use it if I have to take a different car), so it won't have a fuse. To be on the safe side, I will add a fuse to my wiring job. I just need to know if 3-5A will do or do I need to go down to 1A?
Old 01-22-2003, 05:44 PM   #8
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Fuse the wire to the detector with the same value fuse as in the original power wire. If it's 1A, use that.
A good rule of thumb is to fuse a device at twice its expected max current drain. This allows for turn-on surge and peak draw without blowing fuses but ensures that the fuse will blow immediately if there is a problem with the device or wiring.
The manufacturer of the detector has already taken all of this into account so no need to second guess them.
escort 9500 radar detector hard wire kit Noob Question bnr34rb26dett Electrical & Lighting 11 11-20-2008 08:13 PM
escort 9500 radar detector hard wire kit Noob Question bnr34rb26dett Newbies & FAQs 1 11-12-2008 11:41 AM
Radar detector/ neons...wiring Slamsitin Electrical & Lighting 1 03-10-2004 08:09 AM
radar detector hard wire or other 12v item TRM Electrical & Lighting 2 12-16-2003 08:08 PM
Quick radar detector power question RexTastic Electrical & Lighting 3 03-07-2003 06:42 PM
