Closed Thread
Old 01-21-2003, 02:16 PM   #1
freeze
Member#: 26061
2007 Forester XT
UGM
Default grounding kit
Can anyone give some info on grounding kits, like the Hot Earth one for example. Will it do much for a stock WRX? And how easy are they to install? Thanks
Ryan
freeze is offline
Old 01-21-2003, 07:41 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Kits are very easy to install, wether or not you will notice a difference...hard to say.
Jay
munkis is offline
Old 01-22-2003, 05:54 AM   #3
Ethan
Member#: 246
According to the packaging, the SYMS kit gives 5hp more. Of course all the grounding kits I've seen are around $100 (here in Japan at least) is it worth that much? and will you notice a difference is a good question.
Ethan is offline
Old 01-22-2003, 10:34 AM   #4
Peaty
Techno Sapien
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
Peaty is offline
Old 01-22-2003, 03:06 PM   #5
sonicblue
Member#: 25227
2012 Escape
I went to sounddomain.com and bought all wire and connectors necessary - spent about $30 or less, I think. Four-point grounding with distribution block. Kits are overrated IMO.
Pic here
Why can't I link a pic???
sonicblue is offline
Old 01-22-2003, 04:31 PM   #6
kingston
Member#: 25079
1987 Subaru GL
rust blue
I work at an audio place. I decided to change out the negative terminal out with a silver plated one. I then took a foot of 4 guage wire and attached it from the terminal to a distribution block. I ran 8 gauge power wire out of there to different ground points in the car.
Didn't feel anything. OH well.
kingston is offline
Old 07-15-2004, 07:25 AM   #7
spliffpirate
Member#: 66307
1994 Accord
Seige Green
I don't think you can gain HP by it but I have heard it in the past before. I use NOLOGY ground cable especially their spark plug wires witch come with their own ground straps, & they have different colors too! call nology & ask them about that HP they might be able to answer that for you since they do especialize on it. www.nology.com
spliffpirate is offline
Old 07-15-2004, 12:46 PM   #8
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
Ebay has a couple of super nice kits for sale too for cheap
great guy too
Shane
www.paranoidfabrications.com
PARANOID56 is offline
Old 07-15-2004, 04:19 PM   #9
ptsmalls
Member#: 31960
2012 R
I like the idea of using the distribution block. Here's where i stand now. Couple things im stuck on.
* Ive heard that chaining the grounds is bad.
* The strut towers are poor grounds.
So I'm working off the idea that i get 4 wires from the dist. block.
I figure one to each side of the manifold.
Then one to the passenger side fenderwall.
Another to the spot behind the IC.
Thats 4 spots there, i was gona do a short one from the neg. term to the driverside fenderwall.
Giving me 5 spots.
Are these the best spots to use ? Or can I daisy chain to include the strut mounts ?
This would be easier and cleaner if they had a dist. block that had one 4ga. in and 5 or 6 8ga. out.
ptsmalls is online now
Old 07-15-2004, 04:47 PM   #10
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
I have the Lineage one and it RULZ!!!
Hank3 is offline
Old 07-15-2004, 05:34 PM   #11
mindchatter
Member#: 36447
Heav en for the weat
her & Hell for company
I made my own, it was a cool project, cost me approx. me $50 in materials, and I get compliments on it every time I open the hood. I didn't daisychain anything though, ran an individual 8ga wire to 5 or 6 diff't points into a Stinger distributor block that's zip tied on top of my Optima. I then ran a single 4ga wire to the negative terminal.
If I noticed a difference it was in the smoothness at start-up, but I'd be wary of believing HP increases though.....
Stu
mindchatter is offline
Old 07-15-2004, 06:11 PM   #12
PARANOID56
Member#: 22035
2003 Brocoma DCab
yea, those are good grounds, i would also tie into the stock grounding points on the engine. there should be two of them. then also ground near the t-body to hit those sensors also.
Shane
Old 07-16-2004, 02:31 AM   #13
spliffpirate
Member#: 66307
1994 Accord
Seige Green
I haven't replaced my grounds yet! but will do so soon!. To you fellas out ther I suggest getting NOLOGY Spark Plugs Wires because they have their own built in ground straps! YES YOU ARE READING RIGHT! They have their own ground straps on the spark plug wires! you connect them were your headers are! you will notice an increased HP! & on save GAS!. I have them on my 94 Accord! Every time I open my hood I get complements even by COPS! hehehe They say "WOW DOES ARE REALLY NICE PLUGS YOU GOT THERE! WHO MAKES THEM? THEY LOOK VERY NICE! I NEVER SEEN DOES BEFORE!" then they say "ARE DOES LEGAL?" & I say "YES THE CARB NUMBERS ARE THERE! & THEIR MADE BY NOLOGY LOOK FOR YOUR SELF!" Then they ask were did I buy them & how much they cost!. I know its unbelivable when they ask me does things cause its funny! they stop me for what ever reasons but then they let me go, unless if I was speeding!, but when I'm just crusing they pull me over tell the pop my hood they see that everything is legal that I have the carb # for everything they let me go. I suggest bying them through SUMMIT RACING! its alot cheaper! but you are going to spend about a buck fifty (150.00) thats how much I bough mines for & I TELL YOU ITS WORTH IT! YOU WILL FEEL A LITTLE BIT MORE HP! i GUARANTEE!!. tHOSE WERE THE FIRST THING I PUT ON MY CAR & i FELT IT A LITTLE BIT BUT ENOUGHT TO LET ME KNOW THAT YEAH THEY DO GIVE YOU SOME HP! & SAVES YOU GAS!
Old 07-16-2004, 05:02 AM   #14
Rickyh
Member#: 40453
Just get the Paranoid Fabrications kit. Won't break the bank and is just as good as the high priced ones.
as far as the Nology plug wires......the wrx has coil on plug, no plug wires.
Rickyh is offline
Old 07-16-2004, 06:07 AM   #15
GravelRash
Member#: 16318
2002 WRX Franknwagen
Grime over Sedona Red
Fwiw...
- 10 ga. wire - plain 'ol automotive primary wire from any auto parts store - should be sufficient
- don't daisy chain
- run a wire from each of the ground bolts on the intake manifold, near the front on each side (you'll see existing wire looms attached to each of them); other ends of the wires go to the existing ground bolt on driver's fender - where the short heavy ground lead from the battery attaches
- if you want you can add another wire from the alternator case to the same lug on the fender; mine is under the top outboard case screw head (note: it was very difficult to get the screw broken loose w/o stripping the head; very tight!)
- probably a good long term idea to solder the lugs to the wires
- use a dialectric grease (auto parts store) on all the connections; the whole idea here is to improve the overall ground paths to the critical grounds on the engine - long term, hence the grease
The major potential issue here is that the sensor shielding grounded to those points on the intake manifold are then dependent on the conductivity through the manifold's connections to the heads, and the head's connections to the block, and it's connections to the body...and thence back to the battery.
Which wouldn't be a big deal if we were dealing with grounding a 12V hi current connection, e.g. headlight. But these are shield grounds, as well as potentially ground paths for sensors (haven't verified that): low voltages and low currents - which may not reliably pass all those interfaces, especially over time as conductivity decreases (think dissimilar metals - steel / aluminum / zinc plating, galvanic reactions, corrosion over time...).
So adding a clean path back to the battery ground (via the fender lead) can help keep signals clean long term.
Don't bother with strut tower connections, etc., unless someone can give you a really convincing technical explanation of why they might be beneficial...and I haven't heard one yet
Btw, all this was checked out w/ a EE with long term automotive experience. His general opinion is that ground paths are the easiest areas to overlook or take for granted when designing systems...
GravelRash is offline
Old 06-08-2011, 11:14 PM   #16
DHmtnbiker42
Member#: 271393
2002 wrx
Default ground cables
ive seen 15hp on the dyno. the stock ignition system gives a terrible burn because the coils cant perform at full voltage with the stock ground cables
DHmtnbiker42 is offline
Old 06-08-2011, 11:24 PM   #17
AllWires
Member#: 217916
2007 STI
UMG
AllWires is offline
Old 06-10-2011, 01:16 AM   #18
krisc10124
Member#: 235965
2006 sti
obp
any one have a pic on this?
krisc10124 is offline
Old 06-10-2011, 06:36 AM   #19
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
No need to bump this thread from 2003.
Use the search function to find info on grounding kits and DIY's, there are plenty of threads to read.
Mulder is offline
Closed Thread
SoCal : Sun HotInaZma Ground Kit & Split Fire Japan Hyper Voltage Kit!!!!! outcast Engine/Power/Exhaust 10 12-20-2006 09:14 PM
F/S: SunAuto voltage kit and HKS circle earth grounding kit swift2fly SCIC Private Classifieds 0 10-25-2006 10:55 PM
grounding kits stock ground points spdracr00 Legacy Forum 4 10-30-2005 11:05 PM
Do Grounding kits work with trunk mounted battery? Dan_E Electrical & Lighting 6 02-12-2005 11:14 AM
intake/ground kit Orville Cote Legacy Forum 1 03-22-2003 12:05 AM
