Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 02-26-2001, 01:23 AM   #1
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
Angry Bad Fuel Mileage
O.k I've been getting Horribel fuel mileage on my Legacy Turbo. What should I do to correct this. i.e buy Fuel injection cleaner? Change Fuel Filter? What else? I use 89 grade fuel. Sometimes when I reve too hard, ya see the needle drop a little low. Sometimes it stays and sometimes it goes back up to where it was. PLEASE HELP. Thanx
ejicon is offline   Reply With Quote
Old 02-26-2001, 02:05 PM   #2
Jgrahn555
Member#: 3224
Post
a) buy a new car. Legacy Turbos have always gotten bad gas milage.
B) change your filter.
c) put in better gas.
d) install new wiperblades.
e) different rubber compound in your tires.
f) install new plugs and wires
g) stay off the throttle so much
And lastly, your poor fuel milage might be due to the excessive wear on your head.
Jason
EDIT: Added a couple more possibilities
[This message has been edited by Jgrahn555 (edited February 26, 2001).]
Jgrahn555 is offline   Reply With Quote
Old 02-27-2001, 01:10 AM   #3
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
Thumbs up
Hahaha, Thanks Jason, you're funny. This Legacy is just a project car. I'm still looking for a used RS to play with.
Old 02-27-2001, 01:37 AM   #4
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
Unhappy
HeLp..PlEaSe!!!
Old 02-27-2001, 06:49 AM   #5
Shik
Member#: 132
2006 GT Ltd 5spd sdn
2015 WRX 6spd CWP
Post
Change your O2 sensor(assuming all the tune-up items were done). Strictly hi-way , I used to get around 27mpg with my Legacy turbo with all the mods done to it. I don't think that's that bad. Don't remember what it got before the mods.
And no offense ejicon, but I would put a minimum of 92 octane fuel in a Turbo Chevy Sprint! May be in my head from the old days, but if it's turbocharged, it gets the good stuff. I ran Sunoco 94 the vast majority of the time. The few times I ran low on gas and put in some "convenient store" 92, within a few miles the car felt totally different, sluggish, throttle response seemed to go down, etc.
Maybe my car was just picky.
Shik is online now   Reply With Quote
Old 02-27-2001, 11:36 AM   #6
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
Post
I had the same problem with my 1997 Impreza L. I changed everything from plugs, fuel filter on down to air filter. The only thing that has made any difference was putting on a www.kartboy.com MAF Filter mount and K&N Conefilter.
I'm not sure if you have the same set-up, but if the bolts going into the airbox are 5.1cm by 9.1cm, it'll work. It's simple to install and I went from 19-21 mpg to 26-28!!!
<IMG SRC="http://216.242.153.40/memberslist/userpics/2863/intake.jpg" border=0>
[This message has been edited by BrysImpreza (edited February 27, 2001).]
BrysImpreza is offline   Reply With Quote
Old 02-27-2001, 11:42 AM   #7
the spacecowboy
Member#: 765
Post
wiperblades?
the spacecowboy is offline   Reply With Quote
Old 02-27-2001, 05:53 PM   #8
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
Post
Erm, Brys, you didn't gain 7MPG from the new intake. I guarantee it. Did you reset your ECU at the time you did the intake? That was likely what made the difference. If not, the new intake probably just forced the ECU to adjust on it's own.
gavin is offline   Reply With Quote
Old 02-27-2001, 07:15 PM   #9
Greborb
Member#: 2974
Post
Another possibility is a bum fuel injector. Just had that problem with my RS with one spraying way too much fuel. Ended up saturating the cat.
Greborb is offline   Reply With Quote
Old 02-27-2001, 07:15 PM   #10
Greborb
Member#: 2974
Post
Old 02-27-2001, 08:07 PM   #11
Rez
Member#: 1958
1999 Impreza 2.5 RS
Rally Blue Pearl
Post
First and foremost, reset your ECU. Brought about 40 miles per tank for me.
-Rez
<IMG SRC="http://www.reverberations.com/Storage/Images/scrambles.gif" border=0>
Rez is offline   Reply With Quote
Bad Fuel Mileage? Subie Doobie Newbies & FAQs 291 07-20-2007 11:23 AM
Bad fuel mileage problem found fosheezy05 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-02-2007 03:58 AM
Fuel mileage getting bad 02REX4LIFE South West Impreza Club Forum -- SWIC 11 02-08-2007 06:46 PM
Can a bad fuel filter cause bad mpg? abosworth Normally Aspirated Powertrain 11 10-06-2005 07:20 PM
Bad Fuel Mileage Jason Legacy Forum 7 03-05-2001 05:32 PM
