Old 02-16-2001, 09:03 PM   #1
suberstar 2.5
Member#: 2633
1999 STi ver5 TypeR
white
Question what parts would i need to build my own turbo kit?
i am considering doing this and just wanted to know what parts i would need. by the way i will most likely be useing AU spec WRX parts.
suberstar 2.5 is offline   Reply With Quote
Old 02-17-2001, 07:25 AM   #2
smacksube
Member#: 4067
01 2.5 rs
Post
the most important thing to drop money on is the fuel system for your car...the turbo and all the piping is good to have done professionally, but your fuel system is what's going to keep your engine from blowing. I would recommend getting a stand alone fuel system, not one that's boost dependant. With a stand alone system, you don't have to worry about high pressure in the fuel lines if you get big enough injectors. so as far as the fuel system goes you'll need, injectors, a fuel pressure regulator, spark plugs, new fuel pump, a fuel management unit, and I think that's it, I'm coming from the top of my head, so yep...
smacksube is offline   Reply With Quote
I want to make my own grouding kit for my engine what do i need bottlediger Car Audio, Video & Security 8 12-26-2005 05:21 PM
Finally did the part break out used to build my water injection kit RiftsWRX Water/Methanol Injection, Nitrous & Intercooler Cooling 29 08-17-2004 01:35 PM
Finally did the part break out used to build my water injection kit RiftsWRX Water/Methanol Injection, Nitrous & Intercooler Cooling 11 08-12-2004 11:57 AM
So I'm building my own turbo kit jasona Normally Aspirated with bolt-on Forced Induction Powertrain 9 07-15-2003 06:52 AM
To anyone building their own turbo kit RalliSpec Normally Aspirated with bolt-on Forced Induction Powertrain 8 09-26-2001 09:27 AM
