Old 04-14-2001, 05:33 AM   #1
jlyttle
Member#: 2815
2004 Forester XT 5sp
Exclamation Amsoil filter does not fit!
I am trying to install it this morning and it just seems too big. I am installing it with the mesh facing the throttle body. It is just too big. I even took both halves of the airbox completely out of the car, and still can't get the filter in between them so that they close. I know that others have had trouble, what is the solution? Please help.
jlyttle is offline   Reply With Quote
Old 04-14-2001, 06:35 AM   #2
jlyttle
Member#: 2815
Post
Ok, it's in. It has to be done JUST the right way. Let's just say that it was a cast iron bitch. I'm sure it will be worth it, and I will know how to do it next time.
Old 04-14-2001, 07:25 AM   #3
Blindeye_03
Member#: 4418
2016 Focus ST
Post
How do you get the airbox off to put the filter in?!
---I am still waiting for mine...still using my paper filter with my ganzflow.
Blindeye_03 is offline   Reply With Quote
Old 04-14-2001, 09:12 AM   #4
jlyttle
Member#: 2815
Post
The airbox is attached by two screws that are readily visible out front. Other that that, there is a hose clamp that locks it to the throttle body and three vacume hoses that you just slide off. Pretty easy. I took a drive around after the install and ECU reset, and no real gains yet (not enough fuel I guess) but it is even louder than just the Ganzflow alone. Pretty cool!
Old 04-14-2001, 07:22 PM   #5
Skirvdawg
Member#: 3375
2002 VW Jetta Wagon
Post
I had the same issue with my Amsoil. I think I spent an hour trying to wedge that fat foot into a stilleto heel. Once I had it in and did the ECU reset, I definitely noticed the wicked sound and I also felt a little increase in power according to my butt dyno.
Skirvdawg is offline   Reply With Quote
Old 04-15-2001, 10:16 AM   #6
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Post
Yea, mine was a PITA too, it's now in there, but all warped, I hope it doesn't effect its performance. Damn, just a 1/4 of an inch shorter and it would fit perfect.
garface is offline   Reply With Quote
Old 04-15-2001, 08:45 PM   #7
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Post
I know the easiest way to put it in is to stuff it into the rear half with the mesh facing the engine. You'll notice that the edges of the filter will hang over/past the rim of the rear half of the airbox. Then swing the rear of the airbox forward and latch it closed.
It is a PITA but worth it!
Larry
ImprezaRS dot com is offline   Reply With Quote
Old 04-15-2001, 08:53 PM   #8
MagicMT
Member#: 4042
2001 Magic Mobile
Old School Style
Post
Put mine in today. I really don't think it fits either. I'm thinking about chopping it off like 1/2 unless it's supposed to just hang off the edge like 1/2 an inch. It's also bent and warped now from trying to jam it in there.
[This message has been edited by MagicMT (edited April 15, 2001).]
MagicMT is offline   Reply With Quote
Old 04-16-2001, 03:29 PM   #9
remarcable
Member#: 2362
1999 Legacy Outback
Blue w/ Paint Chips & Mud
Post
Is it a bad thing to have the filter warped and mushed in there? I am wanting to get an amsoil after every K&N autozone has ordered for me has not fit (first one was 4 inches too long, second one was 3 inches too wide, etc etc) but I am kinda concerned about this fit issue.
I have a 99 so keeping stuff away from that pesky MAF is a must!
remarcable is offline   Reply With Quote
Old 04-16-2001, 06:11 PM   #10
richeich
Member#: 1353
2001 Impreza 2.5RS
Post
Hey remarcable, your Outback would take a TS74, which is different than the one these guys are talking about. Subaru went to a different airbox for MY00 and 01. They have to use (until recently anyway) a special order filter, which I've never personally seen or used. I've got the TS74 in my wife's 96 Outback and my 98 Legacy, and it fits good. I'm not sure what to say about the fit issue with their cars.
Rich
www.lubedealer.com/tulsa
Hey guys, is there a measurable difference between the factory filter and the Amsoil?
richeich is offline   Reply With Quote
Old 04-16-2001, 07:35 PM   #11
sjt
Member#: 4135
The Spurs will
RETURN!
Cool
can't say there's a huge difference but it sure does sound meaner! But some pliers, cutters and elbow grease did the job after many scratches and bumps. Now the exhaust barks instead of burps during acceleration.
sjt is offline   Reply With Quote
Old 04-16-2001, 08:04 PM   #12
Blindeye_03
Member#: 4418
2016 Focus ST
Post
Not meaning to be a moron: dont you mean intake & not exhaust?
Old 04-16-2001, 08:49 PM   #13
sjt
Member#: 4135
The Spurs will
RETURN!
Post
can't tell fer sure, the intake made no noise before and still doesn't seem to cuz I still got the stock air box, but the exhaust seems louder, maybe I just can't tell where the sound is comin from!
Old 04-17-2001, 10:50 AM   #14
remarcable
Member#: 2362
1999 Legacy Outback
Post
Thanks richierich. I have it ordered via 'Ganz the manz' and just paypal'd him today.
Hey, did I just coin a new nickname for Larry? Prolly not...
Old 04-17-2001, 11:05 AM   #15
jlyttle
Member#: 2815
Post
Prolly not.
Old 04-18-2001, 12:46 AM   #16
Blindeye_03
Member#: 4418
2016 Focus ST
Post
Old 04-18-2001, 12:47 AM   #17
Blindeye_03
Member#: 4418
2016 Focus ST
Post
I have been waiting forever to get my amsoil filter..theyre soooo slow...
FYI: Filtering cheap vodka through a brita filter does NOT work svek Off-Topic 50 04-30-2006 06:05 PM
Itg Air filter does not fit 2002 RS 2.5 ThinkTank Normally Aspirated Powertrain 0 04-16-2002 03:57 PM
Gaugepods.com pillar pod does not fit 2002 WRX Wagon Sparks Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-06-2002 09:17 PM
STI bushing kit 2002 WRX - problems with busihings - bolt does not fit alfriedesq Brakes, Steering & Suspension 4 07-27-2001 11:27 AM
My new wing does not fit! david2z4 Technical Forum Archive 13 07-17-2000 08:58 PM
