Old 01-20-2003, 08:30 PM   #1
Mitsuby
Member#: 31725
BLu..
Default Can I run TXS stg-2 map with the HKS DP?
I just recently bought a stage 2 unichip, and my mod right now is a custom axle back, HKS downpipe, K&N, just basically the whole txs unichip stg 1 plus the HKS downpipe(still stock mid-pipe).
Will it be better for me to get the chip remapped to stgae 1, or can I run the stg 2 map with my setup above?
Mitsuby is offline   Reply With Quote
Old 01-21-2003, 10:36 AM   #2
HonduHunter
Member#: 28408
2002 vf48ed WRX
Default bump
i too would like to know that.
HonduHunter is offline   Reply With Quote
Old 01-21-2003, 02:16 PM   #3
codean
Member#: 10186
Do you still have the stock third cat or an uppipe?
Your right in between stages so I would say that you would be fine with the stage 2 unichip.
codean is offline   Reply With Quote
Old 01-21-2003, 04:01 PM   #4
Mitsuby
Member#: 31725
BLu..
The HKS downpipe takes out the last 2 cats, so I only have 1 cat remaining in the stock uppipe.
My setup goes like this.
stock uppipe-----HKS downpipe(removes 2 cats)-----Stock mid-pipe-----Custom 3" axle-back.
and of a course the K&N filter with the silencer hacked.
So, basically I have the whole txs stage-1 kit plus the HKS downpipe.
Can I run the satge 2 map safely?
Old 01-21-2003, 04:56 PM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
sorry i dont know the awser to your mapping question but
you will very small gains with a down pipe and a stock uppipe
vishnu was discussing this in another thread .. somethign to do with first point of restriction being before the turbo
-i happen to have this setup as you speek of w/o the unichip it was noticably slower than a stage 0 setup
Old 01-21-2003, 08:17 PM   #6
Mitsuby
Member#: 31725
BLu..
Thanks for the reply jaxx
So, I can't get a defenite answer here?
I already tried to email TXS couple of time, but they have not replied back yet.
Anyone.. ?
Shiv, nathan, phil??
Your golden retriver?
Old 01-21-2003, 08:24 PM   #7
Mitsuby
Member#: 31725
BLu..
The TXS unichip stage 2 only consisted of the following:
K&N panel filter, Silencer hack, and the TXS turbo back, unichip stage 2.
NO UPPIPE.
Rated at extra 40+whp??
I am pretty sure with the uppipe you will gain extra ponies, but I am only trying to see if I can use the stage 2 map with my setup above.
Somebody has to know the answer.
Old 01-22-2003, 09:32 AM   #8
lstepnio
Member#: 10972
2004 STi (fuxor3d!!)
2004 Forester X
I have an aftermarket uppipe along w/ the HKS downpipe and I'm wondering the same thing.
lstepnio is offline   Reply With Quote
Old 01-22-2003, 10:12 AM   #9
inthememof911
Member#: 14055
2013 Mustang GT
-RIP bug eye-
I would also like to know this. I am thinking about the same setup my self.
Can somebody answer this for us all!?
Mitsuby: I think you should change the thread to
<<can I use the hks downpipe with a "UTEC" stg 2 map>>
Seriously
I guess peoples don't really care about the unichip anymore, but doesn't vishnu still sell it??
Oh wait! We are still worthy because vishnu still sell the piggyback
inthememof911 is offline   Reply With Quote
Old 01-22-2003, 12:45 PM   #10
Davenow
Member#: 23676
TurboXS will still remap unichips for free, and you can buy used unichips fr under 350 now
Old 01-22-2003, 03:42 PM   #11
Mitsuby
Member#: 31725
BLu..
So, no one knows if I can use the stage 2 map safely with the setup above??
Old 01-23-2003, 01:20 AM   #12
nicktckhoo
Member#: 5836
2002 fake STi
silver and pink
yes you can...
Stock ECU will pull timing if not optimal and your setup does not deviate too much from TXS setup for stage 2. As long as you did not change out injectors or a larger turbo, you are ok.
I ran my stage 3 on a stage 2 unichip before and nothing bad happened.
Cheers
Nick
nicktckhoo is offline   Reply With Quote
Old 01-23-2003, 11:00 AM   #13
02WRX_BLUE
Member#: 13704
2006 EVO MR
Apex Silver
Hi,
I know you could with UTEC but you would need to log and see if you get KNOCK at any given point. You would just adjust timing and fuel accordingly to fix this.
In terms of UNICHIP, it is hard to say unless you can log the data to verify that it is in fact working fine. I would guess "YES" but then again you don't have a way to verify or alter the setting for UNICHIP if there are detonation. (But, you can always run the less boost like 16 or 15.5 -- In my opinion, reducing boost a little will give you a better safety margin while jeopardizing a few horse power..)
Dan from PA.
Seriously
02WRX_BLUE is offline   Reply With Quote
Old 01-23-2003, 02:15 PM   #14
codean
Member#: 10186
Ok, your even closer to a "true" stage two then I thought.
It will be fine if you run a stage two unichip with what you have.
Turboxs has stage two unichip will be fine for:
down pipe
Hi flow cat/no cat
mid pipe/ stock unit
stock muffler/hi flow muffler.
K&N filter/stock filter
up-pipe/stock unit
If your setup fall within mods then a stage 2 unichip will be fine. Having it tuned is not necessary but it could help get a little more power.
For a utec, if you go catless tuning will be required.
It doesn't matter which down pipe you have...... When it comes down to it, you got rid of one cat and that is all that the map might care about.
Old 01-23-2003, 03:43 PM   #15
Mitsuby
Member#: 31725
BLu..
Finally I got an answer!!
Thanks alot guys I really appreciate the feedback.
The only thing that I was skeptical about was still having the stock mid-pipe, even though the stock mid-pipe only have the resonator, and not a cat.
I guess I will only run about 15-15.5 psi from the recommended 16.5 for the stage 2 map. Better safe than sorry at least until I can get a new setup, or have a mid-pipe custom made to 3"(since my axle-back, and HKS DP is 3").
Anyway, thanks alot for taking the time to still give this piggybacker feedback
can i run a stage 2 map on cobb ap on this mod.? Mr. SUAVE AccessPort 9 04-07-2006 01:31 PM
Can I use TBXS Stg 4 Map with this setup? vipernj Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-15-2005 05:02 PM
Ok to run base stg 2 map all the time? Stiguy247 Engine Management & Tuning 9 05-18-2005 02:41 PM
Running NOS with TXS STG 2 ??? speedy gp Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-13-2003 11:09 PM
can I run a TXS stg 2 with only a boost gauge? waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-07-2003 12:28 AM
