Welcome to the North American Subaru Impreza Owners Club Sunday May 26, 2013
Old 01-21-2003, 01:48 PM   #1
Projekt
Member#: 15947
91 RX-7
Brave Blue
Default How often should I change my boost fluid?
feel free to add any stupid remarks
how about teflon spark plugs?
Projekt is offline   Reply With Quote
Old 01-21-2003, 01:51 PM   #2
gongzero
Member#: 25040
Up with skirts,
down with pants!
for maximum effectiveness against SRT-4, consider changing boost fluid every 1 miles.
gongzero is offline   Reply With Quote
Old 01-21-2003, 01:51 PM   #3
aod
Member#: 7121
A friend of mine calls tampons spark plugs.
So, I feel that you should change your spark plugs whenever they get too soiled - teflon or not.
aod is offline   Reply With Quote
Old 01-21-2003, 01:53 PM   #4
Johnny Knoxville
Member#: 18508
if your boost fluid gets low...just add water to it.
Johnny Knoxville is offline   Reply With Quote
Old 01-21-2003, 01:54 PM   #5
Kaiser
Member#: 7170
Aut Kaiser,
aut nullus.
Teh fluid from teh oilcovers can be substituted, in a pinch.
Kaiser is offline   Reply With Quote
Old 01-21-2003, 01:55 PM   #6
gongzero
Member#: 25040
Up with skirts,
down with pants!
i don't want to know what kind of girl your buddy has been with, to call tampons spark plugs.
Old 01-21-2003, 01:56 PM   #7
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Now thatthe SRT-4 is coming out, it will never matter how often you change it. You will still be slow.
Eric
Eric SS is offline   Reply With Quote
Old 01-21-2003, 01:57 PM   #8
Crawdads
Member#: 30907
SWP GDB-G
I replaced my boost fluid with Type-R synthetic (IIRC, its the same stuff found in the JDM Factory Twin Turbo Civics ) So now i only have to change it everytime i refill my NAWS bottle.
Crawdads is offline   Reply With Quote
Old 01-21-2003, 01:58 PM   #9
GooseMan
Member#: 2462
2012 Volvo S60 T5
2005 Triumph Sprint ST
its ALL about the hyperkinitec blinker fluid, people! check it ONCE a month! I cant stress this enough!
GooseMan is online now   Reply With Quote
Old 01-21-2003, 02:00 PM   #10
Projekt
Member#: 15947
91 RX-7
Brave Blue
that's ironic cause there are some things you can substitute
Brake fluid - dish soap
fan belt - panty hose
Old 01-21-2003, 02:01 PM   #11
gongzero
Member#: 25040
Up with skirts,
down with pants!
let's not forget:
brains - horsepower
Old 01-21-2003, 02:03 PM   #12
jasona
Member#: 11786
02 TS
Black on White
i use imitation h.i.d. blinker fluid.
jasona is offline   Reply With Quote
Old 01-21-2003, 02:04 PM   #13
-=C=-
Member#: 7719
how often to change your boost fluid is dependent upon what size pulley you are using on your turbo
-=C=- is offline   Reply With Quote
Old 01-21-2003, 02:05 PM   #14
pink-i
Member#: 23640
Careful, folks. Don't do anything that might overwork your trunkmonkey.
pink-i is offline   Reply With Quote
Old 01-21-2003, 02:06 PM   #15
IggDawg
Celebrity Guest Star
Member#: 10648
2002 Escort... D:
Mostly kind of white
blinker fluid should be changed at the same time as the boost fluid.
Don't forget to clean out your spark wires. you don't want anything getting in the way of the spark charge. If you're losing performance, try boring out the wires a little more.
You can substitute marbles for mufler bearings in a pinch. just pour them in with the oil, and they'll flow to the proper location.
-IggDawg
IggDawg is offline   Reply With Quote
Old 01-21-2003, 02:07 PM   #16
Kaiser
Member#: 7170
Aut Kaiser,
aut nullus.
I hear the new STi sprays boost fluid directly over the intercooler for maximum turbocity.
Old 01-21-2003, 02:07 PM   #17
Moop
Member#: 19729
2000 S4
I don't do it as often as I should, as I don't have a set of left-handed wrenches.
Moop is offline   Reply With Quote
Old 01-21-2003, 02:08 PM   #18
Thug
Choke Artist
Member#: 603
You should change it atleast every season to the appropriate fluid. Just like you change the air in your tires to winter air in the winter, and summer air in the summer. Or else you'll risk blowing your doforlator valve.
Thug is offline   Reply With Quote
Old 01-21-2003, 02:09 PM   #19
pink-i
Member#: 23640
Have any of you guys tried the new intercooler heater for those REALLY cold mornings?
Just be careful, turbo fluid is highly flammable like NAWS!
Old 01-21-2003, 02:10 PM   #20
-=C=-
Member#: 7719
yeah but you have to push the button in the STi. The SRT-4 automagically predicts when you want the boost fluid sprayed on the intercooler, and it has a thermostat where you can set the intercooler's temp to regular/cold/NAWS from inside the cabin.
Old 01-21-2003, 02:10 PM   #21
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
My favorite blinker fluid is from Kaleco Auto.
http://www.kalecoauto.com/
Eric
Old 01-21-2003, 02:11 PM   #22
GooseMan
Member#: 2462
2012 Volvo S60 T5
YOU SERIOUS, CLARK?!
NICE!
Old 01-21-2003, 02:11 PM   #23
ITWRX4ME
Member#: 24472
2001 Miata
You can replace your boost fluid with vegetable oil.
ITWRX4ME is offline   Reply With Quote
Old 01-21-2003, 02:11 PM   #24
-=C=-
Member#: 7719
got a part # for that in case it happens ??
Old 01-21-2003, 02:12 PM   #25
ITWRX4ME
Member#: 24472
2001 Miata
You can replace your gas with vegetable oil.
Changed my driving routine, how often should I change my oil? eurospek Service & Maintenance 8 11-04-2009 09:57 PM
How often should I change my diff and trans fluids on STi? elitescouter Newbies & FAQs 3 08-12-2007 04:58 PM
How often should i change my plugs? eatsrice Factory 2.0L Turbo Powertrain 2 03-06-2006 08:09 PM
How often should we change our brake fluids? kenny08 Service & Maintenance 5 09-07-2005 09:44 AM
how often should I change my manual tranny fluid? 96Lconversion New England Impreza Club Forum -- NESIC 6 05-30-2001 12:18 AM
Message Board Statistics All times are GMT -4. The time now is 02:57 AM.
