Old 01-20-2003, 06:24 PM   #1
Quick WRX
Member#: 19689
2002 GDA TXS stg 4+
280 whp
Default P0303 Code common?
I got a OBD II scanner today and pulled the codes I had. I had a P0301 and P0303. I have a '02 WRX with Turbo XS stg 4+ (VF34, STI injectors, Walbro fuel pump, Uppipe, Turbo Back, Vishnu Pulley). After searching its seems that the those codes are vary common and not much action is taken when they show up. Does this sound right to you?
PS - "Innova OBD II code reader" at Kragen for $128. Great deal if your looking for a easy to use code reader.
Quick WRX is offline   Reply With Quote
Old 01-20-2003, 06:55 PM   #2
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
Have a Nice Day? common??
P0301 & P0303 are mis-fire codes for cylinders 1 & 3.
well got them once. and the dealer ship (subaru of jacksonville)
warranted the replacements of defective injectors. it only
took a week for them to get the injectors from across the
nation, one from colorado and the other from atlanta.
but no sted fast rule that says it the injectors. just what
they replaced on my car.
Ben
Old 01-20-2003, 07:05 PM   #3
WRX4FUN
Member#: 24173
2002 WRX Sedan
Blaze Yellow & Enkei RPM2
I had the P0301 & P0303 mis-fire codes about a month ago and I called the dealer and they advised to reset the codes and if they came back to bring my car in but I have not got those codes again.
WRX4FUN is offline   Reply With Quote
Old 01-20-2003, 07:16 PM   #4
jcme262
Member#: 13694
got em once, just wrote it off to communication gap between my old unichip & ECU
jcme262 is offline   Reply With Quote
Old 01-20-2003, 08:07 PM   #5
Quick WRX
Member#: 19689
2002 GDA TXS stg 4+
280 whp
I dont know what order they came in but I got one the day after I put in the STI injectors. The other about a 2 weeks before that (but it went away). I am still running the Unichip for engine managment.
P0303 code, misfire rough idle afcivileng Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 78 10-14-2008 01:14 AM
P0303 code banshee Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-19-2006 04:29 PM
2 codes, common probs with 1.8's? subbyspeed Normally Aspirated Powertrain 14 10-10-2005 07:21 AM
trouble codes P0171, P0303, P0304 Sadisticracer1 Engine Management & Tuning 2 09-27-2005 09:29 PM
P0303 & P0302 Codes, Misfire, Running on 2 Cylinders bigbird Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-01-2004 12:44 PM
