Old 02-26-2001, 07:41 AM   #1
jvogel
Member#: 3693
Question Cost to Install Limited Slip Differential?
I'm considering a 2002 RS purchase, but I'm not happy about the lack of a LSD. Any educated guesses as to the cost of purchase/installation? Many thanks!
jvogel is offline   Reply With Quote
Old 02-26-2001, 10:52 AM   #2
Frank
Member#: 3791
Post
I am going to assume you just want the rear diff to be LSD, ive seen the upgraded Quaiffe units for around 1400 i believe so maybe low 2000's for the install. The stock factory unit is probably cheaper but im just throwing out guesses.
~Frank
Frank is offline   Reply With Quote
Old 02-26-2001, 11:02 AM   #3
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
FYI, Quaife America just dropped their prices after months of racers refusing to pay their ridiculously high prices. (People would import them.)
The Subaru Impreza application is now $995, and yes it was $1395.
ColinL is offline   Reply With Quote
Old 02-26-2001, 11:06 AM   #4
jvogel
Member#: 3693
Post
Many thanks, gentlemen...I'll start the savings account!
Old 02-26-2001, 01:25 PM   #5
Trey
Member#: 670
Post
Does anyone know if the Quaife units use the Non-Turbo DOJ units or the Turbo DOJ? If you need to get new DOJ units to fit the new rear diff, keep in mind these will run you about $575-$600/pair.
Installing the rear diffs in these cars really isn't all that difficult. Just make sure your shop has experience with this type of work and they should have a problem.
Regards,
Trey
CobbTuning.com
Trey is offline   Reply With Quote
Old 02-27-2001, 12:13 AM   #6
wistful
Member#: 745
2004 STi
Java Black Pearl
Post
Kaaz 1.5 way differential is only a few hundred. 6-8, i don't remembe exactly. From my GT2 experience, this is my fav diff. =)
Don
wistful is offline   Reply With Quote
Old 02-27-2001, 12:21 AM   #7
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
I would greatly prefer a Quaife automatic torque biasing diff to any clutch-type LSD for tarmac use. Besides, the Quaife carries a lifetime warranty versus frequent clutch replacement for the Kaaz.
Anyone that has replaced / re-shimmed clutches in an LSD, and frequently, has to be at least considering Quaife.
Limited slip differentials versus electronic slip differential Orson Factory 2.0L Turbo Powertrain 2 12-16-2002 10:29 AM
Limited Slip Differentials NeoteriX Newbies & FAQs 3 08-08-2002 03:50 PM
Limited slip differentials everbruin Transmission (AT/MT) & Driveline 9 04-15-2002 08:24 AM
Rear limited slip differential for 1993 L dsc Transmission (AT/MT) & Driveline 8 03-22-2002 02:54 AM
Anyone know of a front limited slip differential for the 4EAT auto trans? Digital_Boy Normally Aspirated Powertrain 3 12-03-2000 09:58 PM
Message Board Statistics All times are GMT -4. The time now is 09:46 AM.
