Old 01-21-2003, 02:04 PM   #1
Turbo GC4
Member#: 28555
Default Whose boosting an EJ22 NA?
Got a 98 Impreza w/ an EJ22 NA with plans of adding Subachad's up/down pipes and a TDO4.
Instead of a motorswap I think im going to get my cylinders overbored and then use overbored EJ22t Pistons then getting the block o-ringed. Anyone hear of this or a similiar setup?
I think it will be cheaper and about as effective as a whole ej22t swap.
Turbo GC4 is offline   Reply With Quote
Old 01-21-2003, 08:32 PM   #2
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default Leave alone
I am boosting on a stock engine and so are a few others. I would suggest that you leave it stock and boost that for awhile. If you blow the headgasket or something then open it up. But the main thing this engine needs in new heads. The single exhaust port for each head is brutial for high flow up top and would be the first place I would spend my money if modifying the stock engine.
Joshua
yebokmj is offline   Reply With Quote
Old 01-22-2003, 01:09 PM   #3
Portly
Member#: 1197
1997 Impreza Wagon
Mystic Blue Pearl
Joshua
Could you elaborate on what makes you feel that the single port heads flow so poorly (other than that everyone says so)? I've never seen any flow tests on these heads. Also, what type of turbo setup are you running?
FWIW, in NA form my '97 2.2 pulls to redline quite well.
Thanks
Jeff
Portly is offline   Reply With Quote
Old 01-22-2003, 01:36 PM   #4
Aspen
Member#: 145
Banned to
Housework for Summer
Not sure if the head's themselves flow poorly on the 2.2L but I do know that the casting tolerences left little to be desired. I've found less than perfect holes and casting imperfections when I took off my exhaust manifold. I port matched the two by grinding some metal off the head and also grinding the thick lip that protrudes from the exhaust manifold.
http://www.imagestation.com/picture/...1/fd24620f.jpg
But I do agree with Josh and think that you should just use your 2.2L first and see what it can do until it breaks then go ahead and rebuild it properly.
Aspen is offline   Reply With Quote
Old 09-10-2014, 08:46 AM   #5
squarebush
Member#: 173656
squarebush is offline   Reply With Quote
Old 09-11-2014, 04:07 PM   #6
no694terry
Member#: 220816
98 Forester S/t
heart breaker
I am, but a phase one with low compression and better heads. Little different animal. I call it my junkyard build. My clutch cost more than the hole rest of the build.
no694terry is offline   Reply With Quote
boosting on an ej22 shortblock not a ej22t sime Normally Aspirated with bolt-on Forced Induction Powertrain 10 09-11-2014 06:05 PM
Theoreticals...max performance from EJ22 NA kaisersouse Normally Aspirated Powertrain 16 07-22-2005 06:46 AM
A request for anyone with an EJ22 turbo or EJ18 NA motor in pieces (hey Fitz/Darshu!) North Ursalia New England Impreza Club Forum -- NESIC 10 02-14-2004 02:30 AM
WTB EJ22 na Turbo GC4 North West Impreza Club Forum -- NWIC 0 03-27-2003 04:53 AM
Power on EJ22 NA? oldpreza Normally Aspirated Powertrain 1 05-03-2001 10:05 PM
