Welcome to the North American Subaru Impreza Owners Club Monday August 31, 2015
Old 01-21-2003, 02:22 AM   #1
AKMustard
Member#: 31164
Midnight Black Pearl
Default ideal wheel width
What do you guys recommend,
17 x 7.5 (48mm offset)
17 x 7 (50mm offset)
Mostly i just want to get a wheel that will decently fill out the wheel well better than my stock wheels (16x7?)
Will there be a noticeable difference between 7 and 7.5 width in terms of the look?
AKMustard is offline   Reply With Quote
Old 01-21-2003, 04:23 AM   #2
Frederf
Member#: 15622
2002 WRX SW
Subaru factory wheels are
17x7 ET48
17x7.5 ET53
I believe
Frederf is offline   Reply With Quote
Old 01-21-2003, 05:20 AM   #3
balyndraks
Member#: 28678
2003 Legacy L-SE Wgn
Mystic Blue Pearl
you have 16x7 wheels. must have an older RS. a lot of people like those wheels because most subaru 16 inchers are 6.5" wide. on that particular car 17x7.5 with 48 offset probably isn't such a great idea. the 48 offset is less than optimal plus that car doesn't have the space that a wrx sedan does. on YOUR car i'd probably go with the 17x7 with the better 50 offset and run 215/45/17 though you'll probably want to ask people with the same car that you have. hope this helped.
jay
balyndraks is offline   Reply With Quote
Old 01-21-2003, 05:22 AM   #4
balyndraks
Member#: 28678
Mystic Blue Pearl
i just noticed the ? after the 16x7 indicating that you really aren't sure. what are you driving? this would help us out a lot. thanks.
Old 01-21-2003, 09:37 AM   #5
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
17x7 ET48
17x7.5 ET53
I believe
Flip those and thats pretty much correct.
Just to add a bit to the choices. I have a set of 16x7" RS wheels with the 205/55-16s on them. I really like the look of the 205 width on the 7" wheel(very little bellying of the sidewall.) I think the 215/45-17 might look as good on a 7.5" wheel.
ss
subysouth is offline   Reply With Quote
Old 01-21-2003, 10:15 AM   #6
AKMustard
Member#: 31164
I'm driving a MY02 impreza wrx. Yeah i just realized the stock wheel width is 6.5"
Is 17x7 with 50mm offset close enough to ideal?
I'm not sure if i'm thinking about this correctly but on a 17x7 wheel does a 50mm offset mean the wheels are pushed out further than a 48mm offset?
Thanks
Old 01-21-2003, 10:19 AM   #7
peepshow
Member#: 1777
2005 LGT
#92 FZippy
I have an old chassis style car. I have NO problems using 17x7.5 +48mm wheels. I run 215/45/17 Sumitomo HTR Z 2s. I have never gotten any rubbing, not during auto-x, not with passengers in the back, never. The car is lowered with Eibach Pro Kit springs and AGX struts.
- Trent
peepshow is offline   Reply With Quote
Old 01-21-2003, 10:22 AM   #8
peepshow
Member#: 1777
2005 LGT
#92 FZippy
Thanks
Nope, +50mm moves the wheel further inboard than +48mm.
You will be fine running either 17x7 or 17x7.5 +48mm.
- Trent
Old 01-21-2003, 11:09 AM   #9
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
- Trent
A setup real similar to this would be good IMO. You can get a 225/45-17 on that rim on your car. But the extra bit of width is offset to me by the added weight(rotational mass,) and decreased mpg on a daily basis. The 215/45-17 will also gear the car slightly better for acceleration and is interchangeable with almost all the other Subaru platforms. If you are running auto-x, track etc you could get some 225s on 16s for those days.
ss
Old 01-21-2003, 03:24 PM   #10
dj_noose
Member#: 17302
2002 Impreza WRX
you know... the blue one
Default Re: ideal wheel width
I don't think you'll be able to tell much difference between the two. It all depends on what size tire you put on. For a sedan I would recommend 225/45/17 and wagon 215/45/17. Either offset is good . I have 17x7.5" SSR Comps and they have 50mm offset.
dj_noose is offline   Reply With Quote
Old 01-21-2003, 04:53 PM   #11
AKMustard
Member#: 31164
thanks a lot for your help guys
I just purchased some Work Esperio 1's in 17x7 50mm offset with 225/45-17 falken's
Will post pics soon.
08 Sti: Wheel width vs. Tire width VS. offset and more. HELP! Redneck Ricer Tire & Wheel 2 12-02-2008 09:20 AM
Tire width vs. Wheel width? yamahito Tire & Wheel 8 01-28-2007 05:21 PM
Upsizing: Matching wheel width to tire width and adjusting offset sonicblue Tire & Wheel 14 08-16-2004 02:28 PM
wheel width and tire width BlueScooby New England Impreza Club Forum -- NESIC 1 07-29-2002 05:03 PM
How will Kumho V700 section width change with wheel width? Patrick Olsen Brakes, Steering & Suspension 5 08-06-2001 11:19 AM
